• Hardware Platform (Jetson / GPU) • DeepStream Version • Hardware Platform: Jetson AGX Orin • DeepStream Version: 7.0 • JetPack Version: (6.0+b106 and 6.0+b87 both are installed) L4T 36.3.0 • TensorRT Version: 8.6.2
Hello, i am using deepstream-app sample app where i am using rtsp input source and rtsp output using udp sink but i am facing an issue where sometimes i am getting proper 30 fps and sometimes 0 fps even without using any model just as you can see in following image.
here as you can see i’m using same config file but first i was getting 30fps then suddenly 0 fps i have not changed anything in between, these are consecutive executions
