I was buying Jetson nano Developer Kit SB memory 4GB, after installing with Jetson software 4,5 the Linux Kernel not detected to Webcam Logitech C270, uvcvideo not initiailizing. What must I do to solve this problem
Is it really a C270, or a C720? I know the C720 works, am thinking this is some sort of typo. Also, if you monitor “dmesg --follow
” prior to inserting the USB connector, what then shows up in that log when you insert the USB cable? Also, mention if you are using a USB HUB where the camera shares with something else.
