I’m trying to install the driver on a Dell 7920, with 32 GB RAM, Intel Silver 4110 CPU, running the latest CentOS. The kernel is version 3.10.0. There’s just one HP ZR24w monitor connected, so nothing fancy. The installation keeps failing.
There are a few bits of the logfile /var/log/nvidia-installer.log which you might need to look over, so I have attached the log, but the most important bits seems to be these lines, in particular
ERROR: Unable to load the ‘nvidia-drm’ kernel module.
Here’s the end of the logfile, which is
executing: ‘/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-fbc.so.460.32.03’…
executing: ‘/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-allocator.so.460.32.03’…
executing: ‘/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-opticalflow.so.460.32.03’…
executing: ‘/sbin/ldconfig’…
→ done.
→ Driver file installation is complete.
→ Installing DKMS kernel module:
→ done.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
- see logfile. I have been using the file NVIDIA-Linux-x86_64-460.32.03.run which is the latest I can download.
nvidia-installer.log (8.6 KB)
I thought I would show this command.
[root@duck /]# lspci | grep -i nvidia
0000:b3:00.0 VGA compatible controller: NVIDIA Corporation GP106GL [Quadro P2200] (rev a1)
0000:b3:00.1 Audio device: NVIDIA Corporation GP106 High Definition Audio Controller (rev a1)
and this
[root@duck /]# lshw -numeric -C display
*-display UNCLAIMED
description: VGA compatible controller
product: GP106GL [Quadro P2200] [10DE:1C31]
vendor: NVIDIA Corporation [10DE]
physical id: 0
bus info: pci@0000:b3:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller cap_list
configuration: latency=0
resources: memory:fa000000-faffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:f000(size=128) memory:fb000000-fb07ffff
[root@duck /]#
