Hi;
I’m having issues running the docker container for the Transfer Learning Toolkit on my Jetson nano (A02), according to the instruction found here.
I can pull the container no problem. However, in order to work I did have to modify the command to include “sudo”:
$ sudo docker pull nvcr.io/nvidia/tlt-streamanalytics:v2.0_py3
Otherwise I get “permission denied” errors. I’ve remoted into the nano using ssh, btw.
Next I try to run the following command, just like the instructions says:
$ docker run --gpus all -it -v "/path/to/dir/on/host":"/path/to/dir/in/docker" \ -p 8888:8888 nvcr.io/nvidia/tlt-streamanalytics:v2.0_py3 /bin/bash
And I get this error:
standard_init_linux.go:211: exec user process caused "exec format error"
I re-tried the command using “sudo” and I get the same error.
Can I please get some help trouble-shooting?
My nano is running JP4.4, updated.
