My card is GTS 8800, the core clock is 500M. Does that mean the frequency of the processor is 500M or the small multiprocessor?
SPWorley
2
It means you have a G80 core model. Its core clock is 500Mhz, but the shading clock is 1200Mhz, and its effective memory clock is 1600MHz.
Related topics
| deviceProperties - clockRate a constant value? | 3 | 4674 | April 9, 2008 | |
| disparity between core clock and SMP clock | 3 | 2944 | August 1, 2008 | |
| what is the problem of my video card core clock is not correct | 0 | 2685 | January 16, 2009 | |
| Why GPU clock is so low? | 1 | 747 | September 28, 2011 | |
| compare performance across different GPU cards and how to figure out the frequency the GPU clock? | 4 | 10062 | June 14, 2010 | |
| 8800GTX Clock frequency? 1.35Ghz or 575Mhz? | 5 | 10806 | May 22, 2007 | |
| clock Rate Undersnatding Hardware | 3 | 6253 | February 25, 2010 | |
| GTX or GTS ? | 14 | 16404 | August 14, 2007 | |
| cudaGetDeviceProperties() - clockRate: Core Clock or Shader Clock? | 1 | 1291 | July 25, 2011 | |
| No of cores in 8400 GS | 6 | 14251 | February 3, 2010 |
