problem in managing simple data structures in kernel
Hi everybody,
I’m currently working on binary trees for optimization methods and I need to implement a simple data structure on GPU such as FIFO or LIFO. This is a simple implementation where I try to add an element in the structure.
/* sp_t represents an element with different attributes */
typedef int* sp_t;
/* pool of elements */
typedef struct
{  int n;	/* number of  elements */
   int capacity;  /* maximum size of the pool*/
   sp_t *sp; /* array of elements */
}  pool_t;
#define CAPACITY 100
// GPU code
__device__ void p_init(pool_t* pool){
   pool->n = 0;
__device__ void p_add(pool_t* pool, sp_t sp){
  pool->sp[pool->n++] = sp;
__global__ void kernel_test (pool_t* pool,  sp_t sol){
  p_init(pool);
  p_add(pool, sol);
// host code
int n=100;
sp_t sp = malloc ((n+4) * sizeof(int)); // element sp is an array of (n+4) int
init(sp,n); // initialize sp
sp_t sp_d;
cutilSafeCall(cudaMalloc((void**)&sp_d, (n+4) * sizeof(int)));
cutilSafeCall(cudaMemcpy(sp_d, sp, sizeof(pool_t), cudaMemcpyHostToDevice));
pool_t pool_host={0,CAPACITY,NULL};
cutilSafeCall(cudaMalloc((void**)&pool_host.sp, CAPACITY * (n + 4) * sizeof(int)));
pool_t* pool_device;
cutilSafeCall(cudaMalloc((void**)&pool_device, sizeof(pool_t)));
cutilSafeCall(cudaMemcpy(pool_device, &pool_host, sizeof(pool_t), cudaMemcpyHostToDevice));
kernel_test<<<1,1>>>(pool_device, sp_d);
pool_t* pool;
init(pool);
cutilSafeCall(cudaMemcpy(pool_device, pool, sizeof(pool_t), cudaMemcpyHostToDevice));
// HERE IS THE BUG
printElement(pool->sp[0]);
First, during the compilation process, I receive a Warning: Cannot tell what pointer points to, assuming global memory space for the instruction inside the function p_add_device.
__device__ void p_add_device(pool_t* pool, sp_t sp){
Second, in the host code, when I try to print my element with the method printElement(pool->sp[0]), I get a segmentation fault.
As a consequence, I wonder what I am doing wrong in this simple example. Is it impossible to get a structure which has a pointer to another structure in the GPU side ?
Thanks in advance for helping me.
