Hi JerryChang,
Additionally, when saving video input to file, the timestamp does not change, you can see as following
./v4l2-ctl -d /dev/video0 -w --verbose --set-fmt-video=width=3840,height=2160,pixelformat=UYVY --stream-mmap --stream-count=30 --stream-to=test.raw
VIDIOC_QUERYCAP: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Format Video Capture:
Width/Height : 3840/2160
Pixel Format : 'UYVY'
Field : None
Bytes per Line : 7680
Size Image : 16588800
Colorspace : SMPTE 170M
Transfer Function : Default
YCbCr/HSV Encoding: Default
Quantization : Default
Flags :
VIDIOC_REQBUFS: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_STREAMON: ok
Index : 0
Type : Video Capture
Flags : mapped, done
Field : None
Sequence : 0
Length : 16588800
Bytesused: 16588800
Timestamp: 163.298596s (Monotonic, End-of-Frame)
Index : 1
Field : None
Sequence : 1
Length : 16588800
Bytesused: 16588800
0.50 fps
Index : 2
Field : None
Sequence : 2
Length : 16588800
Bytesused: 16588800
Dear JerryChang,
I included those patches; some parameters are missing but finally it does not work; the same error happen.
Additionally, as I did before, I tested our custom FPGA board with Jetpack 3.3 that also include those patches; it has same error.
Do you have other suggestion?
Because half of screen sometime has still image; I think only data from 1 MIPI come to CSI port.
So, I want to know method to check whether or not data is came in CSI input and come out CSI output
Dear JerryChang,
Our FPGA engineer said that, MIPI signal from FPGA was generated and sent to CSI port.
But I am not clear how to check CSI status on TX2 side.
Our device driver and device tree is base on tc358840 device
Thank.
Hi JerryChang,
It seems that, on VI module we only receive the first PXL_SOF of 1 channel.
And then timeout happen because of nvhost_syncpt_wait_timeout_ext() function. But our FPGA engineer confirm about sending SOF frequently.
Do you have any suggestion for this trouble?
Thank in advance.
When the “PXL_SOF syncpt timeout” happens, I reset NvCsi, re-initialize VI and capture context; then I can get data frame.
But because timeout happen, the frame is drop in the middle and screen is not smooth.
Do you have any idea for solving this problem?
Best regards.
that patch was adding error handling mechanism, driver side simply reset the broken capture request and waiting for another frame coming.
you should tune your drivers, please check your stream also follow the MIPI specification.
thanks
Hi JerryChang,
Following is driver source code for notification when PXL_SOF came to VI module:
* Wait for PXL_SOF syncpt
* Use the syncpt max value we just set as threshold
for (i = 0; i < chan->valid_ports; i++) {
err = nvhost_syncpt_wait_timeout_ext(chan->vi->ndev,
chan->syncpt[i][SOF_SYNCPT_IDX], thresh[i],
250, NULL, NULL);
if (unlikely(err))
dev_err(chan->vi->dev,
"PXL_SOF syncpt timeout! err = %d\n", err);
else {
struct vi_capture_status status;
err = vi_notify_get_capture_status(chan->vnc[i],
chan->vnc_id[i],
thresh[i], &status);
if (unlikely(err))
"no capture status! err = %d\n", err);
else
*ts = ns_to_timespec((s64)status.sof_ts);
Because we are using two MIPI for sending data and only one PXL_SOF is get on the first channel port. Do you think that the CSI second port did not initialize correctly or something wrong on device tree (please check attached file)
P.S. We make device driver and device tree base on TC358840 tegra186-quill-p3310-1000-c03-00-base-hdmi2csi.zip (3.11 KB)
am I understand correctly that you’re working a 8-lane device, which need to combine two CSI bricks for enough bandwidth.
hence, please update the num-channels device tree property since you actually only having one device connected.
for example,
Hi JerryChang,
I udpated num-channels on device tree as your suggestion but there are no lucky,
I still cannot get PXL_SOF on the second channel port (timeout still happen); only left screen get data, right screen is green.
I also added some debug message on update_gang_mode and get some result like bellowing (input video is 4K)
