Hello
Debian 9.3 is installed ion my PC DELL T3620.
Step 1:The Nvidia 390.42 driver installation is ok.
=> All run, … but
Step 2. When i run via ssh (ssh -XC username@IPaddrr) a application as kdevelop, I receive error message:
LibGL error: No matching fbConfigs or visuals found
LibGL erro : failed to load driver: swrast
The lspci command list is
VGA compatible controler: NVIDIA Corporation Device lcb3
Have you an idea?
Best regard
Marc
You are trying to use indirectGL?
Where is that Quadro installed, in the remote or the local PC?
Hello.
Rue quadro card is P400.
And no i don t used indirectGL.
Hello, I’m same problems with OpenGL,
My configuration local PC:
DELL T3620
debian 9.3
Nvidia P400 with lasted driver installed without warning (NVIDIA-linux-x86_64-390.48)
glxinfo:
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: Quadro P400/PCIe/SSE2
OpenGL core profile version string: 4.5.0 NVIDIA 390.48
OpenGL core profile shading language version string: 4.50 NVIDIA
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.6.0 NVIDIA 390.48
OpenGL shading language version string: 4.60 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 390.48
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
and indirect GL: yes
My condifuration distant PC:
DELL server R530
Video card default
glxinfo:
OpenGL vendor string: VMware, Inc.
OpenGL renderer string: Gallium 0.4 on llvmpipe (LLVM 3.9, 256 bits)
OpenGL core profile version string: 3.3 (Core Profile) Mesa 13.0.6
OpenGL core profile shading language version string: 3.30
OpenGL version string: 3.0 Mesa 13.0.6
OpenGL shading language version string: 1.30
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.0 Mesa 13.0.6
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.00
and indirect GL : yes
when i run with ssh -XC and i run QT or blender, i have this message :
libGL error: No matching fbconfigs or visuals found
libGL error: failed to load driver : swrast
Unrecognized OpenGL version
Before installing the NVIDIA driver for DUAL DISPLAY, with the default configuration on my T3620, qtcreator and blender run without error with SINGLE DISPLAY, after install NVIDIA 390.48, i have error openGL.
an idea ?
best regard
