Hello everyone,
I have been trying to debug a test application with Nsight 3.2.2 in Visual Studio 2012, but it keeps crashing (nsighttest.exe has stopped working). If I use the debug the application from the error message, I can see that an access violation error is occurring. If I run the code using either a Debug or Release build but without Nsight, there is no error.
I have created a short version of my code to reproduce this issue (I know, it doesn’t do much as is). The access violation happens in the ‘cudaGraphicsGLRegisterImage’ call, and I realized that by removing the ‘SDL_GL_CreateContext’ call, the error no longer occurs. Is there any know incompatibility between Nsight and SDL 2.0?
The error:
Unhandled exception at 0x651B5A17 (nvcuda.dll) in nsighttest.exe: 0xC0000005: Access violation reading location 0x00000010.
Test code:
#include <GL/glew.h>
/* Include windows.h properly on Windows */
#if defined(WIN32) || defined(_WINDOWS)
# define WIN32_LEAN_AND_MEAN
# define NOMINMAX
# include <windows.h>
#endif
#define NO_SDL_GLEXT
#include <SDL.h>
#include <SDL_opengl.h>
#ifndef SDL_MAGIC_MAIN
# undef main
#endif
#include "cuda_runtime.h"
#include <cuda_gl_interop.h>
#include "device_launch_parameters.h"
#include <iostream>
int main()
// Initialize SDL
if (SDL_Init(SDL_INIT_VIDEO) < 0)
std::cerr << "Error initializing SDL: " << SDL_GetError() << std::endl;
return false;
// Set OpenGL attributes
SDL_GL_SetAttribute(SDL_GL_CONTEXT_MAJOR_VERSION, 4);
SDL_GL_SetAttribute(SDL_GL_CONTEXT_MINOR_VERSION, 2);
SDL_GL_SetAttribute(SDL_GL_DOUBLEBUFFER, 1);
SDL_GL_SetAttribute(SDL_GL_DEPTH_SIZE, 24);
SDL_GL_SetAttribute(SDL_GL_RED_SIZE, 8);
SDL_GL_SetAttribute(SDL_GL_GREEN_SIZE, 8);
SDL_GL_SetAttribute(SDL_GL_BLUE_SIZE, 8);
SDL_GL_SetAttribute(SDL_GL_ALPHA_SIZE, 8);
// Create window
SDL_Window* window = SDL_CreateWindow("Window", SDL_WINDOWPOS_CENTERED, SDL_WINDOWPOS_CENTERED, 800, 600,
SDL_WINDOW_OPENGL | SDL_WINDOW_SHOWN);
if (!window)
std::cerr << "Error creating SDL window: " << SDL_GetError() << std::endl;
return false;
// Create OpenGL context
SDL_GLContext openGlContext = SDL_GL_CreateContext(window);
if (!openGlContext)
std::cerr << "Error creating GL context " << SDL_GetError() << std::endl;
// Clear our buffer
glClearColor(0.0f, 0.0f, 0.0f, 1.0f);
glClear(GL_COLOR_BUFFER_BIT);
// Swap our back buffer to the front
SDL_GL_SwapWindow(window);
// Initialize GLEW
if (glewInit() != GLEW_OK) {
std::cerr << "Error initializing GLEW" << std::endl;
return false;
if (!glewIsSupported("GL_VERSION_2_0 "))
std::cerr << "Support for necessary OpenGL extensions missing." << std::endl;
return false;
// Initialize cuda device
cudaSetDevice(0);
GLuint texture;
cudaGraphicsResource_t cudaGLBuffer;
// Create OpenGL texture
glEnable(GL_TEXTURE_2D);
glGenTextures(1, &texture);
glBindTexture(GL_TEXTURE_2D, texture);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP_TO_EDGE);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP_TO_EDGE);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA8, 800, 600, 0, GL_RGBA, GL_UNSIGNED_BYTE, nullptr);
glBindTexture(GL_TEXTURE_2D, 0);
// Register texture with CUDA
cudaGraphicsGLRegisterImage(&cudaGLBuffer, texture, GL_TEXTURE_2D, cudaGraphicsRegisterFlagsSurfaceLoadStore);
// cudaDeviceReset must be called before exiting in order for profiling and
// tracing tools such as Nsight and Visual Profiler to show complete traces.
cudaError_t cudaStatus = cudaDeviceReset();
if (cudaStatus != cudaSuccess) {
fprintf(stderr, "cudaDeviceReset failed!");
return 1;
return 0;
Any ideas?
