Problem of compiling OpenCV with CUDA
An error occurs when compiling the attached two example codes using the following steps.
gcc -lcv -lhighgui -lcvaux -I/usr/include/opencv -c q_cpu.c
nvcc -c -arch=sm_20 -Xcudafe=-w q_gpu.cu
nvcc L/usr/local/cuda/lib64 -L/usr/local/lib -L/usr/lib -L/usr/lib32 -L/usr/lib64 q_gpu.o q_cpu.o -lcv -lhighgui -lcvaux -o test
The error message is as follows.
q_cpu.o: In function `main’:
q_cpu.c:(.text+0x275): undefined reference to `run_GPU’
collect2: ld returned 1 exit status
make: *** [f] Error 1
I will appreciate if I can get any response.
// q_cpu.c
#include "cv.h"
#include "highgui.h"
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#define VALUE_MAX 10000000.0
int*run_GPU(char *s_img, int s_h, int s_w, char *p_img, int p_h, int p_w, int r_h, int r_w);
struct match{
	int bestRow;
	int bestCol;
	int bestSAD;
}position;
int main( int argc, char** argv )
	IplImage* sourceImg;
	IplImage* patternImg;
	float minSAD = VALUE_MAX;
	float SAD;
	int x, y, i, j;
	uchar* ptr;
	uchar p_sourceIMG, p_patternIMG;
	CvPoint pt1, pt2;
	int *host_result;
	int result_height, result_width;
	if( argc != 3 )
	    printf("Using command: %s source_image search_image\n",argv[0]);
		exit(1);
	if((sourceImg = cvLoadImage( argv[1], 0)) == NULL){
		printf("%s cannot be openned\n",argv[1]);
		exit(1);
	printf("height of sourceImg:%d\n",sourceImg->height);
	printf("width of sourceImg:%d\n",sourceImg->width);
	printf("size of sourceImg:%d\n",sourceImg->imageSize);
	if((patternImg = cvLoadImage( argv[2], 0)) == NULL){
		printf("%s cannot be openned\n",argv[2]);
		exit(1);
	printf("height of sourceImg:%d\n",patternImg->height);
	printf("width of sourceImg:%d\n",patternImg->width);
	printf("size of sourceImg:%d\n",patternImg->imageSize);
	//allocate memory on CPU to store SAD results
	result_height = sourceImg->height - patternImg->height + 1;
	result_width = sourceImg->width - patternImg->width + 1;
    host_result = run_GPU(sourceImg->imageData, sourceImg->height, sourceImg->width,
        patternImg->imageData, patternImg->height, patternImg->width, result_height, result_width);
	for( y=0; y < result_height; y++ ) {
		for( x=0; x < result_width; x++ ) {
			if ( minSAD > host_result[y * result_width + x] ) {
				minSAD =  host_result[y * result_width + x];
				// give me VALUE_MAX
				position.bestRow = y;
				position.bestCol = x;
				position.bestSAD =  host_result[y * result_width + x];
	printf("minSAD is %f\n", minSAD);
	//setup the two points for the best match
    pt1.x = position.bestCol;
    pt1.y = position.bestRow;
    pt2.x = pt1.x + patternImg->width;
    pt2.y = pt1.y + patternImg->height;
// Draw the rectangle in the source image
    cvRectangle( sourceImg, pt1, pt2, CV_RGB(255,0,0), 3, 8, 0 );
	cvNamedWindow( "sourceImage", 1 );
    cvShowImage( "sourceImage", sourceImg );
	cvNamedWindow( "patternImage", 1 );
    cvShowImage( "patternImage", patternImg );
    cvWaitKey(0);
cvDestroyWindow( "sourceImage" );
    cvReleaseImage( &sourceImg );
	cvDestroyWindow( "patternImage" );
    cvReleaseImage( &patternImg );
    return 0;
// q_gpu.cu
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#include <cuda_runtime.h>
#define iABS(x) (((x)<0)?(-(x)):(x))
#define iAbsDiff(a,b) (((a)<(b))?((b)-(a)):((a)-(b)))
__global__ void kernel (unsigned char* sourcePtr, unsigned char* patternPtr, int* resultPtr, int s_height, int s_width, int p_height, int p_width);
int *run_GPU(char *s_img, int s_h, int s_w, char *p_img, int p_h, int p_w, int r_h, int r_w) {
    unsigned char *dev_sourceImg, *dev_patternImg;
	int *dev_result;
    int *host_result;
host_result = (int *)malloc(r_h * r_w * sizeof(int));
//allocate the momory on GPU
	cudaMalloc((void**)&dev_sourceImg, s_h * s_w * sizeof(char));
	cudaMalloc((void**)&dev_patternImg, p_h * p_w * sizeof(char));
	cudaMalloc((void**)&dev_result, r_h * r_w * sizeof(int));
	//copy source and pattern image to GPU
	cudaMemcpy(dev_sourceImg,
	           s_img,
			   s_h * s_w * sizeof(char),
			   cudaMemcpyHostToDevice);
	cudaMemcpy(dev_patternImg,
			   p_img,
			   p_h * p_w * sizeof(char),
	dim3 grids(r_w, r_h);
	dim3 threads(16, 16);
	kernel<<<grids, threads>>>(dev_sourceImg, dev_patternImg, dev_result, s_h, s_w, p_h, p_w);
	cudaMemcpy(host_result,
	           dev_result,
		   r_h * r_w * sizeof(int),
		   cudaMemcpyDeviceToHost);
cudaFree(dev_sourceImg);
    cudaFree(dev_patternImg);
    cudaFree(dev_result);
return host_result;
__global__ void kernel (unsigned char* sourcePtr, unsigned char* patternPtr, int* resultPtr, int s_height, int s_width, int p_height, int p_width){
	//map from threadIdx/blockIdx to pixel position
	int s_x = blockIdx.x + threadIdx.x;
	int s_y = blockIdx.y + threadIdx.y;
	int p_x = threadIdx.x; // one block of threads handle 9 blocks
	int p_y = threadIdx.y;
	sourcePtr[ s_y*s_width+s_x ] += 1;
