I am currently developing an application that calls a cuda library.
My application is compiled with g++ 4.3 and needs to know about the cuda datatypes.
When compiling it creates the following error:
Making dependency list for source file src/main.cpp
SOURCE=src/main.cpp ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wnon-virtual-dtor -O3 -fno-strict-aliasing -DNoRepository -ftemplate-depth-40 -I/home/jkastrup/Engys/OpenFOAM-1.6_engysEdition-2.0.beta/src/finiteVolume/lnInclude/ -I../foam_cuda_lib/include/ -Iinclude/ -I/usr/local/cuda/include/ -IlnInclude -I. -I/home/jkastrup/Engys/OpenFOAM-1.6_engysEdition-2.0.beta/src/OpenFOAM/lnInclude -I/home/jkastrup/Engys/OpenFOAM-1.6_engysEdition-2.0.beta/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/main.o
In file included from /usr/local/cuda/include/cusp/complex.h:71,
from /usr/local/cuda/include/cusp/blas.h:26,
from /usr/local/cuda/include/cusp/detail/device/conversion.h:20,
from /usr/local/cuda/include/cusp/detail/device/convert.h:23,
from /usr/local/cuda/include/cusp/detail/dispatch/convert.h:21,
from /usr/local/cuda/include/cusp/detail/convert.inl:17,
from /usr/local/cuda/include/cusp/convert.h:47,
from /usr/local/cuda/include/cusp/detail/coo_matrix.inl:17,
from /usr/local/cuda/include/cusp/coo_matrix.h:368,
from ../foam_cuda_lib/include/foam_cuda_lib_solver.h:5,
from src/main.cpp:9:
/usr/local/cuda/include/cuComplex.h: In function ‘double cuCabs(cuDoubleComplex)’:
/usr/local/cuda/include/cuComplex.h:273: error: call of overloaded ‘sqrt(double&)’ is ambiguous
/usr/include/bits/mathcalls.h:157: note: candidates are: double sqrt(double)
/home/jkastrup/Engys/OpenFOAM-1.6_engysEdition-2.0.beta/src/OpenFOAM/lnInclude/dimensionedScalar.H:65: note: Foam::dimensionedScalar Foam::sqrt(const Foam::dimensionedScalar&)
/home/jkastrup/Engys/OpenFOAM-1.6_engysEdition-2.0.beta/src/OpenFOAM/lnInclude/Scalar.H:233: note: Foam::doubleScalar Foam::sqrt(Foam::doubleScalar)
/home/jkastrup/Engys/OpenFOAM-1.6_engysEdition-2.0.beta/src/OpenFOAM/lnInclude/Scalar.H:233: note: Foam::floatScalar Foam::sqrt(Foam::floatScalar)
make: *** [Make/linux64GccDPOpt/main.o] Error 1
Which in turn comes down to a problem with the sqrt function imported in cuComplex.h.
A solution is to edit cuComplex.h by changing the imported version #import <math.h> to #import and add a “using std::sqrt” to the function that calls sqrt.
I have added my edited version with comments (// EDITIED BY J. KASTRUP) on the three lines I have edited in order to make it work.
Can this fix be added to the next update?
NOTE: I have not tested the cuComplex functions after the edit since I’m not using them.
Other info:
OS: Ubuntu 10.04 (64 bit)
CUDA toolkit: 4.0
Driver: Dev driver for linux 270.41.19
Cusp: v0.2.0.
* Copyright 1993-2011 NVIDIA Corporation. All rights reserved.
* NOTICE TO LICENSEE:
* This source code and/or documentation ("Licensed Deliverables") are
* subject to NVIDIA intellectual property rights under U.S. and
* international Copyright laws.
* These Licensed Deliverables contained herein is PROPRIETARY and
* CONFIDENTIAL to NVIDIA and is being provided under the terms and
* conditions of a form of NVIDIA software license agreement by and
* between NVIDIA and Licensee ("License Agreement") or electronically
* accepted by Licensee. Notwithstanding any terms or conditions to
* the contrary in the License Agreement, reproduction or disclosure
* of the Licensed Deliverables to any third party without the express
* written consent of NVIDIA is prohibited.
* NOTWITHSTANDING ANY TERMS OR CONDITIONS TO THE CONTRARY IN THE
* LICENSE AGREEMENT, NVIDIA MAKES NO REPRESENTATION ABOUT THE
* SUITABILITY OF THESE LICENSED DELIVERABLES FOR ANY PURPOSE. IT IS
* PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED WARRANTY OF ANY KIND.
* NVIDIA DISCLAIMS ALL WARRANTIES WITH REGARD TO THESE LICENSED
* DELIVERABLES, INCLUDING ALL IMPLIED WARRANTIES OF MERCHANTABILITY,
* NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE.
* LICENSE AGREEMENT, IN NO EVENT SHALL NVIDIA BE LIABLE FOR ANY
* SPECIAL, INDIRECT, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, OR ANY
* DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
* WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS
* ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE
* OF THESE LICENSED DELIVERABLES.
* U.S. Government End Users. These Licensed Deliverables are a
* "commercial item" as that term is defined at 48 C.F.R. 2.101 (OCT
* 1995), consisting of "commercial computer software" and "commercial
* computer software documentation" as such terms are used in 48
* C.F.R. 12.212 (SEPT 1995) and is provided to the U.S. Government
* only as a commercial end item. Consistent with 48 C.F.R.12.212 and
* 48 C.F.R. 227.7202-1 through 227.7202-4 (JUNE 1995), all
* U.S. Government End Users acquire the Licensed Deliverables with
* only those rights set forth herein.
* Any use of the Licensed Deliverables in individual and commercial
* software must include, in the user documentation and internal
* comments to the code, the above Disclaimer and U.S. Government End
* Users Notice.
#if !defined(CU_COMPLEX_H_)
#define CU_COMPLEX_H_
#if defined(__cplusplus)
extern "C" {
#endif /* __cplusplus */
//#include <math.h> // import fabsf, sqrt // EDITED BY J. KASTRUP
#include <cmath> // EDITED BY J. KASTRUP
#include "vector_types.h"
typedef float2 cuFloatComplex;
__host__ __device__ static __inline__ float cuCrealf (cuFloatComplex x)
return x.x;
__host__ __device__ static __inline__ float cuCimagf (cuFloatComplex x)
return x.y;
__host__ __device__ static __inline__ cuFloatComplex make_cuFloatComplex
(float r, float i)
cuFloatComplex res;
res.x = r;
res.y = i;
return res;
__host__ __device__ static __inline__ cuFloatComplex cuConjf (cuFloatComplex x)
return make_cuFloatComplex (cuCrealf(x), -cuCimagf(x));
__host__ __device__ static __inline__ cuFloatComplex cuCaddf (cuFloatComplex x,
cuFloatComplex y)
return make_cuFloatComplex (cuCrealf(x) + cuCrealf(y),
cuCimagf(x) + cuCimagf(y));
__host__ __device__ static __inline__ cuFloatComplex cuCsubf (cuFloatComplex x,
cuFloatComplex y)
return make_cuFloatComplex (cuCrealf(x) - cuCrealf(y),
cuCimagf(x) - cuCimagf(y));
/* This implementation could suffer from intermediate overflow even though
* the final result would be in range. However, various implementations do
* not guard against this (presumably to avoid losing performance), so we
* don't do it either to stay competitive.
__host__ __device__ static __inline__ cuFloatComplex cuCmulf (cuFloatComplex x,
cuFloatComplex y)
cuFloatComplex prod;
prod = make_cuFloatComplex ((cuCrealf(x) * cuCrealf(y)) -
(cuCimagf(x) * cuCimagf(y)),
(cuCrealf(x) * cuCimagf(y)) +
(cuCimagf(x) * cuCrealf(y)));
return prod;
/* This implementation guards against intermediate underflow and overflow
* by scaling. Such guarded implementations are usually the default for
* complex library implementations, with some also offering an unguarded,
* faster version.
__host__ __device__ static __inline__ cuFloatComplex cuCdivf (cuFloatComplex x,
cuFloatComplex y)
cuFloatComplex quot;
float s = fabsf(cuCrealf(y)) + fabsf(cuCimagf(y));
float oos = 1.0f / s;
float ars = cuCrealf(x) * oos;
float ais = cuCimagf(x) * oos;
float brs = cuCrealf(y) * oos;
float bis = cuCimagf(y) * oos;
s = (brs * brs) + (bis * bis);
oos = 1.0f / s;
quot = make_cuFloatComplex (((ars * brs) + (ais * bis)) * oos,
((ais * brs) - (ars * bis)) * oos);
return quot;
* We would like to call hypotf(), but it's not available on all platforms.
* This discrete implementation guards against intermediate underflow and
* overflow by scaling. Otherwise we would lose half the exponent range.
* There are various ways of doing guarded computation. For now chose the
* simplest and fastest solution, however this may suffer from inaccuracies
* if sqrt and division are not IEEE compliant.
__host__ __device__ static __inline__ float cuCabsf (cuFloatComplex x)
float a = cuCrealf(x);
float b = cuCimagf(x);
float v, w, t;
a = fabsf(a);
b = fabsf(b);
if (a > b) {
v = a;
w = b;
} else {
v = b;
w = a;
t = w / v;
t = 1.0f + t * t;
t = v * sqrtf(t);
if ((v == 0.0f) || (v > 3.402823466e38f) || (w > 3.402823466e38f)) {
t = v + w;
return t;
/* Double precision */
typedef double2 cuDoubleComplex;
__host__ __device__ static __inline__ double cuCreal (cuDoubleComplex x)
return x.x;
__host__ __device__ static __inline__ double cuCimag (cuDoubleComplex x)
return x.y;
__host__ __device__ static __inline__ cuDoubleComplex make_cuDoubleComplex
(double r, double i)
cuDoubleComplex res;
res.x = r;
res.y = i;
return res;
__host__ __device__ static __inline__ cuDoubleComplex cuConj(cuDoubleComplex x)
return make_cuDoubleComplex (cuCreal(x), -cuCimag(x));
__host__ __device__ static __inline__ cuDoubleComplex cuCadd(cuDoubleComplex x,
cuDoubleComplex y)
return make_cuDoubleComplex (cuCreal(x) + cuCreal(y),
cuCimag(x) + cuCimag(y));
__host__ __device__ static __inline__ cuDoubleComplex cuCsub(cuDoubleComplex x,
cuDoubleComplex y)
return make_cuDoubleComplex (cuCreal(x) - cuCreal(y),
cuCimag(x) - cuCimag(y));
__host__ __device__ static __inline__ cuDoubleComplex cuCmul(cuDoubleComplex x,
cuDoubleComplex y)
cuDoubleComplex prod;
prod = make_cuDoubleComplex ((cuCreal(x) * cuCreal(y)) -
(cuCimag(x) * cuCimag(y)),
(cuCreal(x) * cuCimag(y)) +
(cuCimag(x) * cuCreal(y)));
return prod;
* faster version.
__host__ __device__ static __inline__ cuDoubleComplex cuCdiv(cuDoubleComplex x,
cuDoubleComplex y)
cuDoubleComplex quot;
double s = (fabs(cuCreal(y))) + (fabs(cuCimag(y)));
double oos = 1.0 / s;
double ars = cuCreal(x) * oos;
double ais = cuCimag(x) * oos;
double brs = cuCreal(y) * oos;
double bis = cuCimag(y) * oos;
oos = 1.0 / s;
quot = make_cuDoubleComplex (((ars * brs) + (ais * bis)) * oos,
return quot;
* by scaling. Otherwise we would lose half the exponent range. There are
* various ways of doing guarded computation. For now chose the simplest
* and fastest solution, however this may suffer from inaccuracies if sqrt
* and division are not IEEE compliant.
__host__ __device__ static __inline__ double cuCabs (cuDoubleComplex x)
using std::sqrt; // EDITED BY J. KASTRUP
double a = cuCreal(x);
double b = cuCimag(x);
double v, w, t;
a = fabs(a);
b = fabs(b);
if (a > b) {
v = a;
w = b;
} else {
v = b;
w = a;
t = w / v;
t = 1.0 + t * t;
t = v * sqrt(t);
if ((v == 0.0) ||
(v > 1.79769313486231570e+308) || (w > 1.79769313486231570e+308)) {
t = v + w;
return t;
/* aliases */
typedef cuFloatComplex cuComplex;
__host__ __device__ static __inline__ cuComplex make_cuComplex (float x,
float y)
return make_cuFloatComplex (x, y);
/* float-to-double promotion */
__host__ __device__ static __inline__ cuDoubleComplex cuComplexFloatToDouble
(cuFloatComplex c)
return make_cuDoubleComplex ((double)cuCrealf(c), (double)cuCimagf(c));
__host__ __device__ static __inline__ cuFloatComplex cuComplexDoubleToFloat
(cuDoubleComplex c)
return make_cuFloatComplex ((float)cuCreal(c), (float)cuCimag(c));
__host__ __device__ static __inline__ cuComplex cuCfmaf( cuComplex x, cuComplex y, cuComplex d)
float real_res;
float imag_res;
real_res = (cuCrealf(x) * cuCrealf(y)) + cuCrealf(d);
imag_res = (cuCrealf(x) * cuCimagf(y)) + cuCimagf(d);
real_res = -(cuCimagf(x) * cuCimagf(y)) + real_res;
imag_res = (cuCimagf(x) * cuCrealf(y)) + imag_res;
return make_cuComplex(real_res, imag_res);
__host__ __device__ static __inline__ cuDoubleComplex cuCfma( cuDoubleComplex x, cuDoubleComplex y, cuDoubleComplex d)
double real_res;
double imag_res;
real_res = (cuCreal(x) * cuCreal(y)) + cuCreal(d);
imag_res = (cuCreal(x) * cuCimag(y)) + cuCimag(d);
real_res = -(cuCimag(x) * cuCimag(y)) + real_res;
imag_res = (cuCimag(x) * cuCreal(y)) + imag_res;
return make_cuDoubleComplex(real_res, imag_res);
#endif /* !defined(CU_COMPLEX_H_) */
cuComplex.h (11.5 KB)
