I have encountered some problems with passing templatized structs by value… I have code similar to the snippet below, which used to work, but no longer does with CUDA 2.0
template<unsigned int N>
struct valarray {
float zzz[N];
__global__ void
moo( valarray<N> foo )
int main()
valarray<3> bar = {0.0f, 0.0f, 0.0f};
moo<3><<<dim3(2,1),dim3(16,1)>>>(bar);
return 0;
Compiling the snippet above, I get the following output:
[font=“Times”]modesty ~ $ nvcc -V
nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2007 NVIDIA Corporation
Built on Tue_Jun_10_05:42:45_PDT_2008
Cuda compilation tools, release 1.1, V0.2.1221
modesty ~ $ nvcc --keep reproduce.cu
reproduce.cudafe1.stub.h:17: error: template argument required for ‘struct valarray’
reproduce.cudafe1.stub.c:17: error: template-id ‘moo<3u>’ for ‘void moo(_Z8valarrayILj3EE)’ does not match any template declaration
reproduce.cudafe1.stub.c:17: error: invalid function declaration
modesty ~ $ [/font]
Lines 16 and 17 of reproduce.cudafe1.stub.h are
[font=“Courier”]template
void moo(struct valarray foo);[/font]
While lines 16 and 17 of reproduce.cudafe1.stub.cpp are
[font=“Times”]template <>
void moo<3U> (_Z8valarrayILj3EE foo)[/font]
Seems like somehow the “struct valarray” doesn’t get mangled correctly in the stub.h-file?
Best,
Chris
