Description
Printing "float_val: " log for a long time when converting saved model.
Environment
TensorRT Version: 5.1.5
GPU Type: GeForce GTX 1080Ti
Nvidia Driver Version: 455.45.01
CUDA Version: 10.0
CUDNN Version: 7.4
Operating System + Version: ubuntu 18.04
Python Version (if applicable): 3.6.9
TensorFlow Version (if applicable): 1.15.4
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Codes as follow:
from tensorflow.python.compiler.tensorrt import trt_convert as trt
converter = trt.TrtGraphConverter(input_saved_model_dir='/root/models/v0/cpu/embed_v3_no_scope', max_workspace_size_bytes=(11<32), precision_mode='FP32', maximum_cached_engines=100, input_saved_model_signature_key='predict_y', input_saved_model_tags=['serve'], is_dynamic_op=True)
converter.convert()
converter.save('/tmp/tensorrt_model')
When convert, it print "float_val: " log for a long time and don’t stop for 1 hour at now. Is it normal? My model is actual a large model.
Log like:
float_val: -0.0009008728666231036
float_val: -0.0017594805685803294
float_val: 0.0001926921249832958
float_val: 0.0007630143663845956
float_val: 0.0010934184538200498
float_val: 0.0013937398325651884
float_val: 0.0011748558608815074
float_val: -0.0005035705980844796
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
