In a device function, adding some lines, I have then some messages with problem:
C:\DOCUME~1\Ghislain\LOCALS~1\Temp/tmpxft_00000d00_00000000-9_main_prog.cpp3.i(0): Warning: Olimit was exceeded on function _Z11GLMM1KerneliiPjS_S_S_iPfS0_ii; will not perform function-scope optimization.
1> To still perform function-scope optimization, use -OPT:Olimit=0 (no limit) or -OPT:Olimit=21186
Assertion failure at line 2412 of …/…/be/cg/NVISA/cgtarget.cxx:
1>### Compiler Error in file C:\DOCUME~1\Ghislain\LOCALS~1\Temp/tmpxft_00000d00_00000000-9_main_prog.cpp3.i during Register Allocation phase:
1>### ran out of registers in float
1>nvopencc ERROR: C:\CUDA\bin/…/open64/lib//be.exe returned non-zero status 1
However I just add calculation and no other declaration of values.
I use Visual Studio 2005,. I tried to modify the -OPT:Olimit, but it was not recognized (In project\properties\c.c++\comand-prompt) I tried"
-OPT:Olimit=0, /-OPT:Olimit=0, etc "
Does someone know what is the Olimit, and how I can solve the problem.
