I’m trying to run the flow_monitor_meter sample from DOCA Flow, but I keep getting an “Invalid input” error when I specify the representor device.
Here’s what I’m running:
/tmp/build/doca_flow_monitor_meter -- -r pci/0000:03:00.0,pf1hpf -l 60
And this is what I get back:
root@localhost:/doca_devel/samples/doca_flow/flow_monitor_meter# /tmp/build/doca_flow_monitor_meter -- -r pci/0000:03:00.0,pf1hpf -l 60
[23:39:16:581404][2993881120][DOCA][INF][doca_log.cpp:628] DOCA version 3.1.0105
[23:39:16:581573][2993881120][DOCA][INF][flow_monitor_meter_main.c:49][main] Starting the sample
EAL: Detected CPU lcores: 8
EAL: Detected NUMA nodes: 1
EAL: Detected shared linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: Selected IOVA mode 'PA'
TELEMETRY: No legacy callbacks, legacy socket not created
[23:39:16:609472][2993881120][DOCA][ERR][device_utils.cpp:699] Failed to extract the device representor PCI identifier: 0000:03:00.0,pf1hpf
[23:39:16:609514][2993881120][DOCA][ERR][doca_argp.cpp:540] Failed to parse device representor identifier "pci/0000:03:00.0,pf1hpf": Invalid input
Usage: doca_flow_monitor_meter [DPDK Flags] -- [DOCA Flags] [Program Flags]
DOCA Flags:
-h, --help Print a help synopsis
-v, --version Print program version information
-l, --log-level Set the (numeric) log level for the program <10=DISABLE, 20=CRITICAL, 30=ERROR, 40=WARNING, 50=INFO, 60=DEBUG, 70=TRACE>
--sdk-log-level Set the SDK (numeric) log level for the program <10=DISABLE, 20=CRITICAL, 30=ERROR, 40=WARNING, 50=INFO, 60=DEBUG, 70=TRACE>
Program Flags:
-a, --device device
-r, --rep device representor
[23:39:16:609605][2993881120][DOCA][ERR][flow_monitor_meter_main.c:65][main] Failed to parse sample input: Invalid input
[23:39:16:609627][2993881120][DOCA][INF][flow_monitor_meter_main.c:101][main] Sample finished with errors
I already checked my devices with dpdk-devbind.py --status and both ports are visible:
root@localhost:/doca_devel/samples/doca_flow/flow_monitor_meter# /opt/mellanox/dpdk/bin/dpdk-devbind.py --status
lspci: Unable to load libkmod resources: error -2
Network devices using kernel driver
0000:03:00.0 'MT42822 BlueField-2 integrated ConnectX-6 Dx network controller a2d6' if=pf0hpf,p0,en3f0pf0sf0 drv=mlx5_core unused=
0000:03:00.1 'MT42822 BlueField-2 integrated ConnectX-6 Dx network controller a2d6' if=p1,pf1hpf drv=mlx5_core unused=
Other Network devices
0000:03:00.2 'Device c2d1' unused=
No 'Baseband' devices detected
No 'Crypto' devices detected
No 'DMA' devices detected
No 'Eventdev' devices detected
No 'Mempool' devices detected
No 'Compress' devices detected
No 'Misc (rawdev)' devices detected
No 'Regex' devices detected
I’ve tried several combinations for -a and -r, like:
-a pf0hpf -r pf1hpf
-a 0000:03:00.0 -r 0000:03:00.1
but the sample always fails with the same parsing error.
root@localhost:/doca_devel/samples/doca_flow/flow_monitor_meter# /opt/mellanox/doca/tools/doca_caps --list-rep-devs
PCI: 0000:03:00.0
PCI: 0000:03:00.1
representor-PCI: 0000:03:00.1
ib_port 1
host_index 1
pf_index 1
pci_func_type PF
hotplug no
vuid MT2148X08793MLNXS0D0F1
iface_name pf1hpf
iface_index 10
PCI: 0000:03:00.0
root@localhost:/home/ubuntu# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: oob_net0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 08:c0:eb:b2:43:96 brd ff:ff:ff:ff:ff:ff
altname enamlnxbf17i0
inet 172.28.20.102/24 brd 172.28.20.255 scope global dynamic noprefixroute oob_net0
valid_lft 1893sec preferred_lft 1893sec
inet6 fe80::ac0:ebff:feb2:4396/64 scope link
3: tmfifo_net0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:1a:ca:ff:ff:01 brd ff:ff:ff:ff:ff:ff
inet 192.168.100.2/30 brd 192.168.100.3 scope global noprefixroute tmfifo_net0
inet6 fe80::21a:caff:feff:ff01/64 scope link
4: p0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1550 qdisc mq state UP group default qlen 1000
link/ether 08:c0:eb:b2:43:8e brd ff:ff:ff:ff:ff:ff
altname enp3s0f0np0
inet6 fe80::ac0:ebff:feb2:438e/64 scope link
5: p1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1550 qdisc mq state UP group default qlen 1000
link/ether 08:c0:eb:b2:43:8f brd ff:ff:ff:ff:ff:ff
altname enp3s0f1np1
inet6 fe80::ac0:ebff:feb2:438f/64 scope link
9: pf0hpf: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 128
link/ether 12:77:48:31:b6:b8 brd ff:ff:ff:ff:ff:ff
altname enp3s0f0nc1pf0
inet6 fe80::1077:48ff:fe31:b6b8/64 scope link
10: pf1hpf: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 128
link/ether e2:a0:26:2c:d1:f1 brd ff:ff:ff:ff:ff:ff
altname enp3s0f1nc1pf1
inet6 fe80::e0a0:26ff:fe2c:d1f1/64 scope link
11: en3f0pf0sf0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 128
link/ether c6:f2:4e:81:0f:da brd ff:ff:ff:ff:ff:ff
altname enp3s0f0npf0sf0
12: enp3s0f0s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 02:ae:7b:fc:12:23 brd ff:ff:ff:ff:ff:ff
inet6 fe80::ae:7bff:fefc:1223/64 scope link
14: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether 02:42:4a:ee:03:cc brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
18: ovs-netdev: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 22:58:e7:4d:50:7e brd ff:ff:ff:ff:ff:ff
19: br-inside: <BROADCAST,MULTICAST,PROMISC> mtu 1500 qdisc noop state DOWN group default qlen 1000
20: br-outside: <BROADCAST,MULTICAST,PROMISC> mtu 1500 qdisc noop state DOWN group default qlen 1000
Has anyone managed to get this sample running successfully?
Any working example or advice would be really appreciated.
