The image I installed already contained the VPI-samples. So far I did the following:
- copy the samples to the home directory using the vpi_install_samples.sh
- executing the cmake . command in a sample folder, which returned no errors
- executing the make command, which spat out the error in the first post
So far I tried sample 3 and 11, which returned the same errors.
