We are looking for solution to store other private key not limited to secureboot key. we noticed that there are ODM reserved bit in fuse.
(FUSE_RESERVED_ODM0 [31:0])
the concept of Secureboot is to prevent execution of unauthorized code during boot process through chain-of-trust;
those authenticates boot components (such as, Boot Configuration Table, bootloader binaries, and warmboot vector) were signed using private key.
once the ODM production mode bit is burned, fused keys can no longer be read.
you may enable TA/CA services to perform a secure operation,
however, it’s secureOS feature and it only applies to: Jetson Xavier NX, Jetson AGX Xavier series, and Jetson TX2 series devices.
please also check developer guide, Trusty, a Trusted Execution Environment for reference,
thanks
hi Jerry, I understood the secureboot is different thing . what i am asking is if i can leverage fuse to store other key if fuse is large enough . i think fuse and secureboot are different topic.
it’s ODM field fuses, for example, it’s 256-bits of field programmable ODM_Reserved fuses.
you may check those fuse via sysnode, for example, /sys/devices/7000f800.efuse/7000f800.efuse:efuse-burn/reserved_odm*
note,
thanks
Hi Jerry
“once the ODM production mode bit is burned, fused keys can no longer be read” can you explain how to read the ODM field then ? if we put key in the ODM field and how the application read these key ?
to clarify,
fused keys can no longer be read once the ODM production mode bit is burned; the only exception is the Reserved_ODM fuses; Reserved_ODM will be disabled after you’d program the ODM_lock fuse bit.
it’s Secureboot is to prevent execution of unauthorized code during boot process through chain-of-trust.
so,
you may have your use-case to store keys in fuse for using before program the ODM_lock.
what’s purpose of ODM_LOCK if we can not read them afterwards. in our case do you suggest we can use these 256-bits field but never lock the fuse bit ?
so i am sorry i sitll dont know how should i use these field . ? Should i store our priviate key but not lock the fuse bit ? otherwise you said i can not read them . we are looking for a place we can save priviate key and read it out after system boot up
please avoid to burn ODM production and also ODM lock to program the fuse,
after system boot-up, you’re able to read the fuse (via, efuse) for your use-case.
thanks
should i use sudo ./odmfuse.sh -i <chip_id> -c PKC -p -k <key.pem> [-D <DK_file>] in the factory to burn it first then after booting up the program can read via /sys/devices/7000f800.efuse/7000f800.efuse:efuse-burn/reserved_odm* ?
Eventually, i wang to enable secure boot which means i need turn on the production mode . At same time i need addtioanl bit to store addtional key and I am looking at odm_reserved field. if dont set odm_production_mode to 1 but dont set odm_lock . will secureboot still work also i can still read the /sys/devices/7000f800.efuse/7000f800.efuse:efuse-burn/reserved_odm* after system boot up ?
sorry i meant if i set odm_production_mode to 1 but dont set odm_lock. will secureboot still work also i can still read the /sys/devices/7000f800.efuse/7000f800.efuse:efuse-burn/reserved_odm* after system boot up ?
