I’m having some difficulties with cuPrintf myself, but I don’t have any difficulty doing what you describe.
As an example, take the simplePrintf example that comes in the SDK.
If you create a file main.cpp that contains only:
int wrapper(int argc, char **argv);
int main(int argc, char **argv)
wrapper( argc, argv );
return 0;
and change “main” to “wrapper” in simplePrintf.cu:
*** 30,36 ****
CUPRINTF(“\tValue is:%d\n”, val);
! int main(int argc, char **argv)
int devID;
cudaDeviceProp props;
— 30,36 ----
! int wrapper(int argc, char **argv)
int devID;
and change Makefile to include main.cpp and use the right architecture for you GPU (mine is 1.1 for my laptop):
*** 36,45 ****
Add source files here
EXECUTABLE := simplePrintf
Cuda source files (compiled with cudacc)
! CUFILES_sm_10 := simplePrintf.cu
CUDEPS := cuPrintf.cu
C/C++ source files (compiled with gcc / c++)
! CCFILES := \
add command line parameters so we can target multiple architectures
GENCODE_ARCH := -gencode=arch=compute_10,code="sm_10,compute_10" -gencode=arch=compute_13,code="sm_13,compute_13" -gencode=arch=compute_20,code="sm_20,compute_20"
— 36,45 ----
! CUFILES_sm_11 := simplePrintf.cu
! CCFILES := main.cpp
everything seems to work:
% verbose=1 make
mkdir -p …/…/lib
mkdir -p obj/x86_64/release
mkdir -p …/…/bin/linux/release
g++ -W -Wall -Wimplicit -Wswitch -Wformat -Wchar-subscripts -Wparentheses -Wmultichar -Wtrigraphs -Wpointer-arith -Wcast-align -Wreturn-type -Wno-unused-function -m64 -fno-strict-aliasing -I. -I/usr/local/cuda/include -I…/…/common/inc -I…/…/…/shared//inc -DUNIX -O2 -o obj/x86_64/release/main.cpp.o -c main.cpp
/usr/local/cuda/bin/nvcc -gencode=arch=compute_11,code="sm_11,compute_11" -o obj/x86_64/release/simplePrintf.cu_11.o -c simplePrintf.cu -m64 --compiler-options -fno-strict-aliasing -I. -I/usr/local/cuda/include -I…/…/common/inc -I…/…/…/shared//inc -DUNIX -O2
g++ -fPIC -m64 -o …/…/bin/linux/release/simplePrintf obj/x86_64/release/main.cpp.o obj/x86_64/release/simplePrintf.cu_11.o -L/usr/local/cuda/lib64 -L…/…/lib -L…/…/common/lib/linux -L…/…/…/shared//lib -lcudart -L/usr/local/cuda/lib64 -L…/…/lib -L…/…/common/lib/linux -L…/…/…/shared//lib -lcudart -lcutil_x86_64 -lshrutil_x86_64 -ldl -lpthread
% …/…/bin/linux/release/simplePrintf --noprompt
Using CUDA device [0]: Quadro FX 3700M
Device 0: “Quadro FX 3700M” with Compute 1.1 capability
cuPrintf() is called. Output:
magic=51217
[2, 0]: Value is:10
[2, 1]: Value is:10
[2, 2]: Value is:10
[2, 3]: Value is:10
[1, 0]: Value is:10
[1, 1]: Value is:10
[2, 4]: Value is:10
[1, 2]: Value is:10
[2, 5]: Value is:10
[1, 3]: Value is:10
[2, 6]: Value is:10
[2, 7]: Value is:10
[1, 4]: Value is:10
[1, 5]: Value is:10
[1, 6]: Value is:10
[1, 7]: Value is:10
[0, 0]: Value is:10
[0, 1]: Value is:10
[0, 2]: Value is:10
[0, 3]: Value is:10
[0, 4]: Value is:10
[0, 5]: Value is:10
[0, 6]: Value is:10
[0, 7]: Value is:10
[3, 0]: Value is:10
[3, 1]: Value is:10
[3, 2]: Value is:10
[3, 3]: Value is:10
[3, 4]: Value is:10
[3, 5]: Value is:10
[3, 6]: Value is:10
[3, 7]: Value is:10
PASSED
