Hello everyone,
I have been facing a problem for a few days now while installing nvidia drivers for the NVIDIA L4 GPU.
My current system configuration is the following :
- Ubuntu 22.04 VM with Vmware esxi, GPU is configured with passthrough.
- Driver version that I try to install: 535.161.07 following this guide.
After installing the driver I try to execute the nvidia-smi command, I get the following result :
Command ‘nvidia-smi’ not found, but can be installed with:
apt install nvidia-utils-390 # version 390.157-0ubuntu0.22.04.2, or
apt install nvidia-utils-418-server # version 418.226.00-0ubuntu5~0.22.04.1
apt install nvidia-utils-450-server # version 450.248.02-0ubuntu0.22.04.1
apt install nvidia-utils-470 # version 470.223.02-0ubuntu0.22.04.1
apt install nvidia-utils-470-server # version 470.223.02-0ubuntu0.22.04.1
apt install nvidia-utils-525 # version 525.147.05-0ubuntu0.22.04.1
apt install nvidia-utils-525-server # version 525.147.05-0ubuntu0.22.04.1
apt install nvidia-utils-535 # version 535.129.03-0ubuntu0.22.04.1
apt install nvidia-utils-535-server # version 535.129.03-0ubuntu0.22.04.1
apt install nvidia-utils-510 # version 510.60.02-0ubuntu1
apt install nvidia-utils-510-server # version 510.47.03-0ubuntu3
Here is one of the entries in the nvidia bug report log :
NVRM: The NVIDIA GPU 0000:13:00.0 (PCI ID: 10de:27b8)
NVRM: installed in this system is not supported by the
NVRM: NVIDIA 535.161.07 driver release.
NVRM: Please see ‘Appendix A - Supported NVIDIA GPU Products’
NVRM: in this release’s README, available on the operating system
NVRM: specific graphics driver download page at www.nvidia.com.
The PCI ID 10de:27b8 does correspond to NVIDIA L4, and when I read the Appendix A of the driver’s README, I do see the L4 GPU in the list of compatible GPUs.
Here is the output of the dkms status nvidia command :
nvidia/535.161.07, 5.15.0-97-generic, x86_64: installed
Output of uname -r command : 5.15.0-97-generic
output of lshw -c display command (shows that the GPU is unclaimed with no driver installed) :
*-display
description: VGA compatible controller
product: SVGA II Adapter
vendor: VMware
physical id: f
bus info: pci@0000:00:0f.0
logical name: /dev/fb0
version: 00
width: 32 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=vmwgfx latency=64 resolution=1176,885
resources: irq:16 ioport:2040(size=16) memory:f0000000-f7ffffff memory:fb800000-fbffffff memory:c0000-dffff
*-display UNCLAIMED
description: 3D controller
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:13:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pciexpress msix cap_list
configuration: latency=64
resources: iomemory:1fff0-1ffef iomemory:1fff0-1ffef memory:fda00000-fda3ffff memory:1fff00000000-1fff7fffffff memory:1fff80000000-1fff81ffffff
Here is the Passthrough config in Vmware:
Any help would be very appreciated.
Thank you all !
