python3: nmsPlugin.cpp:139: virtual void nvinfer1::plugin::DetectionOutput::configureWithFormat(const nvinfer1::Dims*, int, const nvinfer1::Dims*, int, nvinfer1::DataType, nvinfer1::PluginFormat, int): Assertion `numPriors * numLocClasses * 4 == inputDims[param.inputOrder[0]].d[0]’ failed.
Aborted (core dumped)
Facing above error while converting Problem converting customised trained ssd mobilenet v2 uff to engine format
Anyone help!!
I was able to convert ssd_mobilenet_v2 to tensort
The solution to above problem is
If Custom model trained with one class then give
numClasses=2 (one is your class and the other class is background class)
inputOrder=[0,2,1]
Put these two parameters in your config file and you will be able to convert succesfully
Hope this helps someone else!!
inputOrder=[0,2,1]
Thanks Ambika. This really worked for me.
inputOrder=[0,2,1]
Thanks! It worked for me too.
