Hardware - GPU (NVIDIA GeForce RTX 3050 Ti Laptop GPU)
Hardware - CPU (Intel® Core™ i7)
Operating System: Windows
Riva Version: latest
hi ,
i purchased this course https://courses.nvidia.com/courses/course-v1:DLI+S-FX-04+V1/
and i followed the notebooks in it
i tried to start riva speeech by typing this command in git bash (./riva_start.sh config.sh
but getting this error:
moham@Mohamed_Salama MINGW64 ~/Desktop/Nvidia_course/riva_quickstart_v2.3.0
$ ./riva_start.sh config.sh
Starting Riva Speech Services. This may take several minutes depending on the number of models deployed.
9e366e5c90a2c640d777343a946e978f23ba576279d3a700d2485ec2490d670e
OCI runtime exec failed: exec failed: unable to start container process: exec: "C:/Program Files/Git/usr/bin/grpc_health_probe": stat C:/Program Files/Git/usr/bin/grpc_health_probe: no such file or directory: unknown
Waiting for Riva server to load all models...retrying in 10 seconds
Health ready check failed.
Check Riva logs with: docker logs riva-speech
docker logs:
2023-07-05 11:12:20 ERROR: ld.so: object '[FATAL' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:20 ERROR: ld.so: object 'tini' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:20 ERROR: ld.so: object '(8)]' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:20 ERROR: ld.so: object 'exec' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:20 ERROR: ld.so: object 'C' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:20 ERROR: ld.so: object '/Program' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:20 ERROR: ld.so: object 'Files/Git/usr/bin/bash' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:20 ERROR: ld.so: object 'failed' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:20 ERROR: ld.so: object 'No' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:20 ERROR: ld.so: object 'such' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:20 ERROR: ld.so: object 'file' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:20 ERROR: ld.so: object 'or' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:20 ERROR: ld.so: object 'directory' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:20
2023-07-05 11:12:20 ==========================
2023-07-05 11:12:20 === Riva Speech Skills ===
2023-07-05 11:12:20
2023-07-05 11:12:20 NVIDIA Release 22.06 (build 40051835)
2023-07-05 11:12:20 Riva Speech Server Version 2.3.0
2023-07-05 11:12:20
2023-07-05 11:12:20 Copyright (c) 2018-2022, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
2023-07-05 11:12:20
2023-07-05 11:12:20 Various files include modifications (c) NVIDIA CORPORATION & AFFILIATES. All rights reserved.
2023-07-05 11:12:20
2023-07-05 11:12:20 This container image and its contents are governed by the NVIDIA Deep Learning Container License.
2023-07-05 11:12:20 By pulling and using the container, you accept the terms and conditions of this license:
2023-07-05 11:12:20 https://developer.nvidia.com/ngc/nvidia-deep-learning-container-license
2023-07-05 11:12:20
2023-07-05 11:12:20 NOTE: The SHMEM allocation limit is set to the default of 64MB. This may be
2023-07-05 11:12:20 insufficient for Riva Speech Server. NVIDIA recommends the use of the following flags:
2023-07-05 11:12:20 docker run --gpus all --ipc=host --ulimit memlock=-1 --ulimit stack=67108864 ...
2023-07-05 11:12:20
2023-07-05 11:12:21 > Riva waiting for Triton server to load all models...retrying in 1 second
2023-07-05 11:12:21 ERROR: ld.so: object '[FATAL' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:21 ERROR: ld.so: object 'tini' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:21 ERROR: ld.so: object '(8)]' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:21 ERROR: ld.so: object 'exec' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:21 ERROR: ld.so: object 'C' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:21 ERROR: ld.so: object '/Program' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:21 ERROR: ld.so: object 'Files/Git/usr/bin/bash' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:21 ERROR: ld.so: object 'failed' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:21 ERROR: ld.so: object 'No' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:21 ERROR: ld.so: object 'such' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:21 ERROR: ld.so: object 'file' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:21 ERROR: ld.so: object 'or' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:21 ERROR: ld.so: object 'directory' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:21 I0705 08:12:21.057096 95 metrics.cc:623] Collecting metrics for GPU 0: NVIDIA GeForce RTX 3050 Ti Laptop GPU
2023-07-05 11:12:21 I0705 08:12:21.058383 95 tritonserver.cc:1932]
2023-07-05 11:12:21 +----------------------------------+----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------+
2023-07-05 11:12:21 | Option | Value |
2023-07-05 11:12:21 | server_id | triton |
2023-07-05 11:12:21 | server_version | 2.19.0 |
2023-07-05 11:12:21 | server_extensions | classification sequence model_repository model_repository(unload_dependents) schedule_policy model_configuration system_shared_memory cuda_shared_memory binary_tensor_data statistics trace |
2023-07-05 11:12:21 | model_control_mode | MODE_NONE |
2023-07-05 11:12:21 | strict_model_config | 1 |
2023-07-05 11:12:21 | rate_limit | OFF |
2023-07-05 11:12:21 | pinned_memory_pool_byte_size | 268435456 |
2023-07-05 11:12:21 | cuda_memory_pool_byte_size{0} | 1000000000 |
2023-07-05 11:12:21 | response_cache_byte_size | 0 |
2023-07-05 11:12:21 | min_supported_compute_capability | 6.0 |
2023-07-05 11:12:21 | strict_readiness | 1 |
2023-07-05 11:12:21 | exit_timeout | 30 |
2023-07-05 11:12:21
2023-07-05 11:12:21 I0705 08:12:21.058428 95 server.cc:249] No server context available. Exiting immediately.
2023-07-05 11:12:21 error: creating server: Invalid argument - --model-repository must be specified
2023-07-05 11:12:22 ERROR: ld.so: object '[FATAL' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:22 ERROR: ld.so: object 'tini' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:22 ERROR: ld.so: object '(8)]' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:22 ERROR: ld.so: object 'exec' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:22 ERROR: ld.so: object 'C' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:22 ERROR: ld.so: object '/Program' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:22 ERROR: ld.so: object 'Files/Git/usr/bin/bash' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:22 ERROR: ld.so: object 'failed' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:22 ERROR: ld.so: object 'No' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:22 ERROR: ld.so: object 'such' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:22 ERROR: ld.so: object 'file' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:22 ERROR: ld.so: object 'or' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:22 ERROR: ld.so: object 'directory' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:22 > Riva waiting for Triton server to load all models...retrying in 1 second
2023-07-05 11:12:23 > Riva waiting for Triton server to load all models...retrying in 1 second
2023-07-05 11:12:22 W0705 08:12:22.061030 95 metrics.cc:401] Unable to get power limit for GPU 0. Status:Success, value:0.000000
2023-07-05 11:12:23 ERROR: ld.so: object '[FATAL' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:23 ERROR: ld.so: object 'tini' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:23 ERROR: ld.so: object '(8)]' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:23 ERROR: ld.so: object 'exec' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:23 ERROR: ld.so: object 'C' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:23 ERROR: ld.so: object '/Program' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:23 ERROR: ld.so: object 'Files/Git/usr/bin/bash' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:23 ERROR: ld.so: object 'failed' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:23 ERROR: ld.so: object 'No' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:23 ERROR: ld.so: object 'such' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:23 ERROR: ld.so: object 'file' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:23 ERROR: ld.so: object 'or' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:23 ERROR: ld.so: object 'directory' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
2023-07-05 11:12:24 /opt/riva/bin/start-riva: line 1: kill: (95) - No such process
2023-07-05 11:12:24 > Triton server died before reaching ready state. Terminating Riva startup.
2023-07-05 11:12:24 Check Triton logs with: docker logs
Please help me to cater this problem
