Problem installing JetPack 3.2 from ubuntu 16.04 host
Hi Folks
I am have trouble installing JP3.2 from my ubuntu host.
  1. I run ./JetPack-L4T-3.2-linux-x64_b196.run, after downloading.
  2. The installer runs into trouble during installation of vision works with following message
Need to get 530 kB/77.3 MB of archives.
After this operation, 168 MB of additional disk space will be used.
Get:1 file:/var/visionworks-repo  libvisionworks 1.6.0.193n [8,847 kB]
Get:2 file:/var/visionworks-repo  libvisionworks-dev 1.6.0.193n [144 kB]
Err:3 http://security.ubuntu.com/ubuntu xenial-security/universe amd64 libavfilter-ffmpeg5 amd64 7:2.8.11-0ubuntu0.16.04.1
  404  Not Found [IP: 91.189.91.23 80]
Get:4 file:/var/visionworks-repo  libvisionworks-samples 1.6.0.193n [53.5 MB]
W: --force-yes is deprecated, use one of the options starting with --allow instead.
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/universe/f/ffmpeg/libavfilter-ffmpeg5_2.8.11-0ubuntu0.16.04.1_amd64.deb  404  Not Found [IP: 91.189.91.23 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I would not like to skip installation of VisionWorks. Please help.
Suppose this is an environment issue.
Not sure if there is anything missing on your host.
We are checking with our internal team for the suggestion.
Will update information to you later.
VisionWorks depends on the libavfilter-ffmpeg5 package, which can be installed from Ubuntu repository.
Buth the repository and DNS is broken in your environment.
Could you try other repository or check the network environment first?
Hi dumbogeorge,
Have you managed to get VisionWorks install successfully?
Any further support required?
Hi AastaLLL and KayCCC
I am able to flash OS. Even when I started from a cleanly created new user - I was facing this issue with JetPack. But I tried switching to custom option , and then chose to not install VW. That way I was able to boot TX2 som on my carrier board. Even though I chose to skip installation of VW from JP install GUI - it still installed VisionWorks-SFM-0.90-Samples in /home/nvidia
Could you share your JetPack log with us?
$ zip log.zip [Jetpack]/_installer/logs
Attach log.zip
