I tried copy a structure to constant memory using cudaMemcpyToSymbolAsync in my mac laptop that has GTX 650M (CC 3.0). I compiled it using -gencode arch=compute_20,code=sm_20 and everytime i tried to run, it showed this msg: CUDA Runtime API error 13: invalid device symbol. (i’m using cudaCheckErrors from SDK). the copy was done as following code
for(int dev = 0; dev < ndevs; ++dev) { //ndevs is number of devices available
checkCudaErrors( cudaSetDevice(dev) );
checkCudaErrors(
cudaMemcpyToSymbolAsync(cmem, &cmem_host[dev], sizeof(ConstMem), 0, //my cmem_host is array of structure resided in the host memory
cudaMemcpyHostToDevice)
but if i run it in my workstation that GTX690 (CC 2.0) running on Ubuntu 10.04LTS, It run well without any error msg.
is there any way to fix this? is because of the cuda in macosx?
thank you
