Problem flashing to Jetson Orin NX with Hadron carrier board
I am attempting to flash my Jetson Orin NX with the Connect Tech Hadron carrier board. I was told that because the Orin NX doesn’t have an internal eMMC, I should flash the NVMe card from separately from my host computer first following these directions. However, after installing the NVMe back into the board and running the command, ./flash.sh cti/orin-nx/hadron/base nvme0n1p1, I get this error from serial: Top caller module: SDMMC, reason: 0x06, aux_info: 0x07; busy spin. The last line of the actual flashing logs is: tegrarcm_v2 --chip 0x23 0 --oem platformdetails storage storage_info.bin
What could the problem be?
please contact the vendor for help as you are using a third-party carrier board.
They seems to have some customized flashing scripts created by themselves, which we do not guarantee the integrity. We also do not have the same carrier board for testing.
