• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Is it possible to do probe on individual stream after nvstreamdemux ?
I am trying to attach probe function on individual stream in deepstream-demux-multi-in-multi-out example , but i am getting frames of all streams in probe function event callback.
• TensorRT Version
Blockquote
import gi
gi.require_version(‘Gst’, ‘1.0’)
from gi.repository import Gst
def my_probe_function(pad, info, user_data):
# Check the streamid property of the GstPad object to identify the stream
streamid = pad.get_property(“streamid”)
print(“Got a buffer from stream”, streamid)
# Access the GstBuffer object from the info object
gst_buffer = info.get_buffer()
# Process the buffer as needed
# Return Gst.PadProbeReturn.OK to pass the buffer down the pipeline
return Gst.PadProbeReturn.OK
Iterate over the output pads of the nvstreamdemux element
for i, pad in enumerate(nvstreamdemux_src_pads):
# Set the streamid property on the pad
pad.set_property(“streamid”, i)
# Attach the probe function to the pad
pad.add_probe(Gst.PadProbeType.BUFFER, my_probe_function, None)
Regarding your second question, info is a Gst.PadProbeInfo object that contains information about the probe event, such as the GstBuffer object that triggered the probe, the direction of the data flow (i.e., whether it is a buffer going upstream or downstream), and the timestamp of the buffer. The info.get_buffer() method returns the GstBuffer object that triggered the probe.
