hi,
i’m getting this trace
[code]./cat.sh
tracer: nop
entries-in-buffer/entries-written: 1733/1733 #P:4
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/3:1-1221 [003] .... 214.435251: rtos_queue_peek_from_isr_failed: tstamp:7079274425 queue:0x0b4b4500
kworker/3:1-1221 [003] .... 214.603279: rtos_queue_peek_from_isr_failed: tstamp:7084274631 queue:0x0b4b4500
kworker/3:1-1221 [003] .... 214.771158: rtos_queue_peek_from_isr_failed: tstamp:7089274624 queue:0x0b4b4500
kworker/3:1-1221 [003] .... 214.883269: rtos_queue_peek_from_isr_failed: tstamp:7094274630 queue:0x0b4b4500
kworker/3:1-1221 [003] .... 215.051335: rtos_queue_peek_from_isr_failed: tstamp:7099274638 queue:0x0b4b4500
kworker/3:1-1221 [003] .... 215.219166: rtos_queue_peek_from_isr_failed: tstamp:7104274644 queue:0x0b4b4500
kworker/3:1-1221 [003] .... 215.387205: rtos_queue_peek_from_isr_failed: tstamp:7109274654 queue:0x0b4b4500
kworker/3:1-1221 [003] .... 215.555258: rtos_queue_peek_from_isr_failed: tstamp:7114274490 queue:0x0b4b4500
kworker/3:1-1221 [003] .... 215.723185: rtos_queue_peek_from_isr_failed: tstamp:7119274662 queue:0x0b4b4500
kworker/3:1-1221 [003] .... 215.891158: rtos_queue_peek_from_isr_failed: tstamp:7124274668 queue:0x0b4b4500
kworker/3:1-1221 [003] .... 216.003129: rtos_queue_peek_from_isr_failed: tstamp:7129274495 queue:0x0b4b4500
v4l2-ctl-8639 [005] .... 216.101275: tegra_channel_open: vi-output, crosslink 2-0037
v4l2-ctl-8639 [000] .... 216.105007: tegra_channel_set_power: crosslink 2-0037 : 0x1
v4l2-ctl-8639 [000] .... 216.105018: camera_common_s_power: status : 0x1
v4l2-ctl-8639 [000] .... 216.105052: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
v4l2-ctl-8639 [000] .... 216.105054: csi_s_power: enable : 0x1
v4l2-ctl-8639 [004] .... 216.115793: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 41
vi-output, cros-8640 [003] … 216.116110: tegra_channel_set_stream: enable : 0x1
vi-output, cros-8640 [000] … 216.117692: tegra_channel_set_stream: 150c0000.nvcsi–1 : 0x1
vi-output, cros-8640 [000] … 216.117695: csi_s_stream: enable : 0x1
vi-output, cros-8640 [000] … 216.117721: tegra_channel_set_stream: crosslink 2-0037 : 0x1
kworker/3:1-1221 [003] … 216.171036: rtos_queue_send_from_isr_failed: tstamp:7132887270 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.171040: rtos_queue_send_from_isr_failed: tstamp:7132887385 queue:0x0b4aad68
kworker/3:1-1221 [003] … 216.171041: rtos_queue_send_from_isr_failed: tstamp:7132887493 queue:0x0b4ac998
kworker/3:1-1221 [003] … 216.171042: rtos_queue_send_from_isr_failed: tstamp:7132887599 queue:0x0b4ae518
kworker/3:1-1221 [003] … 216.171043: rtos_queue_send_from_isr_failed: tstamp:7132887703 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 216.171044: rtos_queue_send_from_isr_failed: tstamp:7132887807 queue:0x0b4b0098
kworker/3:1-1221 [003] … 216.171045: rtos_queue_send_from_isr_failed: tstamp:7132887916 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 216.171045: rtos_queue_send_from_isr_failed: tstamp:7132888019 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 216.171047: rtos_queue_send_failed: tstamp:7132888489 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.171048: rtos_queue_send_from_isr_failed: tstamp:7132890377 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.171049: rtos_queue_send_from_isr_failed: tstamp:7132890482 queue:0x0b4aad68
kworker/3:1-1221 [003] … 216.171050: rtos_queue_send_from_isr_failed: tstamp:7132890587 queue:0x0b4ac998
kworker/3:1-1221 [003] … 216.171051: rtos_queue_send_from_isr_failed: tstamp:7132890693 queue:0x0b4ae518
kworker/3:1-1221 [003] … 216.171052: rtos_queue_send_from_isr_failed: tstamp:7132890797 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 216.171053: rtos_queue_send_from_isr_failed: tstamp:7132890902 queue:0x0b4b0098
kworker/3:1-1221 [003] … 216.171053: rtos_queue_send_from_isr_failed: tstamp:7132891007 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 216.171054: rtos_queue_send_from_isr_failed: tstamp:7132891112 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 216.171055: rtos_queue_send_failed: tstamp:7132892036 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.171057: rtos_queue_peek_from_isr_failed: tstamp:7134274457 queue:0x0b4b4500
kworker/3:1-1221 [003] … 216.343118: rtos_queue_peek_from_isr_failed: tstamp:7139274556 queue:0x0b4b4500
kworker/3:1-1221 [003] … 216.343130: rtos_queue_send_from_isr_failed: tstamp:7139768396 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.343132: rtos_queue_send_from_isr_failed: tstamp:7139768683 queue:0x0b4aad68
kworker/3:1-1221 [003] … 216.343135: rtos_queue_send_from_isr_failed: tstamp:7139768952 queue:0x0b4ac998
kworker/3:1-1221 [003] … 216.343137: rtos_queue_send_from_isr_failed: tstamp:7139769223 queue:0x0b4ae518
kworker/3:1-1221 [003] … 216.343140: rtos_queue_send_from_isr_failed: tstamp:7139769490 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 216.343142: rtos_queue_send_from_isr_failed: tstamp:7139769759 queue:0x0b4b0098
kworker/3:1-1221 [003] … 216.343143: rtos_queue_send_from_isr_failed: tstamp:7139770027 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 216.343145: rtos_queue_send_from_isr_failed: tstamp:7139770297 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 216.343149: rtos_queue_send_failed: tstamp:7139771801 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.343151: rtos_queue_send_from_isr_failed: tstamp:7139778308 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.343153: rtos_queue_send_from_isr_failed: tstamp:7139778575 queue:0x0b4aad68
kworker/3:1-1221 [003] … 216.343155: rtos_queue_send_from_isr_failed: tstamp:7139778841 queue:0x0b4ac998
kworker/3:1-1221 [003] … 216.343156: rtos_queue_send_from_isr_failed: tstamp:7139779108 queue:0x0b4ae518
kworker/3:1-1221 [003] … 216.343158: rtos_queue_send_from_isr_failed: tstamp:7139779372 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 216.343160: rtos_queue_send_from_isr_failed: tstamp:7139779638 queue:0x0b4b0098
kworker/3:1-1221 [003] … 216.343162: rtos_queue_send_from_isr_failed: tstamp:7139779904 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 216.343164: rtos_queue_send_from_isr_failed: tstamp:7139780167 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 216.343165: rtos_queue_send_failed: tstamp:7139781228 queue:0x0b4a7258
vi-output, cros-8640 [000] … 216.353344: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 41
vi-output, cros-8640 [000] … 216.353388: tegra_channel_capture_frame: sof:-549620695340.-269320296128
kworker/3:1-1221 [003] … 216.395101: rtos_queue_send_from_isr_failed: tstamp:7140306337 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.395110: rtos_queue_send_from_isr_failed: tstamp:7140306520 queue:0x0b4aad68
kworker/3:1-1221 [003] … 216.395113: rtos_queue_send_from_isr_failed: tstamp:7140306695 queue:0x0b4ac998
kworker/3:1-1221 [003] … 216.395116: rtos_queue_send_from_isr_failed: tstamp:7140306870 queue:0x0b4ae518
kworker/3:1-1221 [003] … 216.395119: rtos_queue_send_from_isr_failed: tstamp:7140307042 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 216.395121: rtos_queue_send_from_isr_failed: tstamp:7140307216 queue:0x0b4b0098
kworker/3:1-1221 [003] … 216.395124: rtos_queue_send_from_isr_failed: tstamp:7140307392 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 216.395128: rtos_queue_send_from_isr_failed: tstamp:7140307574 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 216.395134: rtos_queue_send_failed: tstamp:7140308360 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.395136: rtos_queue_send_from_isr_failed: tstamp:7140311809 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.395139: rtos_queue_send_from_isr_failed: tstamp:7140311984 queue:0x0b4aad68
kworker/3:1-1221 [003] … 216.395142: rtos_queue_send_from_isr_failed: tstamp:7140312159 queue:0x0b4ac998
kworker/3:1-1221 [003] … 216.395144: rtos_queue_send_from_isr_failed: tstamp:7140312334 queue:0x0b4ae518
kworker/3:1-1221 [003] … 216.395147: rtos_queue_send_from_isr_failed: tstamp:7140312507 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 216.395151: rtos_queue_send_from_isr_failed: tstamp:7140312680 queue:0x0b4b0098
kworker/3:1-1221 [003] … 216.395153: rtos_queue_send_from_isr_failed: tstamp:7140312854 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 216.395156: rtos_queue_send_from_isr_failed: tstamp:7140313028 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 216.395158: rtos_queue_send_failed: tstamp:7140314938 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.507133: rtos_queue_peek_from_isr_failed: tstamp:7144274630 queue:0x0b4b4500
vi-output, cros-8640 [005] … 216.588916: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 41
vi-output, cros-8640 [005] … 216.588974: tegra_channel_capture_frame: sof:-549620695340.-269320296128
kworker/3:1-1221 [003] … 216.619156: rtos_queue_send_from_isr_failed: tstamp:7147133371 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.619166: rtos_queue_send_from_isr_failed: tstamp:7147133659 queue:0x0b4aad68
kworker/3:1-1221 [003] … 216.619170: rtos_queue_send_from_isr_failed: tstamp:7147133930 queue:0x0b4ac998
kworker/3:1-1221 [003] … 216.619174: rtos_queue_send_from_isr_failed: tstamp:7147134258 queue:0x0b4ae518
kworker/3:1-1221 [003] … 216.619178: rtos_queue_send_from_isr_failed: tstamp:7147134538 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 216.619181: rtos_queue_send_from_isr_failed: tstamp:7147134802 queue:0x0b4b0098
kworker/3:1-1221 [003] … 216.619185: rtos_queue_send_from_isr_failed: tstamp:7147135067 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 216.619188: rtos_queue_send_from_isr_failed: tstamp:7147135333 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 216.619195: rtos_queue_send_failed: tstamp:7147136655 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.619198: rtos_queue_send_from_isr_failed: tstamp:7147141804 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.619202: rtos_queue_send_from_isr_failed: tstamp:7147142070 queue:0x0b4aad68
kworker/3:1-1221 [003] … 216.619205: rtos_queue_send_from_isr_failed: tstamp:7147142336 queue:0x0b4ac998
kworker/3:1-1221 [003] … 216.619209: rtos_queue_send_from_isr_failed: tstamp:7147142603 queue:0x0b4ae518
kworker/3:1-1221 [003] … 216.619212: rtos_queue_send_from_isr_failed: tstamp:7147142868 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 216.619215: rtos_queue_send_from_isr_failed: tstamp:7147143132 queue:0x0b4b0098
kworker/3:1-1221 [003] … 216.619219: rtos_queue_send_from_isr_failed: tstamp:7147143397 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 216.619222: rtos_queue_send_from_isr_failed: tstamp:7147143661 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 216.619225: rtos_queue_send_failed: tstamp:7147144792 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.619228: rtos_queue_send_from_isr_failed: tstamp:7147662839 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.619232: rtos_queue_send_from_isr_failed: tstamp:7147663121 queue:0x0b4aad68
kworker/3:1-1221 [003] … 216.619235: rtos_queue_send_from_isr_failed: tstamp:7147663401 queue:0x0b4ac998
kworker/3:1-1221 [003] … 216.619238: rtos_queue_send_from_isr_failed: tstamp:7147663669 queue:0x0b4ae518
kworker/3:1-1221 [003] … 216.619242: rtos_queue_send_from_isr_failed: tstamp:7147663936 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 216.619245: rtos_queue_send_from_isr_failed: tstamp:7147664202 queue:0x0b4b0098
kworker/3:1-1221 [003] … 216.619248: rtos_queue_send_from_isr_failed: tstamp:7147664469 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 216.619252: rtos_queue_send_from_isr_failed: tstamp:7147664738 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 216.619255: rtos_queue_send_failed: tstamp:7147665931 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.619258: rtos_queue_send_from_isr_failed: tstamp:7147670704 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.619262: rtos_queue_send_from_isr_failed: tstamp:7147670980 queue:0x0b4aad68
kworker/3:1-1221 [003] … 216.619265: rtos_queue_send_from_isr_failed: tstamp:7147671248 queue:0x0b4ac998
kworker/3:1-1221 [003] … 216.619268: rtos_queue_send_from_isr_failed: tstamp:7147671518 queue:0x0b4ae518
kworker/3:1-1221 [003] … 216.619272: rtos_queue_send_from_isr_failed: tstamp:7147671785 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 216.619275: rtos_queue_send_from_isr_failed: tstamp:7147672051 queue:0x0b4b0098
kworker/3:1-1221 [003] … 216.619278: rtos_queue_send_from_isr_failed: tstamp:7147672317 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 216.619282: rtos_queue_send_from_isr_failed: tstamp:7147672584 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 216.619285: rtos_queue_send_failed: tstamp:7147675863 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.675137: rtos_queue_peek_from_isr_failed: tstamp:7149274669 queue:0x0b4b4500
vi-output, cros-8640 [004] … 216.824303: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 41
vi-output, cros-8640 [004] … 216.824340: tegra_channel_capture_frame: sof:-549620695340.-269320296128
kworker/3:1-1221 [003] … 216.843142: rtos_queue_peek_from_isr_failed: tstamp:7154274542 queue:0x0b4b4500
kworker/3:1-1221 [003] … 216.843156: rtos_queue_send_from_isr_failed: tstamp:7154504688 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.843159: rtos_queue_send_from_isr_failed: tstamp:7154504873 queue:0x0b4aad68
kworker/3:1-1221 [003] … 216.843162: rtos_queue_send_from_isr_failed: tstamp:7154505051 queue:0x0b4ac998
kworker/3:1-1221 [003] … 216.843166: rtos_queue_send_from_isr_failed: tstamp:7154505227 queue:0x0b4ae518
kworker/3:1-1221 [003] … 216.843169: rtos_queue_send_from_isr_failed: tstamp:7154505401 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 216.843172: rtos_queue_send_from_isr_failed: tstamp:7154505575 queue:0x0b4b0098
kworker/3:1-1221 [003] … 216.843174: rtos_queue_send_from_isr_failed: tstamp:7154505749 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 216.843177: rtos_queue_send_from_isr_failed: tstamp:7154505922 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 216.843184: rtos_queue_send_failed: tstamp:7154506874 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.843187: rtos_queue_send_from_isr_failed: tstamp:7154510664 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.843189: rtos_queue_send_from_isr_failed: tstamp:7154510841 queue:0x0b4aad68
kworker/3:1-1221 [003] … 216.843192: rtos_queue_send_from_isr_failed: tstamp:7154511016 queue:0x0b4ac998
kworker/3:1-1221 [003] … 216.843194: rtos_queue_send_from_isr_failed: tstamp:7154511192 queue:0x0b4ae518
kworker/3:1-1221 [003] … 216.843197: rtos_queue_send_from_isr_failed: tstamp:7154511366 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 216.843199: rtos_queue_send_from_isr_failed: tstamp:7154511545 queue:0x0b4b0098
kworker/3:1-1221 [003] … 216.843202: rtos_queue_send_from_isr_failed: tstamp:7154511717 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 216.843204: rtos_queue_send_from_isr_failed: tstamp:7154511891 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 216.843207: rtos_queue_send_failed: tstamp:7154512595 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.843209: rtos_queue_send_from_isr_failed: tstamp:7155027119 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.843212: rtos_queue_send_from_isr_failed: tstamp:7155027262 queue:0x0b4aad68
kworker/3:1-1221 [003] … 216.843215: rtos_queue_send_from_isr_failed: tstamp:7155027401 queue:0x0b4ac998
kworker/3:1-1221 [003] … 216.843217: rtos_queue_send_from_isr_failed: tstamp:7155027542 queue:0x0b4ae518
kworker/3:1-1221 [003] … 216.843220: rtos_queue_send_from_isr_failed: tstamp:7155027679 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 216.843222: rtos_queue_send_from_isr_failed: tstamp:7155027817 queue:0x0b4b0098
kworker/3:1-1221 [003] … 216.843225: rtos_queue_send_from_isr_failed: tstamp:7155027954 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 216.843227: rtos_queue_send_from_isr_failed: tstamp:7155028092 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 216.843230: rtos_queue_send_failed: tstamp:7155028682 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.843232: rtos_queue_send_from_isr_failed: tstamp:7155030720 queue:0x0b4a7258
kworker/3:1-1221 [003] … 216.843235: rtos_queue_send_from_isr_failed: tstamp:7155030865 queue:0x0b4aad68
kworker/3:1-1221 [003] … 216.843237: rtos_queue_send_from_isr_failed: tstamp:7155031004 queue:0x0b4ac998
kworker/3:1-1221 [003] … 216.843240: rtos_queue_send_from_isr_failed: tstamp:7155031149 queue:0x0b4ae518
kworker/3:1-1221 [003] … 216.843242: rtos_queue_send_from_isr_failed: tstamp:7155031287 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 216.843244: rtos_queue_send_from_isr_failed: tstamp:7155031424 queue:0x0b4b0098
kworker/3:1-1221 [003] … 216.843247: rtos_queue_send_from_isr_failed: tstamp:7155031562 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 216.843249: rtos_queue_send_from_isr_failed: tstamp:7155031698 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 216.843256: rtos_queue_send_failed: tstamp:7155033094 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.011140: rtos_queue_peek_from_isr_failed: tstamp:7159274596 queue:0x0b4b4500
vi-output, cros-8640 [004] … 217.061099: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 41
vi-output, cros-8640 [004] … 217.061146: tegra_channel_capture_frame: sof:-549620695340.-269320296128
kworker/3:1-1221 [003] … 217.067048: rtos_queue_send_from_isr_failed: tstamp:7161901208 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.067052: rtos_queue_send_from_isr_failed: tstamp:7161901355 queue:0x0b4aad68
kworker/3:1-1221 [003] … 217.067053: rtos_queue_send_from_isr_failed: tstamp:7161901495 queue:0x0b4ac998
kworker/3:1-1221 [003] … 217.067054: rtos_queue_send_from_isr_failed: tstamp:7161901635 queue:0x0b4ae518
kworker/3:1-1221 [003] … 217.067055: rtos_queue_send_from_isr_failed: tstamp:7161901772 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 217.067056: rtos_queue_send_from_isr_failed: tstamp:7161901910 queue:0x0b4b0098
kworker/3:1-1221 [003] … 217.067058: rtos_queue_send_from_isr_failed: tstamp:7161902049 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 217.067059: rtos_queue_send_from_isr_failed: tstamp:7161902186 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 217.067061: rtos_queue_send_failed: tstamp:7161902923 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.067062: rtos_queue_send_from_isr_failed: tstamp:7161905172 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.067064: rtos_queue_send_from_isr_failed: tstamp:7161905312 queue:0x0b4aad68
kworker/3:1-1221 [003] … 217.067065: rtos_queue_send_from_isr_failed: tstamp:7161905451 queue:0x0b4ac998
kworker/3:1-1221 [003] … 217.067066: rtos_queue_send_from_isr_failed: tstamp:7161905590 queue:0x0b4ae518
kworker/3:1-1221 [003] … 217.067067: rtos_queue_send_from_isr_failed: tstamp:7161905726 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 217.067068: rtos_queue_send_from_isr_failed: tstamp:7161905862 queue:0x0b4b0098
kworker/3:1-1221 [003] … 217.067070: rtos_queue_send_from_isr_failed: tstamp:7161905998 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 217.067071: rtos_queue_send_from_isr_failed: tstamp:7161906136 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 217.067072: rtos_queue_send_failed: tstamp:7161906698 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.067073: rtos_queue_send_from_isr_failed: tstamp:7162420215 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.067074: rtos_queue_send_from_isr_failed: tstamp:7162420323 queue:0x0b4aad68
kworker/3:1-1221 [003] … 217.067075: rtos_queue_send_from_isr_failed: tstamp:7162420429 queue:0x0b4ac998
kworker/3:1-1221 [003] … 217.067077: rtos_queue_send_from_isr_failed: tstamp:7162420537 queue:0x0b4ae518
kworker/3:1-1221 [003] … 217.067078: rtos_queue_send_from_isr_failed: tstamp:7162420642 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 217.067079: rtos_queue_send_from_isr_failed: tstamp:7162420746 queue:0x0b4b0098
kworker/3:1-1221 [003] … 217.067080: rtos_queue_send_from_isr_failed: tstamp:7162420849 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 217.067081: rtos_queue_send_from_isr_failed: tstamp:7162420959 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 217.067082: rtos_queue_send_failed: tstamp:7162421452 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.067084: rtos_queue_send_from_isr_failed: tstamp:7162427839 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.067085: rtos_queue_send_from_isr_failed: tstamp:7162427945 queue:0x0b4aad68
kworker/3:1-1221 [003] … 217.067086: rtos_queue_send_from_isr_failed: tstamp:7162428050 queue:0x0b4ac998
kworker/3:1-1221 [003] … 217.067087: rtos_queue_send_from_isr_failed: tstamp:7162428155 queue:0x0b4ae518
kworker/3:1-1221 [003] … 217.067088: rtos_queue_send_from_isr_failed: tstamp:7162428260 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 217.067090: rtos_queue_send_from_isr_failed: tstamp:7162428365 queue:0x0b4b0098
kworker/3:1-1221 [003] … 217.067091: rtos_queue_send_from_isr_failed: tstamp:7162428470 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 217.067092: rtos_queue_send_from_isr_failed: tstamp:7162428575 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 217.067093: rtos_queue_send_failed: tstamp:7162429494 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.123232: rtos_queue_peek_from_isr_failed: tstamp:7164274656 queue:0x0b4b4500
kworker/3:1-1221 [003] … 217.291064: rtos_queue_send_from_isr_failed: tstamp:7169263601 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.291070: rtos_queue_send_from_isr_failed: tstamp:7169263887 queue:0x0b4aad68
kworker/3:1-1221 [003] … 217.291072: rtos_queue_send_from_isr_failed: tstamp:7169264159 queue:0x0b4ac998
kworker/3:1-1221 [003] … 217.291073: rtos_queue_send_from_isr_failed: tstamp:7169264429 queue:0x0b4ae518
kworker/3:1-1221 [003] … 217.291074: rtos_queue_send_from_isr_failed: tstamp:7169264708 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 217.291075: rtos_queue_send_from_isr_failed: tstamp:7169264977 queue:0x0b4b0098
kworker/3:1-1221 [003] … 217.291076: rtos_queue_send_from_isr_failed: tstamp:7169265244 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 217.291077: rtos_queue_send_from_isr_failed: tstamp:7169265510 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 217.291080: rtos_queue_send_failed: tstamp:7169266903 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.291083: rtos_queue_peek_from_isr_failed: tstamp:7169274582 queue:0x0b4b4500
kworker/3:1-1221 [003] … 217.291084: rtos_queue_send_from_isr_failed: tstamp:7169274896 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.291085: rtos_queue_send_from_isr_failed: tstamp:7169275166 queue:0x0b4aad68
kworker/3:1-1221 [003] … 217.291086: rtos_queue_send_from_isr_failed: tstamp:7169275432 queue:0x0b4ac998
kworker/3:1-1221 [003] … 217.291087: rtos_queue_send_from_isr_failed: tstamp:7169275700 queue:0x0b4ae518
kworker/3:1-1221 [003] … 217.291088: rtos_queue_send_from_isr_failed: tstamp:7169275965 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 217.291090: rtos_queue_send_from_isr_failed: tstamp:7169276230 queue:0x0b4b0098
kworker/3:1-1221 [003] … 217.291091: rtos_queue_send_from_isr_failed: tstamp:7169276496 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 217.291092: rtos_queue_send_from_isr_failed: tstamp:7169276760 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 217.291093: rtos_queue_send_failed: tstamp:7169277961 queue:0x0b4a7258
vi-output, cros-8640 [005] … 217.297671: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 41
vi-output, cros-8640 [005] … 217.297750: tegra_channel_capture_frame: sof:-549620695340.-269320296128
kworker/3:1-1221 [003] … 217.347162: rtos_queue_send_from_isr_failed: tstamp:7169796636 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.347179: rtos_queue_send_from_isr_failed: tstamp:7169796819 queue:0x0b4aad68
kworker/3:1-1221 [003] … 217.347184: rtos_queue_send_from_isr_failed: tstamp:7169796994 queue:0x0b4ac998
kworker/3:1-1221 [003] … 217.347187: rtos_queue_send_from_isr_failed: tstamp:7169797169 queue:0x0b4ae518
kworker/3:1-1221 [003] … 217.347190: rtos_queue_send_from_isr_failed: tstamp:7169797343 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 217.347194: rtos_queue_send_from_isr_failed: tstamp:7169797516 queue:0x0b4b0098
kworker/3:1-1221 [003] … 217.347198: rtos_queue_send_from_isr_failed: tstamp:7169797693 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 217.347202: rtos_queue_send_from_isr_failed: tstamp:7169797865 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 217.347209: rtos_queue_send_failed: tstamp:7169798604 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.347213: rtos_queue_send_from_isr_failed: tstamp:7169812857 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.347216: rtos_queue_send_from_isr_failed: tstamp:7169813128 queue:0x0b4aad68
kworker/3:1-1221 [003] … 217.347219: rtos_queue_send_from_isr_failed: tstamp:7169813399 queue:0x0b4ac998
kworker/3:1-1221 [003] … 217.347223: rtos_queue_send_from_isr_failed: tstamp:7169813668 queue:0x0b4ae518
kworker/3:1-1221 [003] … 217.347226: rtos_queue_send_from_isr_failed: tstamp:7169813935 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 217.347230: rtos_queue_send_from_isr_failed: tstamp:7169814211 queue:0x0b4b0098
kworker/3:1-1221 [003] … 217.347233: rtos_queue_send_from_isr_failed: tstamp:7169814478 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 217.347236: rtos_queue_send_from_isr_failed: tstamp:7169814748 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 217.347239: rtos_queue_send_failed: tstamp:7169817992 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.459168: rtos_queue_peek_from_isr_failed: tstamp:7174274666 queue:0x0b4b4500
vi-output, cros-8640 [004] … 217.516880: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 41
vi-output, cros-8640 [004] … 217.516947: tegra_channel_capture_frame: sof:-549620695340.-269320296128
kworker/3:1-1221 [003] … 217.571269: rtos_queue_send_from_isr_failed: tstamp:7176633705 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.571281: rtos_queue_send_from_isr_failed: tstamp:7176633989 queue:0x0b4aad68
kworker/3:1-1221 [003] … 217.571285: rtos_queue_send_from_isr_failed: tstamp:7176634258 queue:0x0b4ac998
kworker/3:1-1221 [003] … 217.571289: rtos_queue_send_from_isr_failed: tstamp:7176634527 queue:0x0b4ae518
kworker/3:1-1221 [003] … 217.571292: rtos_queue_send_from_isr_failed: tstamp:7176634791 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 217.571295: rtos_queue_send_from_isr_failed: tstamp:7176635057 queue:0x0b4b0098
kworker/3:1-1221 [003] … 217.571299: rtos_queue_send_from_isr_failed: tstamp:7176635327 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 217.571302: rtos_queue_send_from_isr_failed: tstamp:7176635593 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 217.571310: rtos_queue_send_failed: tstamp:7176636887 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.571313: rtos_queue_send_from_isr_failed: tstamp:7176644575 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.571317: rtos_queue_send_from_isr_failed: tstamp:7176644842 queue:0x0b4aad68
kworker/3:1-1221 [003] … 217.571320: rtos_queue_send_from_isr_failed: tstamp:7176645114 queue:0x0b4ac998
kworker/3:1-1221 [003] … 217.571324: rtos_queue_send_from_isr_failed: tstamp:7176645382 queue:0x0b4ae518
kworker/3:1-1221 [003] … 217.571327: rtos_queue_send_from_isr_failed: tstamp:7176645647 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 217.571331: rtos_queue_send_from_isr_failed: tstamp:7176645979 queue:0x0b4b0098
kworker/3:1-1221 [003] … 217.571334: rtos_queue_send_from_isr_failed: tstamp:7176646245 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 217.571337: rtos_queue_send_from_isr_failed: tstamp:7176646513 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 217.571340: rtos_queue_send_failed: tstamp:7176647588 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.571344: rtos_queue_send_from_isr_failed: tstamp:7176658567 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.571347: rtos_queue_send_from_isr_failed: tstamp:7176658834 queue:0x0b4aad68
kworker/3:1-1221 [003] … 217.571350: rtos_queue_send_from_isr_failed: tstamp:7176659102 queue:0x0b4ac998
kworker/3:1-1221 [003] … 217.571354: rtos_queue_send_from_isr_failed: tstamp:7176659370 queue:0x0b4ae518
kworker/3:1-1221 [003] … 217.571357: rtos_queue_send_from_isr_failed: tstamp:7176659636 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 217.571360: rtos_queue_send_from_isr_failed: tstamp:7176659904 queue:0x0b4b0098
kworker/3:1-1221 [003] … 217.571364: rtos_queue_send_from_isr_failed: tstamp:7176660170 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 217.571367: rtos_queue_send_from_isr_failed: tstamp:7176660436 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 217.571370: rtos_queue_send_failed: tstamp:7176661507 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.571374: rtos_queue_send_from_isr_failed: tstamp:7176667571 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.571377: rtos_queue_send_from_isr_failed: tstamp:7176667839 queue:0x0b4aad68
kworker/3:1-1221 [003] … 217.571380: rtos_queue_send_from_isr_failed: tstamp:7176668107 queue:0x0b4ac998
kworker/3:1-1221 [003] … 217.571383: rtos_queue_send_from_isr_failed: tstamp:7176668375 queue:0x0b4ae518
kworker/3:1-1221 [003] … 217.571387: rtos_queue_send_from_isr_failed: tstamp:7176668641 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 217.571390: rtos_queue_send_from_isr_failed: tstamp:7176668911 queue:0x0b4b0098
kworker/3:1-1221 [003] … 217.571394: rtos_queue_send_from_isr_failed: tstamp:7176669178 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 217.571397: rtos_queue_send_from_isr_failed: tstamp:7176669444 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 217.571400: rtos_queue_send_failed: tstamp:7176672688 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.627291: rtos_queue_peek_from_isr_failed: tstamp:7179274665 queue:0x0b4b4500
kworker/3:1-1221 [003] … 217.743076: rtos_queue_send_from_isr_failed: tstamp:7183527488 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.743082: rtos_queue_send_from_isr_failed: tstamp:7183527772 queue:0x0b4aad68
kworker/3:1-1221 [003] … 217.743084: rtos_queue_send_from_isr_failed: tstamp:7183528040 queue:0x0b4ac998
kworker/3:1-1221 [003] … 217.743085: rtos_queue_send_from_isr_failed: tstamp:7183528309 queue:0x0b4ae518
kworker/3:1-1221 [003] … 217.743087: rtos_queue_send_from_isr_failed: tstamp:7183528573 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 217.743088: rtos_queue_send_from_isr_failed: tstamp:7183528839 queue:0x0b4b0098
kworker/3:1-1221 [003] … 217.743090: rtos_queue_send_from_isr_failed: tstamp:7183529110 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 217.743092: rtos_queue_send_from_isr_failed: tstamp:7183529433 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 217.743094: rtos_queue_send_failed: tstamp:7183530740 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.743096: rtos_queue_send_from_isr_failed: tstamp:7183536602 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.743097: rtos_queue_send_from_isr_failed: tstamp:7183536868 queue:0x0b4aad68
kworker/3:1-1221 [003] … 217.743099: rtos_queue_send_from_isr_failed: tstamp:7183537134 queue:0x0b4ac998
kworker/3:1-1221 [003] … 217.743101: rtos_queue_send_from_isr_failed: tstamp:7183537401 queue:0x0b4ae518
kworker/3:1-1221 [003] … 217.743102: rtos_queue_send_from_isr_failed: tstamp:7183537665 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 217.743104: rtos_queue_send_from_isr_failed: tstamp:7183537930 queue:0x0b4b0098
kworker/3:1-1221 [003] … 217.743105: rtos_queue_send_from_isr_failed: tstamp:7183538196 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 217.743107: rtos_queue_send_from_isr_failed: tstamp:7183538460 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 217.743108: rtos_queue_send_failed: tstamp:7183539526 queue:0x0b4a7258
vi-output, cros-8640 [004] … 217.753294: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 41
vi-output, cros-8640 [004] … 217.753329: tegra_channel_capture_frame: sof:-549620695340.-269320296128
kworker/3:1-1221 [003] … 217.799287: rtos_queue_send_from_isr_failed: tstamp:7184057499 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.799296: rtos_queue_send_from_isr_failed: tstamp:7184057642 queue:0x0b4aad68
kworker/3:1-1221 [003] … 217.799300: rtos_queue_send_from_isr_failed: tstamp:7184057787 queue:0x0b4ac998
kworker/3:1-1221 [003] … 217.799303: rtos_queue_send_from_isr_failed: tstamp:7184057929 queue:0x0b4ae518
kworker/3:1-1221 [003] … 217.799306: rtos_queue_send_from_isr_failed: tstamp:7184058066 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 217.799310: rtos_queue_send_from_isr_failed: tstamp:7184058204 queue:0x0b4b0098
kworker/3:1-1221 [003] … 217.799313: rtos_queue_send_from_isr_failed: tstamp:7184058340 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 217.799316: rtos_queue_send_from_isr_failed: tstamp:7184058481 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 217.799322: rtos_queue_send_failed: tstamp:7184059087 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.799326: rtos_queue_send_from_isr_failed: tstamp:7184061675 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.799329: rtos_queue_send_from_isr_failed: tstamp:7184061815 queue:0x0b4aad68
kworker/3:1-1221 [003] … 217.799332: rtos_queue_send_from_isr_failed: tstamp:7184061952 queue:0x0b4ac998
kworker/3:1-1221 [003] … 217.799336: rtos_queue_send_from_isr_failed: tstamp:7184062091 queue:0x0b4ae518
kworker/3:1-1221 [003] … 217.799344: rtos_queue_send_from_isr_failed: tstamp:7184062227 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 217.799348: rtos_queue_send_from_isr_failed: tstamp:7184062365 queue:0x0b4b0098
kworker/3:1-1221 [003] … 217.799352: rtos_queue_send_from_isr_failed: tstamp:7184062504 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 217.799355: rtos_queue_send_from_isr_failed: tstamp:7184062641 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 217.799359: rtos_queue_send_failed: tstamp:7184064005 queue:0x0b4a7258
kworker/3:1-1221 [003] … 217.799366: rtos_queue_peek_from_isr_failed: tstamp:7184274557 queue:0x0b4b4500
kworker/3:1-1221 [003] … 217.967115: rtos_queue_peek_from_isr_failed: tstamp:7189274636 queue:0x0b4b4500
vi-output, cros-8640 [004] … 217.990473: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 41
vi-output, cros-8640 [004] … 217.990534: tegra_channel_capture_frame: sof:-549620695340.-269320296128
kworker/3:1-1221 [003] … 218.023169: rtos_queue_send_from_isr_failed: tstamp:7190890746 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.023177: rtos_queue_send_from_isr_failed: tstamp:7190891091 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.023181: rtos_queue_send_from_isr_failed: tstamp:7190891359 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.023184: rtos_queue_send_from_isr_failed: tstamp:7190891657 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.023188: rtos_queue_send_from_isr_failed: tstamp:7190891923 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.023191: rtos_queue_send_from_isr_failed: tstamp:7190892188 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.023194: rtos_queue_send_from_isr_failed: tstamp:7190892463 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.023198: rtos_queue_send_from_isr_failed: tstamp:7190892727 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.023206: rtos_queue_send_failed: tstamp:7190894033 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.023209: rtos_queue_send_from_isr_failed: tstamp:7190901686 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.023212: rtos_queue_send_from_isr_failed: tstamp:7190901952 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.023216: rtos_queue_send_from_isr_failed: tstamp:7190902219 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.023219: rtos_queue_send_from_isr_failed: tstamp:7190902492 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.023222: rtos_queue_send_from_isr_failed: tstamp:7190902761 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.023226: rtos_queue_send_from_isr_failed: tstamp:7190903027 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.023229: rtos_queue_send_from_isr_failed: tstamp:7190903292 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.023233: rtos_queue_send_from_isr_failed: tstamp:7190903558 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.023236: rtos_queue_send_failed: tstamp:7190904641 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.023240: rtos_queue_send_from_isr_failed: tstamp:7191461708 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.023243: rtos_queue_send_from_isr_failed: tstamp:7191462002 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.023246: rtos_queue_send_from_isr_failed: tstamp:7191462271 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.023250: rtos_queue_send_from_isr_failed: tstamp:7191462540 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.023253: rtos_queue_send_from_isr_failed: tstamp:7191462809 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.023256: rtos_queue_send_from_isr_failed: tstamp:7191463076 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.023260: rtos_queue_send_from_isr_failed: tstamp:7191463343 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.023263: rtos_queue_send_from_isr_failed: tstamp:7191463610 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.023266: rtos_queue_send_failed: tstamp:7191464837 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.023270: rtos_queue_send_from_isr_failed: tstamp:7191469427 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.023273: rtos_queue_send_from_isr_failed: tstamp:7191469697 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.023276: rtos_queue_send_from_isr_failed: tstamp:7191469964 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.023280: rtos_queue_send_from_isr_failed: tstamp:7191470231 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.023283: rtos_queue_send_from_isr_failed: tstamp:7191470497 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.023286: rtos_queue_send_from_isr_failed: tstamp:7191470763 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.023289: rtos_queue_send_from_isr_failed: tstamp:7191471030 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.023293: rtos_queue_send_from_isr_failed: tstamp:7191471296 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.023296: rtos_queue_send_failed: tstamp:7191474571 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.135149: rtos_queue_peek_from_isr_failed: tstamp:7194274713 queue:0x0b4b4500
vi-output, cros-8640 [004] … 218.226559: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 41
vi-output, cros-8640 [004] … 218.226619: tegra_channel_capture_frame: sof:-549620695340.-269320296128
kworker/3:1-1221 [003] … 218.247126: rtos_queue_send_from_isr_failed: tstamp:7198319663 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.247136: rtos_queue_send_from_isr_failed: tstamp:7198319808 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.247141: rtos_queue_send_from_isr_failed: tstamp:7198319948 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.247144: rtos_queue_send_from_isr_failed: tstamp:7198320089 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.247147: rtos_queue_send_from_isr_failed: tstamp:7198320225 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.247151: rtos_queue_send_from_isr_failed: tstamp:7198320361 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.247154: rtos_queue_send_from_isr_failed: tstamp:7198320499 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.247157: rtos_queue_send_from_isr_failed: tstamp:7198320636 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.247165: rtos_queue_send_failed: tstamp:7198321368 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.247168: rtos_queue_send_from_isr_failed: tstamp:7198324427 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.247171: rtos_queue_send_from_isr_failed: tstamp:7198324565 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.247174: rtos_queue_send_from_isr_failed: tstamp:7198324704 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.247178: rtos_queue_send_from_isr_failed: tstamp:7198324843 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.247181: rtos_queue_send_from_isr_failed: tstamp:7198324980 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.247185: rtos_queue_send_from_isr_failed: tstamp:7198325122 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.247188: rtos_queue_send_from_isr_failed: tstamp:7198325259 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.247191: rtos_queue_send_from_isr_failed: tstamp:7198325396 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.247194: rtos_queue_send_failed: tstamp:7198325948 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.247198: rtos_queue_send_from_isr_failed: tstamp:7198841238 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.247201: rtos_queue_send_from_isr_failed: tstamp:7198841520 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.247205: rtos_queue_send_from_isr_failed: tstamp:7198841788 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.247208: rtos_queue_send_from_isr_failed: tstamp:7198842058 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.247212: rtos_queue_send_from_isr_failed: tstamp:7198842323 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.247215: rtos_queue_send_from_isr_failed: tstamp:7198842591 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.247218: rtos_queue_send_from_isr_failed: tstamp:7198842859 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.247222: rtos_queue_send_from_isr_failed: tstamp:7198843126 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.247225: rtos_queue_send_failed: tstamp:7198844333 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.247228: rtos_queue_send_from_isr_failed: tstamp:7198847453 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.247232: rtos_queue_send_from_isr_failed: tstamp:7198847722 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.247235: rtos_queue_send_from_isr_failed: tstamp:7198848000 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.247238: rtos_queue_send_from_isr_failed: tstamp:7198848334 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.247242: rtos_queue_send_from_isr_failed: tstamp:7198848599 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.247245: rtos_queue_send_from_isr_failed: tstamp:7198848865 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.247248: rtos_queue_send_from_isr_failed: tstamp:7198849134 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.247252: rtos_queue_send_from_isr_failed: tstamp:7198849401 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.247255: rtos_queue_send_failed: tstamp:7198852535 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.247260: rtos_queue_peek_from_isr_failed: tstamp:7199274590 queue:0x0b4b4500
kworker/3:1-1221 [003] … 218.415191: rtos_queue_peek_from_isr_failed: tstamp:7204274657 queue:0x0b4b4500
vi-output, cros-8640 [004] … 218.469660: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 41
vi-output, cros-8640 [004] … 218.469704: tegra_channel_capture_frame: sof:-549620695340.-269320296128
kworker/3:1-1221 [003] … 218.471046: rtos_queue_send_from_isr_failed: tstamp:7205634367 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.471050: rtos_queue_send_from_isr_failed: tstamp:7205634551 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.471051: rtos_queue_send_from_isr_failed: tstamp:7205634728 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.471053: rtos_queue_send_from_isr_failed: tstamp:7205634903 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.471054: rtos_queue_send_from_isr_failed: tstamp:7205635077 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.471055: rtos_queue_send_from_isr_failed: tstamp:7205635251 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.471057: rtos_queue_send_from_isr_failed: tstamp:7205635424 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.471059: rtos_queue_send_from_isr_failed: tstamp:7205635597 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.471062: rtos_queue_send_failed: tstamp:7205636491 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.471063: rtos_queue_send_from_isr_failed: tstamp:7205643852 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.471064: rtos_queue_send_from_isr_failed: tstamp:7205644029 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.471066: rtos_queue_send_from_isr_failed: tstamp:7205644203 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.471067: rtos_queue_send_from_isr_failed: tstamp:7205644385 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.471068: rtos_queue_send_from_isr_failed: tstamp:7205644557 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.471069: rtos_queue_send_from_isr_failed: tstamp:7205644731 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.471071: rtos_queue_send_from_isr_failed: tstamp:7205644903 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.471072: rtos_queue_send_from_isr_failed: tstamp:7205645076 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.471073: rtos_queue_send_failed: tstamp:7205645771 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.471074: rtos_queue_send_from_isr_failed: tstamp:7206441996 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.471076: rtos_queue_send_from_isr_failed: tstamp:7206442177 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.471077: rtos_queue_send_from_isr_failed: tstamp:7206442351 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.471078: rtos_queue_send_from_isr_failed: tstamp:7206442526 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.471079: rtos_queue_send_from_isr_failed: tstamp:7206442699 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.471081: rtos_queue_send_from_isr_failed: tstamp:7206442901 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.471082: rtos_queue_send_from_isr_failed: tstamp:7206443081 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.471083: rtos_queue_send_from_isr_failed: tstamp:7206443255 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.471084: rtos_queue_send_failed: tstamp:7206443994 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.471085: rtos_queue_send_from_isr_failed: tstamp:7206446669 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.471086: rtos_queue_send_from_isr_failed: tstamp:7206446844 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.471087: rtos_queue_send_from_isr_failed: tstamp:7206447054 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.471089: rtos_queue_send_from_isr_failed: tstamp:7206447228 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.471090: rtos_queue_send_from_isr_failed: tstamp:7206447404 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.471091: rtos_queue_send_from_isr_failed: tstamp:7206447578 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.471092: rtos_queue_send_from_isr_failed: tstamp:7206447752 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.471093: rtos_queue_send_from_isr_failed: tstamp:7206447927 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.471094: rtos_queue_send_failed: tstamp:7206449839 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.583173: rtos_queue_peek_from_isr_failed: tstamp:7209274704 queue:0x0b4b4500
kworker/3:1-1221 [003] … 218.699082: rtos_queue_send_from_isr_failed: tstamp:7213258121 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.699093: rtos_queue_send_from_isr_failed: tstamp:7213258407 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.699096: rtos_queue_send_from_isr_failed: tstamp:7213258678 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.699098: rtos_queue_send_from_isr_failed: tstamp:7213258961 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.699101: rtos_queue_send_from_isr_failed: tstamp:7213259228 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.699103: rtos_queue_send_from_isr_failed: tstamp:7213259498 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.699106: rtos_queue_send_from_isr_failed: tstamp:7213259764 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.699108: rtos_queue_send_from_isr_failed: tstamp:7213260029 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.699114: rtos_queue_send_failed: tstamp:7213261373 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.699117: rtos_queue_send_from_isr_failed: tstamp:7213267916 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.699120: rtos_queue_send_from_isr_failed: tstamp:7213268184 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.699122: rtos_queue_send_from_isr_failed: tstamp:7213268451 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.699124: rtos_queue_send_from_isr_failed: tstamp:7213268720 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.699127: rtos_queue_send_from_isr_failed: tstamp:7213268984 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.699129: rtos_queue_send_from_isr_failed: tstamp:7213269258 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.699131: rtos_queue_send_from_isr_failed: tstamp:7213269525 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.699134: rtos_queue_send_from_isr_failed: tstamp:7213269791 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.699136: rtos_queue_send_failed: tstamp:7213270866 queue:0x0b4a7258
vi-output, cros-8640 [004] … 218.714195: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 41
vi-output, cros-8640 [004] … 218.714253: tegra_channel_capture_frame: sof:-549620695340.-269320296128
kworker/3:1-1221 [003] … 218.751131: rtos_queue_send_from_isr_failed: tstamp:7214078570 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.751140: rtos_queue_send_from_isr_failed: tstamp:7214078905 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.751144: rtos_queue_send_from_isr_failed: tstamp:7214079172 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.751147: rtos_queue_send_from_isr_failed: tstamp:7214079443 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.751151: rtos_queue_send_from_isr_failed: tstamp:7214079710 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.751154: rtos_queue_send_from_isr_failed: tstamp:7214079978 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.751157: rtos_queue_send_from_isr_failed: tstamp:7214080245 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.751161: rtos_queue_send_from_isr_failed: tstamp:7214080514 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.751170: rtos_queue_send_failed: tstamp:7214081717 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.751174: rtos_queue_send_from_isr_failed: tstamp:7214086062 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.751178: rtos_queue_send_from_isr_failed: tstamp:7214086332 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.751182: rtos_queue_send_from_isr_failed: tstamp:7214086600 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.751185: rtos_queue_send_from_isr_failed: tstamp:7214086868 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.751190: rtos_queue_send_from_isr_failed: tstamp:7214087136 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.751193: rtos_queue_send_from_isr_failed: tstamp:7214087403 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.751196: rtos_queue_send_from_isr_failed: tstamp:7214087670 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.751200: rtos_queue_send_from_isr_failed: tstamp:7214087940 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.751203: rtos_queue_send_failed: tstamp:7214091245 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.751209: rtos_queue_peek_from_isr_failed: tstamp:7214274610 queue:0x0b4b4500
kworker/3:1-1221 [003] … 218.919153: rtos_queue_peek_from_isr_failed: tstamp:7219274688 queue:0x0b4b4500
vi-output, cros-8640 [004] … 218.942032: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 41
vi-output, cros-8640 [004] … 218.942076: tegra_channel_capture_frame: sof:-549620695340.-269320296128
kworker/3:1-1221 [003] … 218.975144: rtos_queue_send_from_isr_failed: tstamp:7220902115 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.975152: rtos_queue_send_from_isr_failed: tstamp:7220902298 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.975156: rtos_queue_send_from_isr_failed: tstamp:7220902473 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.975160: rtos_queue_send_from_isr_failed: tstamp:7220902648 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.975163: rtos_queue_send_from_isr_failed: tstamp:7220902820 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.975167: rtos_queue_send_from_isr_failed: tstamp:7220902994 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.975170: rtos_queue_send_from_isr_failed: tstamp:7220903168 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.975173: rtos_queue_send_from_isr_failed: tstamp:7220903348 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.975181: rtos_queue_send_failed: tstamp:7220904235 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.975184: rtos_queue_send_from_isr_failed: tstamp:7220910494 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.975188: rtos_queue_send_from_isr_failed: tstamp:7220910669 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.975191: rtos_queue_send_from_isr_failed: tstamp:7220910872 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.975195: rtos_queue_send_from_isr_failed: tstamp:7220911149 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.975198: rtos_queue_send_from_isr_failed: tstamp:7220911426 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.975201: rtos_queue_send_from_isr_failed: tstamp:7220911693 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.975204: rtos_queue_send_from_isr_failed: tstamp:7220911960 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.975208: rtos_queue_send_from_isr_failed: tstamp:7220912228 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.975211: rtos_queue_send_failed: tstamp:7220913384 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.975214: rtos_queue_send_from_isr_failed: tstamp:7221202324 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.975218: rtos_queue_send_from_isr_failed: tstamp:7221202507 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.975221: rtos_queue_send_from_isr_failed: tstamp:7221202682 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.975224: rtos_queue_send_from_isr_failed: tstamp:7221202858 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.975228: rtos_queue_send_from_isr_failed: tstamp:7221203032 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.975231: rtos_queue_send_from_isr_failed: tstamp:7221203206 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.975234: rtos_queue_send_from_isr_failed: tstamp:7221203380 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.975238: rtos_queue_send_from_isr_failed: tstamp:7221203553 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.975241: rtos_queue_send_failed: tstamp:7221204361 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.975244: rtos_queue_send_from_isr_failed: tstamp:7221207888 queue:0x0b4a7258
kworker/3:1-1221 [003] … 218.975248: rtos_queue_send_from_isr_failed: tstamp:7221208065 queue:0x0b4aad68
kworker/3:1-1221 [003] … 218.975251: rtos_queue_send_from_isr_failed: tstamp:7221208246 queue:0x0b4ac998
kworker/3:1-1221 [003] … 218.975254: rtos_queue_send_from_isr_failed: tstamp:7221208420 queue:0x0b4ae518
kworker/3:1-1221 [003] … 218.975257: rtos_queue_send_from_isr_failed: tstamp:7221208594 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 218.975261: rtos_queue_send_from_isr_failed: tstamp:7221208767 queue:0x0b4b0098
kworker/3:1-1221 [003] … 218.975264: rtos_queue_send_from_isr_failed: tstamp:7221208942 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 218.975267: rtos_queue_send_from_isr_failed: tstamp:7221209115 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 218.975270: rtos_queue_send_failed: tstamp:7221210974 queue:0x0b4a7258
kworker/3:1-1221 [003] … 219.087150: rtos_queue_peek_from_isr_failed: tstamp:7224274716 queue:0x0b4b4500
vi-output, cros-8640 [004] … 219.194413: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 41
vi-output, cros-8640 [004] … 219.194450: tegra_channel_capture_frame: sof:-549620695340.-269320296128
kworker/3:1-1221 [003] … 219.199052: rtos_queue_send_from_isr_failed: tstamp:7228010810 queue:0x0b4a7258
kworker/3:1-1221 [003] … 219.199058: rtos_queue_send_from_isr_failed: tstamp:7228011093 queue:0x0b4aad68
kworker/3:1-1221 [003] … 219.199060: rtos_queue_send_from_isr_failed: tstamp:7228011363 queue:0x0b4ac998
kworker/3:1-1221 [003] … 219.199062: rtos_queue_send_from_isr_failed: tstamp:7228011630 queue:0x0b4ae518
kworker/3:1-1221 [003] … 219.199064: rtos_queue_send_from_isr_failed: tstamp:7228011898 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 219.199065: rtos_queue_send_from_isr_failed: tstamp:7228012165 queue:0x0b4b0098
kworker/3:1-1221 [003] … 219.199068: rtos_queue_send_from_isr_failed: tstamp:7228012434 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 219.199070: rtos_queue_send_from_isr_failed: tstamp:7228012758 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 219.199075: rtos_queue_send_failed: tstamp:7228014471 queue:0x0b4a7258
kworker/3:1-1221 [003] … 219.199082: rtcpu_vinotify_event: tstamp:7228016706 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:65282 vi_tstamp:7228013417 data:0x08000000
kworker/3:1-1221 [003] … 219.199085: rtos_queue_send_from_isr_failed: tstamp:7228022347 queue:0x0b4a7258
kworker/3:1-1221 [003] … 219.199087: rtos_queue_send_from_isr_failed: tstamp:7228022615 queue:0x0b4aad68
kworker/3:1-1221 [003] … 219.199089: rtos_queue_send_from_isr_failed: tstamp:7228022884 queue:0x0b4ac998
kworker/3:1-1221 [003] … 219.199091: rtos_queue_send_from_isr_failed: tstamp:7228023151 queue:0x0b4ae518
kworker/3:1-1221 [003] … 219.199093: rtos_queue_send_from_isr_failed: tstamp:7228023418 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 219.199095: rtos_queue_send_from_isr_failed: tstamp:7228023684 queue:0x0b4b0098
kworker/3:1-1221 [003] … 219.199097: rtos_queue_send_from_isr_failed: tstamp:7228023951 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 219.199099: rtos_queue_send_from_isr_failed: tstamp:7228024218 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 219.199101: rtos_queue_send_failed: tstamp:7228025285 queue:0x0b4a7258
kworker/3:1-1221 [003] … 219.199103: rtos_queue_send_from_isr_failed: tstamp:7229091774 queue:0x0b4a7258
kworker/3:1-1221 [003] … 219.199105: rtos_queue_send_from_isr_failed: tstamp:7229091918 queue:0x0b4aad68
kworker/3:1-1221 [003] … 219.199107: rtos_queue_send_from_isr_failed: tstamp:7229092057 queue:0x0b4ac998
kworker/3:1-1221 [003] … 219.199109: rtos_queue_send_from_isr_failed: tstamp:7229092202 queue:0x0b4ae518
kworker/3:1-1221 [003] … 219.199111: rtos_queue_send_from_isr_failed: tstamp:7229092339 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 219.199113: rtos_queue_send_from_isr_failed: tstamp:7229092482 queue:0x0b4b0098
kworker/3:1-1221 [003] … 219.199115: rtos_queue_send_from_isr_failed: tstamp:7229092619 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 219.199118: rtos_queue_send_from_isr_failed: tstamp:7229092757 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 219.199119: rtos_queue_send_failed: tstamp:7229093347 queue:0x0b4a7258
kworker/3:1-1221 [003] … 219.199121: rtos_queue_send_from_isr_failed: tstamp:7229095857 queue:0x0b4a7258
kworker/3:1-1221 [003] … 219.199123: rtos_queue_send_from_isr_failed: tstamp:7229095996 queue:0x0b4aad68
kworker/3:1-1221 [003] … 219.199124: rtos_queue_send_from_isr_failed: tstamp:7229096133 queue:0x0b4ac998
kworker/3:1-1221 [003] … 219.199125: rtos_queue_send_from_isr_failed: tstamp:7229096272 queue:0x0b4ae518
kworker/3:1-1221 [003] … 219.199127: rtos_queue_send_from_isr_failed: tstamp:7229096410 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 219.199129: rtos_queue_send_from_isr_failed: tstamp:7229096547 queue:0x0b4b0098
kworker/3:1-1221 [003] … 219.199131: rtos_queue_send_from_isr_failed: tstamp:7229096683 queue:0x0b4b0e58
kworker/3:1-1221 [003] … 219.199133: rtos_queue_send_from_isr_failed: tstamp:7229096821 queue:0x0b4b1c18
kworker/3:1-1221 [003] … 219.199135: rtos_queue_send_failed: tstamp:7229098626 queue:0x0b4a7258
kworker/3:1-1221 [003] … 219.199137: rtcpu_vinotify_event: tstamp:7229099890 tag:CHANSEL_SHORT_FRAME channel:0x04 frame:65282 vi_tstamp:7229097907 data:0x00000001
kworker/3:1-1221 [003] … 219.199139: rtcpu_vinotify_event: tstamp:7229100086 tag:ATOMP_FE channel:0x00 frame:65282 vi_tstamp:7229097910 data:0x00000001
kworker/3:1-1221 [003] … 219.255139: rtos_queue_peek_from_isr_failed: tstamp:7229274748 queue:0x0b4b4500
kworker/3:1-1221 [003] … 219.367152: rtos_queue_peek_from_isr_failed: tstamp:7234274684 queue:0x0b4b4500
kworker/3:1-1221 [003] … 219.423069: rtos_queue_send_from_isr_failed: tstamp:7235903189 queue:0x0b4a7258
kworker/3:1-1221 [003] … 219.423077: rtos_queue_send_from_isr_failed: tstamp:7235903374 queue:0x0b4aad68
kworker/3:1-1221 [003] … 219.423079: rtos_queue_send_from_isr_failed: tstamp:7235903550 queue:0x0b4ac998
kworker/3:1-1221 [003] … 219.423080: rtos_queue_send_from_isr_failed: tstamp:7235903725 queue:0x0b4ae518
kworker/3:1-1221 [003] … 219.423082: rtos_queue_send_from_isr_failed: tstamp:7235903899 queue:0x0b4af2d8
kworker/3:1-1221 [003] … 219.423084: rtos_queue_sen
