Camera sensor is working Properly with mipi 4 lane configuration on TX2 board, but as per requirement it needs to be configured for mipi 2 lane on TX2 board.
For make it work:
- The camera sensor is programmed for 2 lane configuration.
- Modified dtsi file for mipi 2 lane.
bus-width = <2>;
After All this modification we are not getting any frame.
We are getting error “PXL_SOF syncpt timeout! err = -11”.
Any ideas what went wrong? Please give your inputs,
According to:
https://elinux.org/Jetson_TX2/28.1_Camera_BringUp
Trace:
kworker/3:1-2816 [003] ...1 3821.828721: rtcpu_start: tstamp:119771535648
kworker/3:1-2816 [003] ...1 3821.988777: rtos_queue_peek_from_isr_failed: tstamp:119776535445 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3822.144806: rtos_queue_peek_from_isr_failed: tstamp:119781535954 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3822.300770: rtos_queue_peek_from_isr_failed: tstamp:119786536454 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3822.456799: rtos_queue_peek_from_isr_failed: tstamp:119791536949 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3822.612808: rtos_queue_peek_from_isr_failed: tstamp:119796537539 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3822.768761: rtos_queue_peek_from_isr_failed: tstamp:119801537957 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3822.924792: rtos_queue_peek_from_isr_failed: tstamp:119806538515 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3823.080770: rtos_queue_peek_from_isr_failed: tstamp:119811538988 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3823.236799: rtos_queue_peek_from_isr_failed: tstamp:119816539496 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3823.392769: rtos_queue_peek_from_isr_failed: tstamp:119821540005 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3823.548770: rtos_queue_peek_from_isr_failed: tstamp:119826540510 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3823.704791: rtos_queue_peek_from_isr_failed: tstamp:119831541085 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3823.912798: rtos_queue_peek_from_isr_failed: tstamp:119836541522 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3824.068790: rtos_queue_peek_from_isr_failed: tstamp:119841542019 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3824.224773: rtos_queue_peek_from_isr_failed: tstamp:119846542605 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3824.380768: rtos_queue_peek_from_isr_failed: tstamp:119851543044 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3824.536771: rtos_queue_peek_from_isr_failed: tstamp:119856543549 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3824.692773: rtos_queue_peek_from_isr_failed: tstamp:119861544061 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3824.848791: rtos_queue_peek_from_isr_failed: tstamp:119866544551 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3825.004774: rtos_queue_peek_from_isr_failed: tstamp:119871545128 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3825.160783: rtos_queue_peek_from_isr_failed: tstamp:119876545579 queue:0x0b4a3c58
kworker/3:1-2816 [003] ...1 3825.316789: rtos_queue_peek_from_isr_failed: tstamp:119881546105 queue:0x0b4a3c58
