Hi Nvidia, I have the following code:
typedef struct
float32_t x;
float32_t y;
dwRenderEngineColorRGBA color;
} Point2D;
Point2D points[1];
points[0].x = xQ;
points[0].y = yQ; //getRandom();
points[0].color = {1.0f, 0.0f, 0.0f, 0.3f};
dwRenderEngine_setPointSize(2.1f, m_renderEngine);
dwRenderEngine_setColor({0.0f, 1.0f, 1.0f, 1.0f}, m_renderEngine);
dwRenderEngine_setColorByValue(DW_RENDER_ENGINE_COLOR_BY_VALUE_MODE_ATTRIBUTE_RGBA, 1.0f, m_renderEngine);
dwRenderEngine_render(DW_RENDER_ENGINE_PRIMITIVE_TYPE_POINTS_2D,
points,
sizeof(points),
0,
1,
m_renderEngine);
dwRenderEngine_setColor({1.0f, 0.0f, 0.0f, 1.0f}, m_renderEngine);
dwRenderEngine_setColorByValue(DW_RENDER_ENGINE_COLOR_BY_VALUE_MODE_INTENSITY, 1.0f, m_renderEngine);
with this code, I can do this:
but I do not know how to put the camera image in the background along with the mask, so I comment the following code:
dwVector2f range{};
range.x = m_imgGl->prop.width;
range.y = m_imgGl->prop.height;
CHECK_DW_ERROR(dwRenderEngine_setCoordinateRange2D(range, m_renderEngine));
CHECK_DW_ERROR(dwRenderEngine_renderImage2D(m_imgGl, {0.0f, 0.0f, range.x, range.y}, m_renderEngine));
when I remove the comment, the points are rendered in zero positions, i have the following image
Thank you, my English is in the progress.
