I just want to move my post to here
Basically, I cannot get any debug information when I am debugging the shared libraries, and would like to see if other have similar problem, and what is the correct way to set it up. Thanks!
Hi Nachochp,
I’ve tried to reproduce your issue with shared libraries, but all worked correctly for me. You can try setting paths to sources and libraries explicitly in the Debugging properties - it might help.
