alxhoff
February 24, 2025, 11:50am
1
I am following the steps here for generating an OTA payload but am running into the problem that I get
+ cp /workspace/target_bsp/5.1.3/Linux_for_Tegra/bootloader/xusb_sil_rel_fw /workspace/target_bsp/5.1.3/Linux_for_Tegra/ota_base_dir_tmp/internal_device/images-R35-ToT/
+ '[' -n '' ']'
+ '[' 0x23 == 0x19 ']'
+ cp /workspace/target_bsp/5.1.3/Linux_for_Tegra/tools/ota_tools/version_upgrade/l4t_update_partitions.sh /workspace/target_bsp/5.1.3/Linux_for_Tegra/ota_base_dir_tmp
+ cp /workspace/target_bsp/5.1.3/Linux_for_Tegra/tools/ota_tools/version_upgrade/upgradetasklist.txt.jetson-agx-orin-devkit.R32x_to_R35-ToT_emmc /workspace/target_bsp/5.1.3/Linux_for_Tegra/ota_base_dir_tmp/upgradetasklist.txt
cp: cannot stat '/workspace/target_bsp/5.1.3/Linux_for_Tegra/tools/ota_tools/version_upgrade/upgradetasklist.txt.jetson-agx-orin-devkit.R32x_to_R35-ToT_emmc': No such file or directory
looking into this folder I only see the following files
./rootfs/5.1.3/Linux_for_Tegra/tools/ota_tools/version_upgrade/upgradetasklist.txt.jetson-agx-xavier-devkit.R32x_to_R35-ToT_emmc
./rootfs/5.1.3/Linux_for_Tegra/tools/ota_tools/version_upgrade/upgradetasklist.txt.jetson-xavier-nx-devkit-emmc.R32x_to_R35-ToT_emmc
./rootfs/5.1.3/Linux_for_Tegra/tools/ota_tools/version_upgrade/upgradetasklist.txt.jetson-agx-xavier-industrial.R32x_to_R35-ToT_emmc
I cannot find these appropriate file for JP 5.1.3 and a jetson-agx-orin-devkit board.
What am I missing?
Cheers
Could you provide your commands you execute for us to review?
Also some questions to confirm
Is your AGX Orin a dev kit or a custom board?
alxhoff
February 25, 2025, 11:37am
5
The command I am running is
./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh jetson-agx-orin-devkit R35-4
Moving from JP 5.1.2 → 5.1.3.
I should also mention that I have modified the default partition .XML to remove some of the non-required partitions such that the payload would match the partition scheme we use in ops on our jetsons.
It is a AGX Orin dev kit
I have checked all OTA tools and it seems that these update files for the Orin are not included in any of them and I cannot find them online. please help
kayccc
March 26, 2025, 5:12am
9
Yes this is still an issue, didn’t find a solution to it so had to revert to using the default partition layout.
We verify the image-based ota customization layout using command provided
sudo ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh jetson-agx-orin-devkit R35-4
Please make sure BASE_BSP
, TARGET_BSP
and the correct ota tool .
Also please also note that using the same custom partition layout file to generate the OTA package.
If still fail, we need you provide steps by steps commands in detail include the file you modify for us to reproduce your error.
system
Closed
May 6, 2025, 4:57am
15
