I just look on the matrix, on the file ex5.mtx (I don’t have matlab). Is it this one ?
Correct me if I’m wrong.
What I understand from the file is:
This matrix is 27x27 with 153 non zeros values.
The matrix is base 1 and not base 0.
All 3 vectors have 153 values
The matrix is upper side already.
The first column is d_cooColIndA.
The second column is d_csrRowPtrA
The last column is d_ValAICP
As the matrix is symmetric, you can inverse the first column and second column to get the lower side of the matrix.
Another point, the d_csrRowPtrA has 153 values and should have 28 (N+1) values, as said in the documentation of cusparse.
I’ve followed this website to construct my CSR (or CRS) Compressed Row Storage (CRS)
This matrix is 27x27 with 153 non zeros values. (OK)
The matrix is base 1 and not base 0. (Ok) I converted to zero base.
All 3 vectors have 153 values. (OK)
The matrix is upper side already. (NO). The matrix is assumed to be stored in column-major format. For obtain Upper side I inverted the first column and second column.
I have wrong values (-1#IND) in d_ValAICP from 140 to 152 after using cusparseDcsric0 (I used double). But I feel that I don’t read correctly the file. It seems that some values are round which can lead to errors.
For example 24 22 -18518.5518518739 is round. Be sure that you have exactly the same values.
Sorry, I don’t really have time to go deeper at the moment, I will try to check that when I have time.
