Hi1
I am flashing my new custom board using this method
but i see in the terminal that i got stucked at Nvflash 4.13.0000 started. i think it took about 20 minutes and do nothing so i disconnect it as on the manual it is written that it should be completed with in 10 minutes.
it also do not show anything on its serial terminal
these are logs shown in terminal
linux4tegra@ubuntu:~/Linux_for_Tegra$ sudo ./flash.sh jetson-tk1 mmcblk0p1
copying bctfile(/home/linux4tegra/Linux_for_Tegra/bootloader/ardbeg/BCT/PM375_Hynix_2GB_H5TC4G63AFR_H5TC4G63CFR_RDA_924MHz.cfg)… done.
copying bootloader(/home/linux4tegra/Linux_for_Tegra/bootloader/ardbeg/u-boot.bin)… done.
populating kernel to rootfs… done.
populating jetson-tk1_extlinux.conf.emmc to rootfs… done.
done.
Making system.img…
populating rootfs from /home/linux4tegra/Linux_for_Tegra/rootfs … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image…
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 3682304( 899 blks) ==> 28:3682316
1: SKP: 57344( 14 blks) ==> 3682344:57356
2: RAW: 4096( 1 blks) ==> 3682356:4108
3: SKP: 61440( 15 blks) ==> 3686464:61452
4: RAW: 1478656( 361 blks) ==> 3686476:1478668
5: SKP: 32075776( 7831 blks) ==> 5165144:32075788
6: RAW: 3547136( 866 blks) ==> 5165156:3547148
7: SKP: 93310976( 22781 blks) ==> 8712304:93310988
8: RAW: 8192( 2 blks) ==> 8712316:8204
9: SKP: 3665920( 895 blks) ==> 8720520:3665932
10: RAW: 14073856( 3436 blks) ==> 8720532:14073868
11: SKP: 8192( 2 blks) ==> 22794400:8204
12: RAW: 21970944( 5364 blks) ==> 22794412:21970956
13: SKP: 8192( 2 blks) ==> 44765368:8204
14: RAW: 425984( 104 blks) ==> 44765380:425996
15: SKP: 4096( 1 blks) ==> 45191376:4108
16: RAW: 16605184( 4054 blks) ==> 45191388:16605196
17: SKP: 8192( 2 blks) ==> 61796584:8204
18: RAW: 2609152( 637 blks) ==> 61796596:2609164
19: SKP: 8192( 2 blks) ==> 64405760:8204
20: RAW: 17465344( 4264 blks) ==> 64405772:17465356
21: SKP: 4096( 1 blks) ==> 81871128:4108
22: RAW: 32100352( 7837 blks) ==> 81871140:32100364
23: SKP: 159469568( 38933 blks) ==> 113971504:159469580
24: RAW: 8192( 2 blks) ==> 113971516:8204
25: SKP: 268427264( 65534 blks) ==> 113979720:268427276
26: RAW: 8192( 2 blks) ==> 113979732:8204
27: SKP: 268427264( 65534 blks) ==> 113987936:268427276
28: RAW: 8192( 2 blks) ==> 113987948:8204
29: SKP: 268427264( 65534 blks) ==> 113996152:268427276
30: RAW: 8192( 2 blks) ==> 113996164:8204
31: SKP: 939515904( 229374 blks) ==> 114004368:939515916
32: RAW: 8192( 2 blks) ==> 114004380:8204
33: SKP: 57344( 14 blks) ==> 114012584:57356
34: RAW: 4096( 1 blks) ==> 114012596:4108
35: SKP: 61440( 15 blks) ==> 114016704:61452
36: RAW: 614400( 150 blks) ==> 114016716:614412
37: SKP: 32940032( 8042 blks) ==> 114631128:32940044
38: RAW: 3633152( 887 blks) ==> 114631140:3633164
39: SKP: 96899072( 23657 blks) ==> 118264304:96899084
40: RAW: 7618560( 1860 blks) ==> 118264316:7618572
41: SKP: 1066123264( 260284 blks) ==> 125882888:1066123276
42: RAW: 8192( 2 blks) ==> 125882900:8204
43: SKP: 268427264( 65534 blks) ==> 125891104:268427276
44: RAW: 8192( 2 blks) ==> 125891116:8204
45: SKP: 671080448( 163838 blks) ==> 125899320:671080460
46: RAW: 8192( 2 blks) ==> 125899332:8204
47: SKP: 57344( 14 blks) ==> 125907536:57356
48: RAW: 4096( 1 blks) ==> 125907548:4108
49: SKP: 61440( 15 blks) ==> 125911656:61452
50: RAW: 204800( 50 blks) ==> 125911668:204812
51: SKP: 33349632( 8142 blks) ==> 126116480:33349644
52: RAW: 1052672( 257 blks) ==> 126116492:1052684
53: SKP: 99479552( 24287 blks) ==> 127169176:99479564
54: RAW: 12423168( 3033 blks) ==> 127169188:12423180
55: SKP: 2000842752( 488487 blks) ==> 139592368:2000842764
56: RAW: 12288( 3 blks) ==> 139592380:12300
57: SKP: 134205440( 32765 blks) ==> 139604680:134205452
58: RAW: 8192( 2 blks) ==> 139604692:8204
59: SKP: 3665920( 895 blks) ==> 139612896:3665932
60: RAW: 15429632( 3767 blks) ==> 139612908:15429644
61: SKP: 1994162176( 486856 blks) ==> 155042552:1994162188
62: RAW: 8192( 2 blks) ==> 155042564:8204
63: SKP: 57344( 14 blks) ==> 155050768:57356
64: RAW: 4096( 1 blks) ==> 155050780:4108
65: SKP: 61440( 15 blks) ==> 155054888:61452
66: RAW: 4096( 1 blks) ==> 155054900:4108
67: SKP: 33550336( 8191 blks) ==> 155059008:33550348
68: RAW: 8192( 2 blks) ==> 155059020:8204
69: SKP: 100524032( 24542 blks) ==> 155067224:100524044
70: RAW: 81920( 20 blks) ==> 155067236:81932
71: SKP: 2013184000( 491500 blks) ==> 155149168:2013184012
72: RAW: 8192( 2 blks) ==> 155149180:8204
73: SKP: 57344( 14 blks) ==> 155157384:57356
74: RAW: 4096( 1 blks) ==> 155157396:4108
75: SKP: 61440( 15 blks) ==> 155161504:61452
76: RAW: 36864( 9 blks) ==> 155161516:36876
77: SKP: 33517568( 8183 blks) ==> 155198392:33517580
78: RAW: 217088( 53 blks) ==> 155198404:217100
79: SKP: 100315136( 24491 blks) ==> 155415504:100315148
80: RAW: 8192( 2 blks) ==> 155415516:8204
81: SKP: 3665920( 895 blks) ==> 155423720:3665932
82: RAW: 29880320( 7295 blks) ==> 155423732:29880332
83: SKP: 33554432( 8192 blks) ==> 185304064:33554444
84: RAW: 22114304( 5399 blks) ==> 185304076:22114316
85: SKP: 8192( 2 blks) ==> 207418392:8204
86: RAW: 69632( 17 blks) ==> 207418404:69644
87: SKP: 8192( 2 blks) ==> 207488048:8204
88: RAW: 32768( 8 blks) ==> 207488060:32780
89: SKP: 1923923968( 469708 blks) ==> 207520840:1923923980
90: RAW: 8192( 2 blks) ==> 207520852:8204
91: SKP: 57344( 14 blks) ==> 207529056:57356
92: RAW: 4096( 1 blks) ==> 207529068:4108
93: SKP: 61440( 15 blks) ==> 207533176:61452
94: RAW: 913408( 223 blks) ==> 207533188:913420
95: SKP: 32641024( 7969 blks) ==> 208446608:32641036
96: RAW: 3600384( 879 blks) ==> 208446620:3600396
97: SKP: 96931840( 23665 blks) ==> 212047016:96931852
98: RAW: 5341184( 1304 blks) ==> 212047028:5341196
99: SKP: 4096( 1 blks) ==> 217388224:4108
100: RAW: 7024640( 1715 blks) ==> 217388236:7024652
101: SKP: 12288( 3 blks) ==> 224412888:12300
102: RAW: 90112( 22 blks) ==> 224412900:90124
103: SKP: 12288( 3 blks) ==> 224503024:12300
104: RAW: 94208( 23 blks) ==> 224503036:94220
105: SKP: 12288( 3 blks) ==> 224597256:12300
106: RAW: 90112( 22 blks) ==> 224597268:90124
107: SKP: 12288( 3 blks) ==> 224687392:12300
108: RAW: 4096( 1 blks) ==> 224687404:4108
109: SKP: 4096( 1 blks) ==> 224691512:4108
110: RAW: 81920( 20 blks) ==> 224691524:81932
111: SKP: 12288( 3 blks) ==> 224773456:12300
112: RAW: 90112( 22 blks) ==> 224773468:90124
113: SKP: 12288( 3 blks) ==> 224863592:12300
114: RAW: 94208( 23 blks) ==> 224863604:94220
115: SKP: 12288( 3 blks) ==> 224957824:12300
116: RAW: 90112( 22 blks) ==> 224957836:90124
117: SKP: 12288( 3 blks) ==> 225047960:12300
118: RAW: 4096( 1 blks) ==> 225047972:4108
119: SKP: 4096( 1 blks) ==> 225052080:4108
120: RAW: 81920( 20 blks) ==> 225052092:81932
121: SKP: 12288( 3 blks) ==> 225134024:12300
122: RAW: 90112( 22 blks) ==> 225134036:90124
123: SKP: 12288( 3 blks) ==> 225224160:12300
124: RAW: 19161088( 4678 blks) ==> 225224172:19161100
125: SKP: 34635776( 8456 blks) ==> 244385272:34635788
126: RAW: 3289088( 803 blks) ==> 244385284:3289100
127: SKP: 1942867968( 474333 blks) ==> 247674384:1942867980
– Total: -----------------------------------------------------------
128 CHUNK 15032385536(3670016 blks) ==> 247674396(60467 blks)
done.
system.img built successfully.
copying dtbfile(/home/linux4tegra/Linux_for_Tegra/kernel/dtb/tegra124-jetson_tk1-pm375-000-c00-00.dtb)… done.
copying cfgfile(/home/linux4tegra/Linux_for_Tegra/bootloader/ardbeg/cfg/gnu_linux_fastboot_emmc_full.cfg) to flash.cfg… done.
creating gpt(ppt.img)…
*** GPT Parameters ***
Device Sector Size ------- 512
device size -------------- 15766388736
bootpart size ------------ 8388608
userpart size ------------ 15758000128
Erase Block Size --------- 2097152
FS Buffer size ----------- 4096
Partition Config file ---- flash.cfg
Visible partition flag — GP1
Primary GPT output ------- PPT->ppt.img
Secondary GPT output ----- GPT->gpt.img
Target device name ------- none
*** PARTITION LAYOUT(20 partitions) ***
[ BCT] BH 0 16383 8.0MiB
[ PPT] UH 0 4095 2.0MiB ppt.img
[ PT] UH 4096 8191 2.0MiB
[ EBT] UH 8192 16383 4.0MiB u-boot.bin
[ LNX] UH 16384 49151 16.0MiB
[ SOS] UH 49152 61439 6.0MiB
[ NVC] UH 61440 65535 2.0MiB
[ MPB] UH 65536 77823 6.0MiB
[ MBP] UH 77824 90111 6.0MiB
[ GP1] UH 90112 94207 2.0MiB
[ APP] UV 94208 29454335 14336.0MiB system.img
[ DTB] UV 29454336 29462527 4.0MiB tegra124-jetson_tk1-pm375-000-c00-00.dtb
[ EFI] UV 29462528 29593599 64.0MiB
[ USP] UV 29593600 29601791 4.0MiB
[ TP1] UV 29601792 29609983 4.0MiB
[ TP2] UV 29609984 29618175 4.0MiB
[ TP3] UV 29618176 29626367 4.0MiB
[ WB0] UV 29626368 29630463 2.0MiB
[ UDA] UV 29630464 30773247 558.0MiB
[ GPT] UH 30773248 30777343 2.0MiB gpt.img
copying flasher(/home/linux4tegra/Linux_for_Tegra/bootloader/ardbeg/fastboot.bin)… done.
Existing flashapp(/home/linux4tegra/Linux_for_Tegra/bootloader/nvflash) reused.
*** Flashing target device started. ***
./nvflash --bct PM375_Hynix_2GB_H5TC4G63AFR_H5TC4G63CFR_RDA_924MHz.cfg --setbct --configfile flash.cfg --create --bl fastboot.bin --odmdata 0x6009C000 --go
