Do you have any idea to solve this problem but keeping the PPS support in my jetson xavier nx and avoiding flashing the system? Because all the files are in the system.
I want to add a point that my system was boot from SSD card… The kernel of Jetson is: 5.10.
I don’t think the black screen issue is relating to your PPS dtb, but you can revert the change to check if it could help.
If you are using overlay dtb, you can not specify the macro like TEGRA194_MAIN_GPIO, please specify the hex value instead.
Or you can just modify them in device tree source and rebuild kernel image/dtb.
