Hi. Thanks for your help.
Yes I did according to the notebook.
This is my spec file for 10 epochs:
random_seed: 42
model_config {
model_input_width: 640
model_input_height: 640
model_input_channels: 3
num_layers: 18
all_projections: true
arch: "resnet"
use_batch_norm: False
training_precision {
backend_floatx: FLOAT32
training_config {
batch_size: 2
epochs: 10
log_summary_steps: 10
checkpoint_interval: 5
loss: "cross_dice_sum"
learning_rate:0.0001
regularizer {
type: L2
weight: 2e-5
optimizer {
adam {
epsilon: 9.99999993923e-09
beta1: 0.899999976158
beta2: 0.999000012875
dataset_config {
dataset: "custom"
augment: False
augmentation_config {
spatial_augmentation {
hflip_probability : 0.5
vflip_probability : 0.5
crop_and_resize_prob : 0.5
brightness_augmentation {
delta: 0.2
input_image_type: "color"
train_images_path:"/workspace/tlt/tlt-experiments/all_segmentation_approaches/corrosion_dataset_temp/images/train/"
train_masks_path:"/workspace/tlt/tlt-experiments/all_segmentation_approaches/corrosion_dataset_temp/masks/train"
val_images_path:"/workspace/tlt/tlt-experiments/all_segmentation_approaches/corrosion_dataset_temp/images/val"
val_masks_path:"/workspace/tlt/tlt-experiments/all_segmentation_approaches/corrosion_dataset_temp/masks/val"
test_images_path:"/workspace/tlt/tlt-experiments/all_segmentation_approaches/corrosion_dataset_temp/images/test"
data_class_config {
target_classes {
mapping_class: "foreground"
label_id: 1
target_classes {
mapping_class: "background"
label_id: 0
and this is training log:
Loading experiment spec at /workspace/tlt/local_dir/tlt_unet_corrosion_resnet18/unpruned_model/final_spec.txt.
Running for 10 Epochs
Epoch: 0/10:, Cur-Step: 0, loss(cross_dice_sum): 1.09276, Running average loss:1.09276, Time taken: 0:00:00 ETA: 0:00:00
Epoch: 0/10:, Cur-Step: 10, loss(cross_dice_sum): 0.48246, Running average loss:0.95171, Time taken: 0:00:00 ETA: 0:00:00
Epoch: 0/10:, Cur-Step: 20, loss(cross_dice_sum): 0.05996, Running average loss:0.54133, Time taken: 0:00:00 ETA: 0:00:00
Epoch: 0/10:, Cur-Step: 30, loss(cross_dice_sum): 0.05802, Running average loss:0.38571, Time taken: 0:00:00 ETA: 0:00:00
Epoch: 0/10:, Cur-Step: 40, loss(cross_dice_sum): 0.05610, Running average loss:0.30553, Time taken: 0:00:00 ETA: 0:00:00
Epoch: 0/10:, Cur-Step: 50, loss(cross_dice_sum): 0.05424, Running average loss:0.25642, Time taken: 0:00:00 ETA: 0:00:00
Epoch: 0/10:, Cur-Step: 60, loss(cross_dice_sum): 0.05247, Running average loss:0.22311, Time taken: 0:00:00 ETA: 0:00:00
Epoch: 0/10:, Cur-Step: 70, loss(cross_dice_sum): 0.05080, Running average loss:0.19895, Time taken: 0:00:00 ETA: 0:00:00
Epoch: 0/10:, Cur-Step: 80, loss(cross_dice_sum): 0.04922, Running average loss:0.18055, Time taken: 0:00:00 ETA: 0:00:00
Epoch: 0/10:, Cur-Step: 90, loss(cross_dice_sum): 0.04774, Running average loss:0.16603, Time taken: 0:00:00 ETA: 0:00:00
Epoch: 0/10:, Cur-Step: 100, loss(cross_dice_sum): 0.04636, Running average loss:0.15424, Time taken: 0:00:00 ETA: 0:00:00
Epoch: 1/10:, Cur-Step: 110, loss(cross_dice_sum): 0.04506, Running average loss:0.04550, Time taken: 0:00:00.351211 ETA: 0:00:03.160900
Epoch: 1/10:, Cur-Step: 120, loss(cross_dice_sum): 0.04384, Running average loss:0.04488, Time taken: 0:00:00.351211 ETA: 0:00:03.160900
Epoch: 1/10:, Cur-Step: 130, loss(cross_dice_sum): 0.04269, Running average loss:0.04428, Time taken: 0:00:00.351211 ETA: 0:00:03.160900
Epoch: 1/10:, Cur-Step: 140, loss(cross_dice_sum): 0.04163, Running average loss:0.04371, Time taken: 0:00:00.351211 ETA: 0:00:03.160900
Epoch: 1/10:, Cur-Step: 150, loss(cross_dice_sum): 0.04062, Running average loss:0.04316, Time taken: 0:00:00.351211 ETA: 0:00:03.160900
Epoch: 1/10:, Cur-Step: 160, loss(cross_dice_sum): 0.03968, Running average loss:0.04263, Time taken: 0:00:00.351211 ETA: 0:00:03.160900
Epoch: 1/10:, Cur-Step: 170, loss(cross_dice_sum): 0.03880, Running average loss:0.04212, Time taken: 0:00:00.351211 ETA: 0:00:03.160900
Epoch: 1/10:, Cur-Step: 180, loss(cross_dice_sum): 0.03798, Running average loss:0.04164, Time taken: 0:00:00.351211 ETA: 0:00:03.160900
Epoch: 1/10:, Cur-Step: 190, loss(cross_dice_sum): 0.03720, Running average loss:0.04118, Time taken: 0:00:00.351211 ETA: 0:00:03.160900
Epoch: 1/10:, Cur-Step: 200, loss(cross_dice_sum): 0.03647, Running average loss:0.04073, Time taken: 0:00:00.351211 ETA: 0:00:03.160900
Epoch: 2/10:, Cur-Step: 210, loss(cross_dice_sum): 0.03579, Running average loss:0.03592, Time taken: 0:00:00.440181 ETA: 0:00:03.521450
Epoch: 2/10:, Cur-Step: 220, loss(cross_dice_sum): 0.03514, Running average loss:0.03559, Time taken: 0:00:00.440181 ETA: 0:00:03.521450
Epoch: 2/10:, Cur-Step: 230, loss(cross_dice_sum): 0.03453, Running average loss:0.03528, Time taken: 0:00:00.440181 ETA: 0:00:03.521450
Epoch: 2/10:, Cur-Step: 240, loss(cross_dice_sum): 0.03396, Running average loss:0.03497, Time taken: 0:00:00.440181 ETA: 0:00:03.521450
Epoch: 2/10:, Cur-Step: 250, loss(cross_dice_sum): 0.03341, Running average loss:0.03468, Time taken: 0:00:00.440181 ETA: 0:00:03.521450
Epoch: 2/10:, Cur-Step: 260, loss(cross_dice_sum): 0.03290, Running average loss:0.03440, Time taken: 0:00:00.440181 ETA: 0:00:03.521450
Epoch: 2/10:, Cur-Step: 270, loss(cross_dice_sum): 0.03241, Running average loss:0.03413, Time taken: 0:00:00.440181 ETA: 0:00:03.521450
Epoch: 2/10:, Cur-Step: 280, loss(cross_dice_sum): 0.03195, Running average loss:0.03386, Time taken: 0:00:00.440181 ETA: 0:00:03.521450
Epoch: 2/10:, Cur-Step: 290, loss(cross_dice_sum): 0.03151, Running average loss:0.03361, Time taken: 0:00:00.440181 ETA: 0:00:03.521450
Epoch: 2/10:, Cur-Step: 300, loss(cross_dice_sum): 0.03110, Running average loss:0.03337, Time taken: 0:00:00.440181 ETA: 0:00:03.521450
Epoch: 3/10:, Cur-Step: 310, loss(cross_dice_sum): 0.03070, Running average loss:0.03072, Time taken: 0:00:00.655493 ETA: 0:00:04.588454
Epoch: 3/10:, Cur-Step: 320, loss(cross_dice_sum): 0.03032, Running average loss:0.03053, Time taken: 0:00:00.655493 ETA: 0:00:04.588454
Epoch: 3/10:, Cur-Step: 330, loss(cross_dice_sum): 0.02996, Running average loss:0.03034, Time taken: 0:00:00.655493 ETA: 0:00:04.588454
Epoch: 3/10:, Cur-Step: 340, loss(cross_dice_sum): 0.02962, Running average loss:0.03017, Time taken: 0:00:00.655493 ETA: 0:00:04.588454
Epoch: 3/10:, Cur-Step: 350, loss(cross_dice_sum): 0.02929, Running average loss:0.02999, Time taken: 0:00:00.655493 ETA: 0:00:04.588454
Epoch: 3/10:, Cur-Step: 360, loss(cross_dice_sum): 0.02897, Running average loss:0.02982, Time taken: 0:00:00.655493 ETA: 0:00:04.588454
Epoch: 3/10:, Cur-Step: 370, loss(cross_dice_sum): 0.02866, Running average loss:0.02966, Time taken: 0:00:00.655493 ETA: 0:00:04.588454
Epoch: 3/10:, Cur-Step: 380, loss(cross_dice_sum): 0.02837, Running average loss:0.02950, Time taken: 0:00:00.655493 ETA: 0:00:04.588454
Epoch: 3/10:, Cur-Step: 390, loss(cross_dice_sum): 0.02809, Running average loss:0.02934, Time taken: 0:00:00.655493 ETA: 0:00:04.588454
Epoch: 3/10:, Cur-Step: 400, loss(cross_dice_sum): 0.02782, Running average loss:0.02919, Time taken: 0:00:00.655493 ETA: 0:00:04.588454
Epoch: 3/10:, Cur-Step: 410, loss(cross_dice_sum): 0.02756, Running average loss:0.02904, Time taken: 0:00:00.655493 ETA: 0:00:04.588454
Epoch: 4/10:, Cur-Step: 420, loss(cross_dice_sum): 0.02730, Running average loss:0.02740, Time taken: 0:00:00.150345 ETA: 0:00:00.902072
Epoch: 4/10:, Cur-Step: 430, loss(cross_dice_sum): 0.02706, Running average loss:0.02728, Time taken: 0:00:00.150345 ETA: 0:00:00.902072
Epoch: 4/10:, Cur-Step: 440, loss(cross_dice_sum): 0.02682, Running average loss:0.02716, Time taken: 0:00:00.150345 ETA: 0:00:00.902072
Epoch: 4/10:, Cur-Step: 450, loss(cross_dice_sum): 0.02659, Running average loss:0.02704, Time taken: 0:00:00.150345 ETA: 0:00:00.902072
Epoch: 4/10:, Cur-Step: 460, loss(cross_dice_sum): 0.02637, Running average loss:0.02692, Time taken: 0:00:00.150345 ETA: 0:00:00.902072
Epoch: 4/10:, Cur-Step: 470, loss(cross_dice_sum): 0.02616, Running average loss:0.02681, Time taken: 0:00:00.150345 ETA: 0:00:00.902072
Epoch: 4/10:, Cur-Step: 480, loss(cross_dice_sum): 0.02595, Running average loss:0.02670, Time taken: 0:00:00.150345 ETA: 0:00:00.902072
Epoch: 4/10:, Cur-Step: 490, loss(cross_dice_sum): 0.02574, Running average loss:0.02659, Time taken: 0:00:00.150345 ETA: 0:00:00.902072
Epoch: 4/10:, Cur-Step: 500, loss(cross_dice_sum): 0.02555, Running average loss:0.02648, Time taken: 0:00:00.150345 ETA: 0:00:00.902072
Epoch: 4/10:, Cur-Step: 510, loss(cross_dice_sum): 0.02535, Running average loss:0.02638, Time taken: 0:00:00.150345 ETA: 0:00:00.902072
Epoch: 5/10:, Cur-Step: 520, loss(cross_dice_sum): 0.02517, Running average loss:0.02521, Time taken: 0:00:00.364646 ETA: 0:00:01.823229
Epoch: 5/10:, Cur-Step: 530, loss(cross_dice_sum): 0.02498, Running average loss:0.02512, Time taken: 0:00:00.364646 ETA: 0:00:01.823229
Epoch: 5/10:, Cur-Step: 540, loss(cross_dice_sum): 0.02481, Running average loss:0.02503, Time taken: 0:00:00.364646 ETA: 0:00:01.823229
Epoch: 5/10:, Cur-Step: 550, loss(cross_dice_sum): 0.02463, Running average loss:0.02494, Time taken: 0:00:00.364646 ETA: 0:00:01.823229
Epoch: 5/10:, Cur-Step: 560, loss(cross_dice_sum): 0.02446, Running average loss:0.02485, Time taken: 0:00:00.364646 ETA: 0:00:01.823229
Epoch: 5/10:, Cur-Step: 570, loss(cross_dice_sum): 0.02430, Running average loss:0.02477, Time taken: 0:00:00.364646 ETA: 0:00:01.823229
Epoch: 5/10:, Cur-Step: 580, loss(cross_dice_sum): 0.02413, Running average loss:0.02468, Time taken: 0:00:00.364646 ETA: 0:00:01.823229
Epoch: 5/10:, Cur-Step: 590, loss(cross_dice_sum): 0.02398, Running average loss:0.02460, Time taken: 0:00:00.364646 ETA: 0:00:01.823229
Epoch: 5/10:, Cur-Step: 600, loss(cross_dice_sum): 0.02382, Running average loss:0.02452, Time taken: 0:00:00.364646 ETA: 0:00:01.823229
Epoch: 5/10:, Cur-Step: 610, loss(cross_dice_sum): 0.02367, Running average loss:0.02444, Time taken: 0:00:00.364646 ETA: 0:00:01.823229
Epoch: 6/10:, Cur-Step: 620, loss(cross_dice_sum): 0.02352, Running average loss:0.02353, Time taken: 0:00:00.614153 ETA: 0:00:02.456614
Epoch: 6/10:, Cur-Step: 630, loss(cross_dice_sum): 0.02337, Running average loss:0.02346, Time taken: 0:00:00.614153 ETA: 0:00:02.456614
Epoch: 6/10:, Cur-Step: 640, loss(cross_dice_sum): 0.02323, Running average loss:0.02339, Time taken: 0:00:00.614153 ETA: 0:00:02.456614
Epoch: 6/10:, Cur-Step: 650, loss(cross_dice_sum): 0.02309, Running average loss:0.02332, Time taken: 0:00:00.614153 ETA: 0:00:02.456614
Epoch: 6/10:, Cur-Step: 660, loss(cross_dice_sum): 0.02295, Running average loss:0.02325, Time taken: 0:00:00.614153 ETA: 0:00:02.456614
Epoch: 6/10:, Cur-Step: 670, loss(cross_dice_sum): 0.02282, Running average loss:0.02318, Time taken: 0:00:00.614153 ETA: 0:00:02.456614
Epoch: 6/10:, Cur-Step: 680, loss(cross_dice_sum): 0.02269, Running average loss:0.02311, Time taken: 0:00:00.614153 ETA: 0:00:02.456614
Epoch: 6/10:, Cur-Step: 690, loss(cross_dice_sum): 0.02256, Running average loss:0.02304, Time taken: 0:00:00.614153 ETA: 0:00:02.456614
Epoch: 6/10:, Cur-Step: 700, loss(cross_dice_sum): 0.02243, Running average loss:0.02297, Time taken: 0:00:00.614153 ETA: 0:00:02.456614
Epoch: 6/10:, Cur-Step: 710, loss(cross_dice_sum): 0.02230, Running average loss:0.02291, Time taken: 0:00:00.614153 ETA: 0:00:02.456614
Epoch: 6/10:, Cur-Step: 720, loss(cross_dice_sum): 0.02218, Running average loss:0.02284, Time taken: 0:00:01.165617 ETA: 0:00:04.662469
Epoch: 7/10:, Cur-Step: 730, loss(cross_dice_sum): 0.02206, Running average loss:0.02211, Time taken: 0:00:01.165617 ETA: 0:00:03.496852
Epoch: 7/10:, Cur-Step: 740, loss(cross_dice_sum): 0.02194, Running average loss:0.02205, Time taken: 0:00:01.165617 ETA: 0:00:03.496852
Epoch: 7/10:, Cur-Step: 750, loss(cross_dice_sum): 0.02182, Running average loss:0.02199, Time taken: 0:00:01.165617 ETA: 0:00:03.496852
Epoch: 7/10:, Cur-Step: 760, loss(cross_dice_sum): 0.02170, Running average loss:0.02193, Time taken: 0:00:01.165617 ETA: 0:00:03.496852
Epoch: 7/10:, Cur-Step: 770, loss(cross_dice_sum): 0.02159, Running average loss:0.02187, Time taken: 0:00:01.165617 ETA: 0:00:03.496852
Epoch: 7/10:, Cur-Step: 780, loss(cross_dice_sum): 0.02148, Running average loss:0.02182, Time taken: 0:00:01.165617 ETA: 0:00:03.496852
Epoch: 7/10:, Cur-Step: 790, loss(cross_dice_sum): 0.02137, Running average loss:0.02176, Time taken: 0:00:01.165617 ETA: 0:00:03.496852
Epoch: 7/10:, Cur-Step: 800, loss(cross_dice_sum): 0.02126, Running average loss:0.02170, Time taken: 0:00:01.165617 ETA: 0:00:03.496852
Epoch: 7/10:, Cur-Step: 810, loss(cross_dice_sum): 0.02115, Running average loss:0.02165, Time taken: 0:00:01.165617 ETA: 0:00:03.496852
Epoch: 7/10:, Cur-Step: 820, loss(cross_dice_sum): 0.02105, Running average loss:0.02159, Time taken: 0:00:01.165617 ETA: 0:00:03.496852
Epoch: 8/10:, Cur-Step: 830, loss(cross_dice_sum): 0.02094, Running average loss:0.02097, Time taken: 0:00:00.285859 ETA: 0:00:00.571719
Epoch: 8/10:, Cur-Step: 840, loss(cross_dice_sum): 0.02084, Running average loss:0.02092, Time taken: 0:00:00.285859 ETA: 0:00:00.571719
Epoch: 8/10:, Cur-Step: 850, loss(cross_dice_sum): 0.02074, Running average loss:0.02087, Time taken: 0:00:00.285859 ETA: 0:00:00.571719
Epoch: 8/10:, Cur-Step: 860, loss(cross_dice_sum): 0.02064, Running average loss:0.02082, Time taken: 0:00:00.285859 ETA: 0:00:00.571719
Epoch: 8/10:, Cur-Step: 870, loss(cross_dice_sum): 0.02054, Running average loss:0.02077, Time taken: 0:00:00.285859 ETA: 0:00:00.571719
Epoch: 8/10:, Cur-Step: 880, loss(cross_dice_sum): 0.02044, Running average loss:0.02072, Time taken: 0:00:00.285859 ETA: 0:00:00.571719
Epoch: 8/10:, Cur-Step: 890, loss(cross_dice_sum): 0.02034, Running average loss:0.02067, Time taken: 0:00:00.285859 ETA: 0:00:00.571719
Epoch: 8/10:, Cur-Step: 900, loss(cross_dice_sum): 0.02025, Running average loss:0.02062, Time taken: 0:00:00.285859 ETA: 0:00:00.571719
Epoch: 8/10:, Cur-Step: 910, loss(cross_dice_sum): 0.02015, Running average loss:0.02057, Time taken: 0:00:00.285859 ETA: 0:00:00.571719
Epoch: 8/10:, Cur-Step: 920, loss(cross_dice_sum): 0.02006, Running average loss:0.02052, Time taken: 0:00:00.285859 ETA: 0:00:00.571719
Epoch: 9/10:, Cur-Step: 930, loss(cross_dice_sum): 0.01997, Running average loss:0.01998, Time taken: 0:00:00.513137 ETA: 0:00:00.513137
Epoch: 9/10:, Cur-Step: 940, loss(cross_dice_sum): 0.01988, Running average loss:0.01994, Time taken: 0:00:00.513137 ETA: 0:00:00.513137
Epoch: 9/10:, Cur-Step: 950, loss(cross_dice_sum): 0.01979, Running average loss:0.01989, Time taken: 0:00:00.513137 ETA: 0:00:00.513137
Epoch: 9/10:, Cur-Step: 960, loss(cross_dice_sum): 0.01970, Running average loss:0.01985, Time taken: 0:00:00.513137 ETA: 0:00:00.513137
Epoch: 9/10:, Cur-Step: 970, loss(cross_dice_sum): 0.01961, Running average loss:0.01980, Time taken: 0:00:00.513137 ETA: 0:00:00.513137
Epoch: 9/10:, Cur-Step: 980, loss(cross_dice_sum): 0.01952, Running average loss:0.01976, Time taken: 0:00:00.513137 ETA: 0:00:00.513137
Epoch: 9/10:, Cur-Step: 990, loss(cross_dice_sum): 0.01944, Running average loss:0.01971, Time taken: 0:00:00.513137 ETA: 0:00:00.513137
Epoch: 9/10:, Cur-Step: 1000, loss(cross_dice_sum): 0.01935, Running average loss:0.01967, Time taken: 0:00:00.513137 ETA: 0:00:00.513137
Epoch: 9/10:, Cur-Step: 1010, loss(cross_dice_sum): 0.01927, Running average loss:0.01963, Time taken: 0:00:00.513137 ETA: 0:00:00.513137
Epoch: 9/10:, Cur-Step: 1020, loss(cross_dice_sum): 0.01919, Running average loss:0.01958, Time taken: 0:00:00.513137 ETA: 0:00:00.513137
Saving the final step model to /workspace/tlt/local_dir/tlt_unet_corrosion_resnet18/unpruned_model/weights/unet_model.tlt
This is an example of an input image with its mask image:
But the all inference results are look like this image:
