I’m having trouble compiling FFTW 3.3.8 using PGI 19.4 on an OpenPOWER 9 system due to an error at compile time:
PGC-F-0249-#error -- Use the "-maltivec" flag to enable PowerPC AltiVec support (/usr/lib/gcc/ppc64le-redhat-linux/4.8.5/include/altivec.h: 34)
PGC/power Linux 19.4-0: compilation aborted
The configuration I am using is:
env CC=pgcc FC=pgfortran F90=pgf90 CFLAGS="-fast -Minfo -fPIC" F77=pgfortran FFLAGS="-fast -Minfo" PTHREAD_CC=$CC ./configure --enable-threaded --enable-shared --enable-vsx --prefix=${HOME}/builds/fftw_pgcc
The PTHREAD_CC bit is a workaround recommended here
Any ideas on what could be going awry? During my configure script, I also see the following warning:
configure: WARNING: altivec.h: present but cannot be compiled
configure: WARNING: altivec.h: check for missing prerequisite headers?
configure: WARNING: altivec.h: see the Autoconf documentation
configure: WARNING: altivec.h: section "Present But Cannot Be Compiled"
configure: WARNING: altivec.h: proceeding with the compiler's result
configure: WARNING: ## ---------------------------- ##
configure: WARNING: ## Report this to fftw@fftw.org ##
but my Google-fu has not been good enough to figure out what that means.
