Problem converting caffemodel to tensorRT using AMPERE-based host GPU
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.0.8170
1.5.1.7815
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
Hi there,
I’m trying to convert a caffemodel to a tensorRT optimized model using the provided tools
tensorRT_optimization
https://docs.nvidia.com/drive/driveworks-3.0/dwx_tensorRT_tool.html
And trtexec
https://docs.nvidia.com/deeplearning/tensorrt/developer-guide/index.html#trtexec
However, when I try to run it on my machine with an RTX 3080 (AMPERE GPU), the process takes a long time and then finally errors out with the following
…/builder/caskConvolutionTraits.cpp (381) - Cask Error in createConstants: 0 (initDeviceReservedSpace)
This problem also happens with a relatively simple model like the supplied MNIST model.
Is there any way to fix this issue? I have another machine with an RTX 2080 which performs the conversion very quickly (< 20 seconds).
Hi @victorgpu,
Please provide the complete log, the steps, and the commands for our check and reproducing. Thanks.
Using the model files in /usr/local/driveworks/data/samples/dnn
Using trtexec
/usr/src/tensorrt/bin/trtexec --deploy=sample_mnist.prototxt --model=sample_mnist.caffemodel --output=prob --verbose
&&&& RUNNING TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --deploy=sample_mnist.prototxt --model=sample_mnist.caffemodel --output=prob --verbose
[I] deploy: sample_mnist.prototxt
[I] model: sample_mnist.caffemodel
[I] output: prob
[I] verbose
[V] [TRT] Plugin Creator registration succeeded - GridAnchor_TRT
[V] [TRT] Plugin Creator registration succeeded - NMS_TRT
[V] [TRT] Plugin Creator registration succeeded - Reorg_TRT
[V] [TRT] Plugin Creator registration succeeded - Region_TRT
[V] [TRT] Plugin Creator registration succeeded - Clip_TRT
[V] [TRT] Plugin Creator registration succeeded - LReLU_TRT
[V] [TRT] Plugin Creator registration succeeded - PriorBox_TRT
[V] [TRT] Plugin Creator registration succeeded - Normalize_TRT
[V] [TRT] Plugin Creator registration succeeded - RPROI_TRT
[V] [TRT] Plugin Creator registration succeeded - BatchedNMS_TRT
[I] Input "data": 1x28x28
[I] Output "prob": 10x1x1
[I] [TRT] Applying generic optimizations to the graph for inference.
[I] [TRT] Original: 9 layers
[I] [TRT] After dead-layer removal: 9 layers
[I] [TRT] After scale fusion: 9 layers
[I] [TRT] Fusing ip1 with relu1
[I] [TRT] After vertical fusions: 8 layers
[I] [TRT] After swap: 8 layers
[I] [TRT] After final dead-layer removal: 8 layers
[I] [TRT] After tensor merging: 8 layers
[I] [TRT] After concat removal: 8 layers
[I] [TRT] Graph construction and optimization completed in 0.0007404 seconds.
[I] [TRT]
[I] [TRT] --------------- Timing scale(10)
[I] [TRT] Tactic 0 is the only option, timing skipped
[I] [TRT]
[I] [TRT] --------------- Timing conv1(3)
[I] [TRT]
[I] [TRT] --------------- Timing conv1(2)
[I] [TRT] Tactic 5 time 0.007168
[I] [TRT] Tactic 18 time 0.008192
[I] [TRT] Tactic 23 time 0.01024
[I] [TRT] Tactic 72 time 0.009216
[I] [TRT] Tactic 73 time 0.007168
[I] [TRT] Tactic 77 time 0.006144
[I] [TRT] Tactic 99 time 0.007168
[I] [TRT] Tactic 100 time 0.007168
[I] [TRT] Tactic 141 time 0.007072
[I] [TRT] Tactic 142 time 0.007168
[I] [TRT] Tactic 147 time 0.007168
[I] [TRT]
[I] [TRT] --------------- Timing conv1(14)
[E] [TRT] ../builder/caskConvolutionTraits.cpp (381) - Cask Error in createConstants: 0 (initDeviceReservedSpace)
[E] could not build engine
[E] Engine could not be created
&&&& FAILED TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --deploy=sample_mnist.prototxt --model=sample_mnist.caffemodel --output=prob --verbose
Using tensorRT_optimization
/usr/local/driveworks/tools/dnn/tensorRT_optimization --modelType=caffe                        --outputBlobs=prob                        --prototxt=sample_mnist.prototxt --caffemodel=sample_mnist.caffemodel
Initializing network optimizer on model sample_mnist.prototxt with weights from sample_mnist.caffemodel
Dear @victorgpu,
Support for Ampere GPU require CUDA 11.0 or more. Note that the last DRIVE release also has CUDA 10.2 so we can not have any work around for this request.
