I’m trying to compile some code into ptx under windows XP and then load it into matlab with the parallel computing toolbox. Matlan complains that: “No entries were found in the PTX file”, so I did some more tests. Compiling to PTX seems to work:
D:\analysis>nvcc -arch=sm_20 -ptx -Xptxas -V distsKernelSmallD.cu
tmpxft_00000ac8_00000000-3_distsKernelSmallD.cudafe1.gpu
tmpxft_00000ac8_00000000-10_distsKernelSmallD.cudafe2.gpu
Compiling to object fails saying that it couldn’t find the cubin file:
D:\analysis>nvcc -arch=sm_20 -c -Xptxas -V distsKernelSmallD.cu
tmpxft_0000025c_00000000-3_distsKernelSmallD.cudafe1.gpu
tmpxft_0000025c_00000000-8_distsKernelSmallD.cudafe2.gpu
ptxas: NVIDIA ® Ptx optimizing assembler
Copyright © 2005-2011 NVIDIA Corporation
Built on Fri_Jan_13_02:49:02_PST_2012
Cuda compilation tools, release 4.1, V0.2.1221
fatbinary fatal : Could not open input file ‘C:/DOCUME~1/Micha/LOCALS~1/Temp/tmpxft_0000025c_00000000-13_distsKernelSmallD.sm_20.cubin’
If I remote the -Xptxas -V it supposedly works (I can create an executable that runs), but it doesn’t solve the matlab problem. Under windows 7 64bit the exact same process works great (making sure that the binary is 64bit instead of 32bit). Any ideas?
System is windows xp 32bit + vs 2010 + matlab 2011b.
