Problem regarding initial setup of jetson nano board
I m trying to boot a jetson nanodevice as per the guide instruction but I didn’t get any output on HDMI display? (i m using HDMI converter for display)
or please guide for any other way I can access a borad ??
method 1. Please do not use a HDMI converter and find a monitor with native HDMI port.
method 2. Enable a uart serial
You would get stuck during method 2 because you need a monitor to configure ubuntu user account.
A workaround is use the script in below link before flashing.
Jetson Nano all USB ports suddenly stopped working - Jetson Nano - NVIDIA Developer Forums
thank you, sir,
could you guide me that in Nvidia Jetson nano it has given the cuda driver installation in the image file?
Hi padmanidaya,
It’s no included, and you need to install through JetPack by SDK Manager.
ok thank you
could you just provide me a link where I can go through and find that jetpack installation guide?
and also , sir in nvcc -V shows the Cuda compiler version. so what is that show ?
also the in the installation it included usr/local/lib show the Cuda 10.00 and Cuda what is that?
Hi padmanidaya,
Please refer to [url]https://developer.nvidia.com/embedded/jetpack[/url]
