I have two projects, the first one(A) is application which linked to the second one(B) which is type of shared library.
Project A : Android.Tegra
Project B : dy
in Project B I have declared a simple class with extern function and I want to use this class in the main class of Project A.
I set up the additional Include Directories and also Additional Library Directories and set up Additional Dependencies as following “android;dy;” and finally add a Reference of Project B(dy) to Project A.
Everything built fine, and deployed on Shield device, but application crashed. and I’ve got an error at Android log that said can not load native library or something similar to it.
I can successfully link static library(.a) and run application without any problem but I don’t know why application with shared library doesn’t work.
Also I added the library as additional dependencies of ANT Build, but it wont work :(
Can anybody help me on this issue?
Pooya
