Problem to create engine from SSD UFF on Jetson Nano (Jetbot)
I have created my model using tensorflow object detection API, so I have my pb models.
then i create the UFF model by using this function:
ff_model = uff.from_tensorflow_frozen_model("./frozen_inference_graph.pb", output_name)
Then I want to create the Tensor RT engine using this function:
engine = ssd_tensorrt.ssd_uff_to_engine(uff_buffer)
but I get error lambda missing argument network. I have checked the code of ssd_uff_to_engine, it is written that the network has been defined by the code.
So what is wrong?
Please refer below example for converting SSD-Mobilenet from Tensorflow to TensorRT:
https://github.com/AastaNV/TRT_object_detection
https://jkjung-avt.github.io/tensorrt-ssd/
https://jkjung-avt.github.io/hand-detection-tutorial/
