I have built and installed opencv 2.4.13.4 in PX2 successfully using the guideline in https://docs.opencv.org/trunk/d6/d15/tutorial_building_tegra_cuda.html
However when I tried to run an opencv sample, it displays the following error message:
OpenCV Error: Unspecified error (The function is not implemented. Rebuild the library with Windows, GTK+ 2.x or Carbon support. If you are on Ubuntu or Debian, install libgtk2.0-dev and pkg-config, then re-run cmake or configure script) in cvNamedWindow, file /home/jesus/opencv/opencv/modules/highgui/src/window.cpp, line 483 terminate called after throwing an instance of ‘cv::Exception’ what(): /home/jesus/opencv/opencv/modules/highgui/src/window.cpp:483: error: (-2) The function is not implemented. Rebuild the library with Windows, GTK+ 2.x or Carbon support. If you are on Ubuntu or Debian, install libgtk2.0-dev and pkg-config, then re-run cmake or configure script in function cvNamedWindow
When I tried to install libgtk2.0-dev, it gave me the following error:
nvidia@tegra-ubuntu:~$ sudo apt-get install libgtk2.0-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libgtk2.0-dev : Depends: libpango1.0-dev (>= 1.20) but it is not going to be installed
Depends: libcairo2-dev (>= 1.6.4-6.1) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
How can I solve the dependencies issues?
