Problem in generating .cfg from .dtsi file
I use ‘Jetson_Xavier_NX_Pinmux_Configuration_Template_v1.06.xlsm’ generate three .dtsi files (without any changes). And execute the command below:
python ./pinmux-dts2cfg.py --pinmux
addr_info.txt gpio_addr_info.txt por_val.txt
–mandatory_pinmux_file mandatory_pinmux.txt
tegra19x-jetson_xavier_nx_module-gpio-default.dtsi
tegra19x-jetson_xavier_nx_module-pinmux.dtsi
1.0
> galen.cfg
But the generated file only contains contents below:
## Pinmux version 1.0
## Input pinmux file name: tegra19x-jetson_xavier_nx_module-gpio-default.dtsi
## Input gpio file name: tegra19x-jetson_xavier_nx_module-pinmux.dtsi
## Generation date: 2021-11-25 13:39
## PLEASE DO NOT EDIT THIS FILE
## This is autogenerated file using the script pinmux-dts2cfg.py
pinmux.major = 1;
pinmux.minor = 0;
Is it correct?
Please put pinmux dtsi priot to gpio-default dtsi.
