We are having a problem I have seen on the boards but none of the solutions i have found work.
We keep getting this error message
“Problem Ejecting NVIDIA Tesla M2090 : the NVIDIA Tesla M2090 device is not removable and cannot be ejected or unplugged”
we are running the current drivers 354.70. on a windows 7 X64 system.
already tried the uninstall, Cleanup (DDU) and reload drivers. no success there.
any one found a fix for this issue?
thank you
Alex
Thank you for look at this
I don’t see any errors in the result
==============NVSMI LOG==============
Timestamp : Mon Mar 07 13:40:18 2016
Driver Version : 354.70
Attached GPUs : 2
GPU 0000:01:00.0
Product Name : Quadro K2000
Product Brand : Quadro
Display Mode : Enabled
Display Active : Enabled
Persistence Mode : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 1920
Driver Model
Current : WDDM
Pending : WDDM
Serial Number : 0320114058501
GPU UUID : GPU-177589ad-55e5-a3b0-8a37-27f991311aca
Minor Number : N/A
VBIOS Version : 80.07.C7.00.03
MultiGPU Board : No
Board ID : 0x100
Inforom Version
Image Version : 2095.0500.00.01
OEM Object : 1.1
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x0FFE10DE
Bus Id : 0000:01:00.0
Sub System Id : 0x094C10DE
GPU Link Info
PCIe Generation
Max : 2
Current : 1
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays since reset : 0
Tx Throughput : N/A
Rx Throughput : N/A
Fan Speed : 30 %
Performance State : P8
Clocks Throttle Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
Unknown : Not Active
FB Memory Usage
Total : 2048 MiB
Used : 407 MiB
Free : 1641 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 9 MiB
Free : 247 MiB
Compute Mode : Default
Utilization
Gpu : 1 %
Memory : 7 %
Encoder : 0 %
Decoder : 0 %
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending : N/A
Temperature
GPU Current Temp : 42 C
GPU Shutdown Temp : 103 C
GPU Slowdown Temp : 98 C
Power Readings
Power Management : N/A
Power Draw : N/A
Power Limit : N/A
Default Power Limit : N/A
Enforced Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Clocks
Graphics : 324 MHz
SM : 324 MHz
Memory : 324 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 954 MHz
SM : 954 MHz
Memory : 2000 MHz
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes
Process ID : 456
Type : C+G
Name : C:\Program Files\MATLAB\R2015a\bin\win64\MATLAB.exe
Used GPU Memory : Not available in WDDM driver model
Process ID : 468
Type : Insufficient Permissions
Name : Insufficient Permissions
Process ID : 2116
Type : C+G
Name : C:\Program Files\Microsoft Office 15\Root\Office15\WINWORD.EXE
Process ID : 2752
Type : C+G
Name : C:\Program Files\UTTechnology\UTScan\UtScan.exe
Process ID : 6196
Type : C+G
Name : C:\Program Files (x86)\TechSmith\Snagit 10\Snagit32.exe
Process ID : 6440
Type : C+G
Name : C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Process ID : 6608
Type : C+G
Process ID : 8176
Type : C+G
Name : C:\Program Files\Microsoft Office 15\root\office15\OUTLOOK.EXE
Process ID : 8716
Type : C+G
Process ID : 11104
Type : C+G
GPU 0000:06:00.0
Product Name : Tesla M2090
Product Brand : Tesla
Display Mode : Disabled
Display Active : Disabled
Accounting Mode : N/A
Accounting Mode Buffer Size : N/A
Driver Model
Current : TCC
Pending : TCC
Serial Number : 0322211026980
GPU UUID : GPU-ddc42316-d356-4263-1c82-a7ad2162bf43
Minor Number : N/A
VBIOS Version : 70.10.46.00.01
MultiGPU Board : No
Board ID : 0x600
Inforom Version
Image Version : N/A
OEM Object : 1.1
ECC Object : 2.0
Power Management Object : 4.0
GPU Operation Mode
Current : N/A
Pending : N/A
PCI
Bus : 0x06
Device : 0x00
Domain : 0x0000
Device Id : 0x109110DE
Bus Id : 0000:06:00.0
Sub System Id : 0x088710DE
GPU Link Info
PCIe Generation
Max : 2
Current : 1
Link Width
Max : 16x
Current : 4x
Bridge Chip
Type : N/A
Firmware : N/A
Replays since reset : N/A
Tx Throughput : N/A
Rx Throughput : N/A
Fan Speed : N/A
Performance State : P12
Clocks Throttle Reasons : N/A
FB Memory Usage
Total : 6143 MiB
Used : 10 MiB
Free : 6133 MiB
BAR1 Memory Usage
Total : N/A
Used : N/A
Free : N/A
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : N/A
Decoder : N/A
Ecc Mode
Current : Disabled
Pending : Disabled
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Retired Pages
Pending : N/A
Temperature
GPU Current Temp : N/A
GPU Shutdown Temp : N/A
GPU Slowdown Temp : N/A
Power Readings
Power Management : Supported
Power Draw : 32.60 W
Power Limit : 225.00 W
Clocks
Graphics : 50 MHz
SM : 100 MHz
Memory : 135 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 650 MHz
SM : 1301 MHz
Memory : 1848 MHz
Clock Policy
Auto Boost : N/A
Processes : None
Does this problem happen on your Win7x64 setup frequently and consistently? Seem that I don’t have this problem on my Tesla M2090 windows setup. Is there specific steps and settings to trigger this issue?
Furthermore, did you try to re-installation the v354.70 driver cleanly? Clean installation means removed all NVIDIA software(from control panel) firstly, and start re-installation with selected “Custom” - checked “Perform a clean installation”.
