Problem in passing an integer array to global function and device function
I’m trying to pass an integer array to a CUDA global routine, which then passes the array as a parameter to a CUDA device routine. (This is actually part of a numerical integration routine I’m working on, but I’ve pared down that code to this simpler one which still produces the same error.)
I can’t figure out why the integer array is not reproduced correctly in the output of the global routine “routine1” and the device routine “routine2”. Note I’m using the function cuPrintf() to output the arrays within these device functions. Also I’m not clear why the integer array is changed when it is copied back from the device memory into the host array h_conn2. I’m running the code on a Tesla C1060, compute capability 1.3.
Any suggestions on how to improve/fix this code so that all three outputs match the original integer array would be greatly appreciated. Thanks!
Dan
1 #include <math.h>
2 #include <time.h>
3 #include <stdlib.h>
4 #include “cuPrintf.cuh”
5 #include “cuPrintf.cu”
6
7 #include <cuda_runtime.h>
8
9 global void routine1(int *connect, int unit_size){
10 device void routine2(int connect1, int unit_sz);
11
12 int i = blockDim.x
blockIdx.x + threadIdx.x;
13 if (i==0){
14 for (int lo=0;lo<unit_size;lo++) cuPrintf(“routine1 %i %i\n”,lo,connec t[lo]);
15 }
16 routine2(connect,unit_size);
17
18 }
19
20 device void routine2(int connect1, int unit_sz){
21
22 int i = blockDim.x
23 if (i==0){
24 for (int lo=0;lo<unit_sz;lo++) cuPrintf(“routine2 %i %i\n”,lo,connect1 [lo]);
25 }
26 }
27
28 int main(void){
29
30 cudaPrintfInit();
31 int unit_size = 4;
32
33 int *h_conn = (int *)malloc(unit_size);
34 int *h_conn2 = (int *)malloc(unit_size);
35 for (int lo=0;lo<unit_size;lo++) h_conn[lo] = lo;
36 for (int lo=0;lo<unit_size;lo++)
printf(“host initial conn[%i] = %i\n”,lo,h_conn[lo]);
38
39 cudaError_t err = cudaSuccess;
40
41 int *d_conn = NULL;
42 err = cudaMalloc((void **)&d_conn,unit_size);
43
44 err = cudaMemcpy(d_conn,h_conn,unit_size,cudaMemcpyHostToDevice);
45
46 int threadsPerBlock = 4;
47 int blocksPerGrid = (unit_size + threadsPerBlock - 1)/ threadsPerBlock;
48 printf(“CUDA kernel launch with %d blocks of %d threads\n”,blocksPerGrid ,threadsPerBlock);
49 routine1<<<blocksPerGrid , threadsPerBlock>>>(d_conn, unit_size);
50
51 cudaPrintfDisplay(stdout,true);
52 cudaPrintfEnd();
53
54 err = cudaGetLastError();
55
56 err = cudaMemcpy(h_conn2,d_conn,unit_size,cudaMemcpyDeviceToHost);
57
58 for (int lo=0;lo<unit_size;lo++)
59 printf(“host final conn[%i] = %i\n”,lo,h_conn2[lo]);
60
61 err = cudaFree(d_conn);
62 free(h_conn);
63 free(h_conn2);
64
65 err = cudaDeviceReset();
66 return 0;
67
68 }
Output:
host initial conn[0] = 0
host initial conn[1] = 1
host initial conn[2] = 2
host initial conn[3] = 3
CUDA kernel launch with 1 blocks of 4 threads
[0, 0]: routine1 0 0
[0, 0]: routine1 1 1009519056
[0, 0]: routine1 2 1017692322
[0, 0]: routine1 3 1023114360
[0, 0]: routine2 0 0
[0, 0]: routine2 1 1009519056
[0, 0]: routine2 2 1017692322
[0, 0]: routine2 3 1023114360
host final conn[0] = 0
host final conn[1] = 0
host final conn[2] = 0
host final conn[3] = 0
  1. add proper cuda error checking to your code (google “proper cuda error checking”, study the first hit)
  2. run your code with cuda-memcheck
  3. You may be confused about how functions like malloc work. The size parameter passed to malloc (and cudaMalloc) is a size in bytes to be allocated. So if you pass unit_size = 4, you will get 4 bytes allocated, i.e. enough space for one 32-bit int quantity. But your kernel is using unit_size as if it were a number of int quantities that can be read and printed out. This won’t work, and cuda-memcheck will show that you are accessing arrays out-of-bounds.
So if you change all of your “unit_size” instances in every malloc, cudaMalloc, and cudaMemcpy operation to:
unit_size*sizeof(int)
You will get better results.
And by the way, the line numbers on your code don’t help and should not be used when posting code in a question. Instead post the code as-is and mark it as a code block. There is a link in the edit pane to do this (select the entire posted code section, then press the </> button).
Thanks a bunch, txbob. Sorry about the line numbers, I’ll avoid those in the future. I followed your advice and was able to get my code working properly. I also put the error checking in place in my main numerical integration code, as well as using cuda-memcheck with it, and was able to track down another bug. I’ll be sure to use these in developing codes in the future – Dan
