Problem installing IGX-r38v2.0-rc8-2026-03-11-16-35-20-arm64.iso
I have an IGX Thor Dev Kit Mini. I’ve downloaded IGX-r38v2.0-rc8-2026-03-11-16-35-20-arm64.iso from the IGX Download Center. Flash it to a USB drive using balenaEtcher. DId a verify. I go through the boot menus and the boot starts. It gets some errors in the platform section saying deferred probe pending. Then it gets to the memory controller initialization and it hangs on tegra-mc.
I downloaded the file again, flashed it to a different USB drive with the same results for both the Real Time Kernel version and the plain kernel version.
Hi scaldara,
Has your IGX Thor Devkit Mini been flashed before?
Please share the full log for further check.
No, first time out of the box. The instructions suggest that the flashing happens automatically with the install. I’ve never seen that before. Can you point me to a document that shows me what and how to flash the firmware?
I’m new to the IGX Thor Devkit Mini. I’ve got the Devkit connected to a keyboard, mouse, HDMI video. It hangs during boot. How would I get access to a log?
Please refer to Installing Software on IGX Thor Developer Kit Mini — NVIDIA IGX Developer Guide to setup IGX Thor devkit mini with ISO.
Or you can refer to JetPack on IGX — NVIDIA IGX Developer Guide to use initrd flash script to flash it from host.
Please refer to IGX Thor Developer Kit Mini System Overview — NVIDIA IGX Developer Guide and use 8. Debug USB-C port to capture serial console log from host. You can read it from /dev/ttyACM0 from host.
I’m using a MacBook Pro as my host system. I connected to the USB-C debug port and opened up a screen session on the Mac with logging enabled. I had a USB drive installed with the released OS flashed to it. I did a power on and followed the screens and selected the OS to boot which was Ver 2.0 with Realtime. Attached is the debug port log.
screenlog.txt (185.8 KB)
Thanks for sharing the log.
The board is able to boot into the installer, so this does not look like a basic USB boot failure.
The failure happens later, after the installer starts, when initramfs/casper cannot find the live filesystem on the USB media.
Unable to find a medium containing a live file system
This usually points to a USB media or USB hub compatibility issue.
Please try recreating the USB with BalenaEtcher, using a different USB drive, and connecting it directly to the devkit without any USB hub or dock.
The problem I was having was solved by formatting the USB drive as ExFAT. This allowed me to complete the install and boot up to the GUI. I then did an apt update to all of the packages. After that I did the “sudo apt install nvidia-igx-ai”. That completed okay, it then asked me to reboot which I did via “sudo reboot now”. On the reboot it comes up with an unknown symbol error and just loops forever on that. Attached is the bootlog.
screenlog2.txt (251.8 KB)
Thanks for sharing the new boot log.
The system is now getting past the installation stage and into Linux, but after the reboot the NVIDIA kernel modules are failing to load.
Have you run sudo apt update before installing nvidia-igx-ai?
I did a reinstallation from the flash drive. I did not do the “sudo apt update”. I can now reboot the installed os without error.
In the prior case when I did the sudo apt update it returned
Get:1 https://dl.google.com/linux/chrome-stable/deb stable InRelease [2548 B]
Hit:2 Index of /ubuntu-ports noble InRelease
Hit:3 https://repo.download.nvidia.com/jetson/common r38.5 InRelease
Hit:4 Index of /ubuntu-ports noble-updates InRelease
Hit:5 Index of /ubuntu-ports noble-security InRelease
Hit:6 https://repo.download.nvidia.com/jetson/som r38.5 InRelease
Hit:7 https://repo.download.nvidia.com/jetson/ffmpeg r38.5 InRelease
Get:8 https://dl.google.com/linux/chrome-stable/deb stable/main arm64 Packages [1419 B]
Fetched 3967 B in 1s (4124 B/s)
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
428 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
To get the packages installed I did a “sudo apt update && sudo apt upgrade -y”
This created some type of conflict which upon reboot the kernel would throw a constant error of:
nvidia: Unknown symbol host1x_syncpt_get_shim_info (err -2)
How do I do the “sudo apt update” such that it only loads the correct NVIDIA packages for IGX Thor Release 2.0
May I know the purpose to run apt upgrade?
Please just run the following commands to install NVIDIA AI Stack.
$ sudo apt update
$ sudo apt install nvidia-igx-ai
This has been my misunderstanding. The reason I did the “apt upgrade” was due to what gets displayed after the “apt update” which is:
432 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
I thought I was supposed to do the upgrades as well. This was clearly my problem.. Doing the upgrade was what caused the crash on reboot.
A suggestion would be to update the procedure and explicitly state to not do the upgrade.
Thanks for you help!
