I’m using OpenCL to process realtime audio effects (mainly based on convolution).
In current implementation, my audio driver requires the process time of each audio bloc to be under 11,6ms (512samples @44,1kHz).
My current implementation works well, and process time is around 7ms. So everything is fine until, someone else needs the card.
When I resize a window under Win XP, the GPU is used, and my processing time goes up to 14ms. And so my audio cracks.
I a using 2 NVidia 8800GTX cards, and the questions are the following :
- Is it possible to affect priorities to my kernels, so that I keep real time processing, an avoid cracks (I mean higher priority, than win XP graphical display).
- My OCL program runs on a single card, is it possible to execute all Windows XP operations on the other card (so that the first one is used only for real time audio processing).
