After booting, go to read WIFI MAC address, Probably read the wrong MAC ADDRESS(00:90:4C:16:70:01).Our carrier board does not have EEPROM.What is possible to try or check?
Better sharing the boot up log from uart console. Also, the eeprom which has mac address is on module, so it does not matter if your carrier board does not have eeprom.
Why did I read the wrong MAC address (00: 90: 4C: 16: 70: 01)?What does this mac address mean?
What are the possible directions to debug?
This is a hardcoded value in our driver.
Please share the boot up log with us first.
I would suggest you to upgrade to rel-32 or at least rel-28 if possible. Rel-24 is a little too old for debug here.
Anyway, I saw there is i2c error so eeprom read gets failure.
i2c_read of GPIO expander reg 5 failed: -121
ERROR: Cannot read board ID EEPROM
WARNING: failed to read board EEPROM
Are you using a custom carrier board?
Yes, we use custom carrier board.As mentioned earlier, there is no eeprom on custom board.The client still uses the old version, we need to find out the problem
Hi cancel27,
The eeprom for mac address is on “TX2 module”. It should not matter whether your custom carrier board has eeprom or not.
For debug only, please try to put this module back to nvidia devkit and flash it with rel-28.3 and see if this mac address is still wrong or not.
case 1. It is correct, then please flash with rel-24.x again with devkit and see if it is correct or not. If it is again correct, then please confirm if any hardware design problem on your custom carrier board.
case2. If it is not correct, then it is possible something wrong with this module.
