hi
In the below code (marked with a line of ****'s to make spotting easy) when i compile with the if() condition commented out, everything works perfectly…But when i uncomment it…i get a compile time error which looks like–Error: External calls are not supported (found non-inlined call to ZSteqIwSt11char_traitsIwESaIwEEbRKSbIT_T0_T1_ES8)
Is it just because of the if() condition or am i missing something else?
P.S- FYI, i have declared the function prototype in ScoreHolder.h. The name of this file is ScoreHolder.cu
[codebox]#include “ScoreHolder.h”
#include “ScoringFunctions.h”
#include
#include
#include
#include “Timer.h”
#include
#include “thrust/sort.h”
#include “Node.h”
#include
#include <stdlib.h>
//#include “Typedefs.h”
//Is this form of method declaration needed here???
global void node2nodeScorer(std::wstring* dev_tnode_atts,std::wstring* dev_tnode_vals,std::wstring* dev_dnode_atts,std::wstring* dev_dnode_vals,int *count);
namespace
// A simple function to test if a file exists.
bool doesFileExist (const std::wstring& path)
bool result (false);
/*std::wstring ws = L"Hello";
std::string s(ws.begin(), ws.end());
s.assign(ws.begin(), ws.end());
cout<<s;*/
std::ifstream file;
std::string path_string(path.begin(),path.end());
path_string.assign(path.begin(),path.end());
//char *s=path_string.c_str();
file.open (path_string.c_str());
if (!file.fail())
result = true;
file.close();
return result;
const std::wstring semanticNodeScorerPath (L"SemanticNodeScorer.jar");
unsigned long* ScoreHolder::map2vec(Graph_ptr& graph)
unsigned long* temp=(unsigned long*)malloc(graph->countNodes()*sizeof(unsigned long*));
int i=0;
for (Graph::NodeIterator templateNode = graph->getFirstNode();templateNode !=graph->getLastNode(); ++templateNode)
temp[i]=(*templateNode).second->getUniqueId();
i++;
return temp;
std::wstring* ScoreHolder::map2string_array(const CUBRC::AttributeValueMap& attributes,int flag)
std::wstring* temp;
temp=new std::wstring[attributes.size()];
int i=0;
if(flag==1)//Specifies that the attributes have to be vectorised
for(CUBRC::AttributeValueMap::const_iterator pos1 =attributes.begin();pos1!=attributes.end(); ++pos1)
//std::wcout<<"Map Value "<<(*pos1).first;
temp[i]=(*pos1).first;
i++;
else if(flag==2)//Specifies that the values have to vectorised
for(CUBRC::AttributeValueMap::const_iterator pos2 =attributes.begin();pos2!=attributes.end(); ++pos2)
temp[i]=(*pos2).second;
// std::wcout<<(*pos2).second;
i++;
return temp;
std::wstring* ScoreHolder::getMapAttributes (Graph_ptr& graph,int flag)
int temp_del=0;
std::wstring* temp;
int loop_itr=0;
Graph::NodeIterator templateNode_temp = graph->getFirstNode();
const Node_ptr n=(*templateNode_temp).second;
const CUBRC::AttributeValueMap& attributes_temp (n->getAttributes());
int no_atts=attributes_temp.size();
std::wstring* final_atts=new std::wstring[graph->countNodes()*no_atts];
int count=0;
int i=0;
CUBRC::AttributeValueMap& attributes ((*templateNode).second->getAttributes());
temp=map2string_array(attributes,flag);
count++;
//std::cout<<std::endl<<"Count--"<<count;
if (final_atts==NULL)
std::cout<<"Error while making a string out of all attribute maps";
exit(1);
for(loop_itr=(count-1)*attributes.size();loop_itr<(count)*attributes.size();loop_itr++)
//std::wcout<<std::endl<<temp[i];
final_atts[loop_itr]=temp[i];
i++;
//std::cin>>temp_del;
return final_atts;
int idx=blockIdx.x*blockDim.x+threadIdx.x;
for(int i=0;i<5;i++)
if(dev_dnode_atts[idx]==dev_tnode_atts[blockIdx.x*blockDim.x
+i])
//Below is the if condition under consideration!!
//if(dev_dnode_vals[idx]==dev_tnode_vals[blockIdx.x*blockDim.x
+i])
count[blockIdx.x*blockDim.x]++;
count[0]=0;
count[1]=1;
count[2]=2;
ScoreHolder::ScoreHolder (Graph_ptr& templateGraph, Graph_ptr& dataGraph)
int* count=(int*)malloc(3*sizeof(int));
int* count_new;
//std::cout<<"hope she clls";
//count_new=(int*)malloc(3*sizeof(int));
for (int i=0;i<3;i++)
count[i]=0;
std::wstring* tnode_atts=new std::wstring[50];
std::wstring* tnode_vals=new std::wstring[50];
std::wstring* dnode_atts=new std::wstring[2500];
std::wstring* dnode_vals=new std::wstring[2500];
std::wstring* dev_tnode_atts;
std::wstring* dev_tnode_vals;
std::wstring* dev_dnode_atts;
std::wstring* dev_dnode_vals;
Timer t (L"Computation of the node to node scores", true);
initializeScores (templateGraph, dataGraph);
unsigned long* tnodeids=map2vec(templateGraph);
unsigned long* dnodeids=map2vec(dataGraph);
//thrust::sort(dnodeids,dnodeids+500);
tnode_atts=getMapAttributes(templateGraph,1);
tnode_vals=getMapAttributes(templateGraph,2);
dnode_atts=getMapAttributes(dataGraph,1);
dnode_vals=getMapAttributes(dataGraph,2);
cudaMalloc((void**)&dev_tnode_atts,50*(sizeof(std::wstring)));
cudaMalloc((void**)&dev_tnode_vals,50*(sizeof(std::wstring)));
cudaMalloc((void**)&dev_dnode_atts,2500*(sizeof(std::wstring)));
cudaMalloc((void**)&dev_dnode_vals,2500*(sizeof(std::wstring)));
cudaMalloc((void**)&count_new,3*(sizeof(int)));
cudaMemcpy(dev_tnode_atts,tnode_atts,50*(sizeof(std::wstring
)),cudaMemcpyHostToDevice);
cudaMemcpy(dev_tnode_vals,tnode_vals,50*(sizeof(std::wstring
cudaMemcpy(dev_dnode_atts,dnode_atts,2500*(sizeof(std::wstri
ng)),cudaMemcpyHostToDevice);
cudaMemcpy(dev_dnode_vals,dnode_vals,2500*(sizeof(std::wstri
cudaMemcpy(count_new,count,3*(sizeof(int)),cudaMemcpyHostToD
evice);
int numBlocks=10;
int numThreadsPerBlock=500;
dim3 dimGrid(numBlocks);
dim3 dimBlock(numThreadsPerBlock);
node2nodeScorer<<< dimGrid,dimBlock >>>(dev_tnode_atts,dev_tnode_vals,dev_dnode_atts,dev_dnode_v
als,count_new);
cudaMemcpy(count,count_new,3*sizeof(int),cudaMemcpyDeviceToH
ost);
std::wcout<<std::endl<<count[i];
exit(1);
for(int i=0;i<2500;i++)
//f++;
//std::cout<<"Count is "<<f<<" ";
//std::wcout<<dnode_vals[i]<<std::endl;
if((i+1)%5==0)
std::wcout<<std::endl;
std::cout<<"Back home";
exit(1);
//Calculate the node to node scores.
/*ScoreHolder::ScoreHolder (Graph_ptr& templateGraph, Graph_ptr& dataGraph)
for (Graph::NodeIterator templateNode = templateGraph->getFirstNode();
templateNode != templateGraph->getLastNode(); ++templateNode)
for (Graph::NodeIterator dataGraphNode = dataGraph->getFirstNode();
dataGraphNode != dataGraph->getLastNode(); ++dataGraphNode)
const unsigned long templateNodeIndex ((*templateNode).second->getUniqueId());
const unsigned long dataGraphNodeIndex ((*dataGraphNode).second->getUniqueId());
//std::cout<<std::endl<<"Below is the main 2 b paralellized function";
//std::cout<<"\nHere";
float score (ScoringFunctions::getScore((*templateNode).second, (*dataGraphNode).second));
m_scores[templateNodeIndex][dataGraphNodeIndex].nodeToNodeSc
ore = score;
//std::cout<<"\n"<<score;
//std::cout<<"\nScore for template node "<<templateNodeIndex<<" and data node "<<dataGraphNodeIndex<<" is "<<score;
t.printTimeInfo(true);
// Get the score for a node.
Structures::ScorePair&
ScoreHolder::getScore (const Node_ptr& templateNode, const Node_ptr& dataGraphNode)
return m_scores[templateNode->getUniqueId()][dataGraphNode->getUniqueId()];
//Initialize the scores from the graphs.
void ScoreHolder::initializeScores (Graph_ptr& templateGraph, Graph_ptr& dataGraph)
const unsigned long templateNodes (templateGraph->countNodes());
const unsigned long dataGraphNodes (dataGraph->countNodes());
// The old "trim excess capacity with a swap trick"
std::vector<std::vector<Structures::ScorePair> > tg (templateNodes);
tg.resize(templateNodes);
m_scores.swap(tg);
for (unsigned long i = 0; i < templateNodes; ++i)
std::vector<Structures::ScorePair> dg (dataGraphNodes);
dg.resize(dataGraphNodes);
m_scores[i].swap(dg);
// Calculate the node to node scores from the java application.
Graph_ptr& dataGraph,
const std::wstring& templateGraphPath,
const std::wstring& dataGraphFilePath,
const std::wstring& owlFileDirectory,
bool getUriInfo)
Timer t (L"Semantic computation of the node to node scores", true);
// This is where we call the java code to get the scores.
if (doesFileExist (templateGraphPath) &&
doesFileExist (dataGraphFilePath))
// Create a bat file to execute the scores file. It sucks that I have to create a file
// to do this, but the system call only accepts char* args and not wchar_t. Oh well.
std::wofstream cmd;
cmd.open("executeScores.bat");//Gotta check this up later...why the hell is a simple string written as a wide string...creates major issues on a unix platform
cmd << L"java -Xms10m -Xmx1024m -jar " << semanticNodeScorerPath
<< L" -t " << L"\"" << templateGraphPath << L"\""
<< L" -d " << L"\"" << dataGraphFilePath << L"\""
<< L" -o " << L"\"" << owlFileDirectory << L"\""
<< L" -f " << L"\"" << L"scores.txt" << L"\"";
if (!getUriInfo)
cmd << L" -dontGetUriInfo ";
cmd.close();
// Execute the bat file to run our java stuff
system("executeScores.bat");
// Ensure that the score file exists.
if (doesFileExist (std::wstring(L"scores.txt")))
std::wifstream scoreFile ("scores.txt");
if (scoreFile.is_open())
while (!scoreFile.eof())
std::wstring templateId, dataId, scoreAsString;
std::getline(scoreFile, templateId);
if (!scoreFile.eof())
std::getline(scoreFile, dataId);
std::getline(scoreFile, scoreAsString);
// Ensure that the parameters have non zero length.
if (templateId.length() > 0 && dataId.length() > 0 && scoreAsString.length() > 0)
float score (0);
std::wistringstream iss (scoreAsString);
// If this doesn't work, then the string was not a floating point value.
if (iss >> score)
Node_ptr templateNode = templateGraph->getNodeById(templateId);
Node_ptr dataGraphNode = dataGraph->getNodeById(dataId);
if (templateNode.get() != NULL && dataGraphNode.get() != NULL)
m_scores[templateNode->getUniqueId()][dataGraphNode->getUniqueId()].nodeToNodeScore = score;
scoreFile.close();
else
std::wcout << std::endl << L"\nThe java scores file does not exist, quitting.";
[/codebox]
