Printing all OpenCL devices Not detecting all OpenCL devices under Windows
I wrote a little bit of code to read out the OpenCL devices on a computer and some selected information about each device.
int main()
	unsigned int i, j;				//iterator variables for loops
	cl_platform_id platforms[32];			//an array to hold the IDs of all the platforms, hopefuly there won't be more than 32
	cl_uint num_platforms;				//this number will hold the number of platforms on this machine
	char vendor[1024];				//this strirng will hold a platforms vendor
	cl_device_id devices[32];			//this variable holds the number of devices for each platform, hopefully it won't be more than 32 per platform
	cl_uint num_devices;				//this number will hold the number of devices on this machine
	char deviceName[1024];				//this string will hold the devices name
	cl_uint numberOfCores;				//this variable holds the number of cores of on a device
	cl_long amountOfMemory;				//this variable holds the amount of memory on a device
	cl_uint clockFreq;				//this variable holds the clock frequency of a device
	cl_ulong maxAlocatableMem;			//this variable holds the maximum allocatable memory
	cl_ulong localMem;				//this variable holds local memory for a device
	cl_bool	available;				//this variable holds if the device is available
	//get the number of platforms
	clGetPlatformIDs (32, platforms, &num_platforms);
	printf("\nNumber of platforms:\t%u\n\n", num_platforms);
	//this is a loop for platforms
	for(i = 0; i < num_platforms; i++)
		printf("Platform:\t\t%u\n\n", i);
		clGetPlatformInfo (platforms[i], CL_PLATFORM_VENDOR, sizeof(vendor), vendor, NULL);
		printf("\tPlatform Vendor:\t%s\n", vendor);
		clGetDeviceIDs (platforms[i], CL_DEVICE_TYPE_ALL, sizeof(devices), devices, &num_devices);
		printf("\tNumber of devices:\t%u\n\n", num_devices);
		//this is a loop for devices
		for(j = 0; j < num_devices; j++)
			//scan in device information
			clGetDeviceInfo(devices[j], CL_DEVICE_NAME, sizeof(deviceName), deviceName, NULL);
			clGetDeviceInfo(devices[j], CL_DEVICE_VENDOR, sizeof(vendor), vendor, NULL);
			clGetDeviceInfo(devices[j], CL_DEVICE_MAX_COMPUTE_UNITS, sizeof(numberOfCores), &numberOfCores, NULL);
			clGetDeviceInfo(devices[j], CL_DEVICE_GLOBAL_MEM_SIZE, sizeof(amountOfMemory), &amountOfMemory, NULL);
			clGetDeviceInfo(devices[j], CL_DEVICE_MAX_CLOCK_FREQUENCY, sizeof(clockFreq), &clockFreq, NULL);
			clGetDeviceInfo(devices[j], CL_DEVICE_MAX_MEM_ALLOC_SIZE, sizeof(maxAlocatableMem), &maxAlocatableMem, NULL);
			clGetDeviceInfo(devices[j], CL_DEVICE_LOCAL_MEM_SIZE, sizeof(localMem), &localMem, NULL);
			clGetDeviceInfo(devices[j], CL_DEVICE_AVAILABLE, sizeof(available), &available, NULL);
			//print out device information
			printf("\tDevice: %u\n", j);
			printf("\t\tName:\t\t\t\t%s\n", deviceName);
			printf("\t\tVendor:\t\t\t\t%s\n", vendor);
			printf("\t\tAvailable:\t\t\t%s\n", available ? "Yes" : "No");
			printf("\t\tCompute Units:\t\t\t%u\n", numberOfCores);
			printf("\t\tClock Frequency:\t\t%u mHz\n", clockFreq);
			printf("\t\tGlobal Memory:\t\t\t%0.00f mb\n", (double)amountOfMemory/1048576);
			printf("\t\tMax Allocateable Memory:\t%0.00f mb\n", (double)maxAlocatableMem/1048576);
			printf("\t\tLocal Memory:\t\t\t%u kb\n\n", (unsigned int)localMem);
	return 0;
On my macbook pro (running Mac OS 10.6 so OpenCL is already installed) I detect 3 OpenCL devices with this code, (2 nVidia Cards and my Core 2 Duo processor), everything works great.
On my windows desktop I have an nVidia card and a core 2 Quad processor. I’m using Visual Studio 9 and the OpenCL SDK that came with CUDA 4.0. I’m only detecting my video card with this code (not my multi-core processor as well).
Does the OpenCL implementation that comes with CUDA only work with nVidia Graphics Cards? Is there another implementation I can install that includes support for Multi-core CPUs?
Yes.
Yes, see here.
Thanks a lot!
