• Hardware Platform (Jetson / GPU) Jetson Xavier NX
• DeepStream Version 5.1
• JetPack Version (valid for Jetson only) 4.5.1
• TensorRT Version 7.1.3
• Issue Type( questions, new requirements, bugs) question
I’m building a deepstream pipeline with python. As pgie I’m using Face Detect model (exported to int8 with TLTv3). As sgie I’m using a classifier with two labels (mask, no-mask). This classifier was trained with TLTv3. This pipeline is based on test2 example, but I removed the tracker.
When running the pipeline, only pgie outputs show on output video. In this pipeline pgie links directly to sgie.
Also, how can I access results from sgie in probe? I tried to access through l_class = obj_meta.classifier_meta_list but the result is always None.
Do I need to include the tracker?
configuration file for pgie:
[property]
gpu-id=0
enable-dla=1
use-dla-core=0
# preprocessing parameters.
model-color-format=0
net-scale-factor=0.0039215697906911373
tlt-model-key=nvidia_tlt
tlt-encoded-model=../../app-be/resources/models/facedetection/model.etlt
model-engine-file=../../app-be/resources/models/facedetection/face_detection.trt
labelfile-path=../../app-be/resources/models/facedetection/labels.txt
input-dims=3;416;736;0
uff-input-blob-name=input_1
batch-size=1
process-mode=1
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
num-detected-classes=1
cluster-mode=1
interval=0
gie-unique-id=1
force-implicit-batch-dim=1
output-blob-names=output_bbox/BiasAdd;output_cov/Sigmoid
[class-attrs-all]
pre-cluster-threshold=0.4
## Set eps=0.7 and minBoxes for cluster-mode=1(DBSCAN)
eps=0.7
minBoxes=1
configuration file for sgie:
[property]
gpu-id=0
# preprocessing parameters: These are the same for all classification models generated by TLT.
net-scale-factor=1.0
offsets=103.939;116.779;123.68
model-color-format=1
batch-size=1
# Model specific paths. These need to be updated for every classification model.
int8-calib-file=../../app-be/resources/models/maskclassification/calibration.bin
labelfile-path=../../app-be/resources/models/maskclassification/labels_mask.txt
tlt-encoded-model=../../app-be/resources/models/maskclassification/final_model_int8.etlt
tlt-model-key=tlt_encode
model-engine-file=../../app-be/resources/models/facedetection/face_mask_classification.trt
input-dims=3;224;224;0
output-blob-names=predictions/Softmax
network-mode=1
# process-mode: 2 - inferences on crops from primary detector, 1 - inferences on whole frame
process-mode=2
interval=0
network-type=1 # defines that the model is a classifier.
gie-unique-id=2
operate-on-gie-id=1
classifier-async-mode=0
classifier-threshold=0.2
process-mode=2
